Topics76,566
Posts784,685
Members12,395
Most Online204 Jul 10th, 2022
Posts: 4,984 Likes: 230
Posts: 4,984 Likes: 230 |
A set of Triumph 650 cases has appeared, stamped "T120TT DU 75311." BEWARE of these cases. The stamps are not original factory stamps, but even worse, "DU 75311" falls well into the 1968 model year, and NO " TT" bikes were built after 1967.
I should have added that these cases are on EBAY, U.S.A., under number 133675908327.
They appear to have been un-numbered replacement cases that someone stamped to pass off as rare and expensive "T120TT" cases.
Posts: 7,868 Likes: 201
Posts: 7,868 Likes: 201 |
1957 6T Thunderbird 650 1968 T100R Daytona 500 1971 TR6R Tiger 650 1970 BSA A65F 650 1955 Tiger 100 - Project 1971 BSA A65 650 - Project 1972 Norton Commando 750 "Combat"
"Charlie don't surf"
Posts: 90 Likes: 1
Posts: 90 Likes: 1 |
Being pretty careful with the description. Wonder how big a carp they think they will reel in with that pic of the numbers.
Mike
My company car is a Kenworth
Posts: 104 Likes: 5
Posts: 104 Likes: 5 |
On my 68 (DU81XXX) which I an very confident hasn't been altered, the engine number is on a raised block but doesn't have the Triumph stamps across it. I believe the stamps came in 69. If the cases are genuine and haven't had a file and restamp job, that would put the cases as 67 or early 68 as they have the oil feed to exhaust cam followers
68TR6P rebuilt as a C 70 TR6R 73 TR5T
Posts: 2,751 Likes: 113
Posts: 2,751 Likes: 113 |
I can't help thinking that anyone who is willing to pay a premium for a set of TT cases that hasn't done enough research to know these are fake kind of deserves what they get. The first giveaway is that the T120 should be a single stamp, I wouldn't have got as far as reading the actual engine number.
Call up the craftsmen Bring me the draftsmen Build me a path from cradle to grave And I'll give my consent To any government That does not deny a man a living wage
Posts: 879 Likes: 104
Posts: 879 Likes: 104 |
That's Greg, and he does say it's a non stock number, so any hopefuls are warned
Posts: 6,557 Likes: 367
Posts: 6,557 Likes: 367 |
That's Greg, and he does say it's a non stock number, so any hopefuls are warned Exactly, The ad description has not been edited? It's an honest ad, buyer warned. I have bought from this seller many times.
Posts: 1,500 Likes: 38
Posts: 1,500 Likes: 38 |
That's Greg, and he does say it's a non stock number, so any hopefuls are warned Exactly, The ad description has not been edited? It's an honest ad, buyer warned. I have bought from this seller many times. How can it be an honest ad if the item itself is dishonest?
Posts: 9,283 Likes: 226
Posts: 9,283 Likes: 226 |
How can it be an honest ad if the item itself is dishonest? What should the seller be doing differently, in your opinion?
How can it be an honest ad if the item itself is dishonest? What should the seller be doing differently, in your opinion? Dishonest cases need to be flogged and put in prison....Set of cases would be just fine for anything but a restoration..
I dunno! If the seller knows the cases have a false number, maybe saying so, and also pointing out that they are otherwise a very good, useful set of cases would do the trick? I can;t see the seller's description (Ebay link won;t work). But I took it from the previous comments that they were being advertised at face value without any information about the genuineness or otherwise of the engine number.
I dunno! If the seller knows the cases have a false number, maybe saying so, and also pointing out that they are otherwise a very good, useful set of cases would do the trick? I can;t see the seller's description (Ebay link won;t work). But I took it from the previous comments that they were being advertised at face value without any information about the genuineness or otherwise of the engine number. This is the title of the listing: Engine Motor Cases Crankcases Triumph 650 Bonneville Tiger Trophy T120R 633 This is the description: Description
Non stock number
Includes camshafts and tach drive
Timing side casting number E4534
Primary side is illegible
Thanks for going to all that trouble. It really isn't all that important though, just something that's been sold by now I expect.
Posts: 4,196 Likes: 97
Posts: 4,196 Likes: 97 |
Is pretty good to have one as spares if you blown the cases (as happened to me years ago) then remove that number and stamp your number.
Posts: 38 |
1965 TR6SR (Project) 1967 T120R (cafe-ed but in restoration) 1967 TR6R (box stock) 1967 TR6C (chopped) 1967 TR6C (box stock) 1968 T120R (flat tracker)
I can't attest to what the law does in other states, or other countries but where I live, altering, removing or re-stamping an item non-factory serial numbers makes the item subject to confiscation by the police, and the man in possession of the item is liable for criminal prosecution.
I don't have the nerve to attempt it.
Posts: 2,564 Likes: 163
Posts: 2,564 Likes: 163 |
"They sold for $152.50"
That's a very low price for a pair of cases and cams, assuming there's no hidden horrors lurking.
A specials builder wouldn't give a monkeys about the odd number, in the UK anyway.
Hillbilly bike |
Posts: 249 Likes: 8
Posts: 249 Likes: 8 |
It's a funny thing, but until about twenty or so years ago, I wouldn't have thought to look to see if the engine and frame numbers matched, or what the numbers were eg many years ago I wrecked a T100T bottom end by breaking the crank and replaced the bottom end with what I could get at the time which was from a 3TA. The bloke who subsequently bought it from me was mainly concerned with the type of main bearings it now had, rather than the engine number. Methinks it's the filthy lucre that's now a major consideration.
