wadeschields
wadeschields
quinten 91
Rohan 65
quinten 13
11,839 Registered Users
2 members (Roadwarrior, bsalloyd), 26 guests, and 66 robots.
A heads up, John has found another foundry to cast his barrels.
Anyone interested. ? He hopes to get enough names/ commitment for another batch of twenty.
These will be the same type as before, Alloy , nickasil lined, different bores and strokes will be catered for, contact John via PM here. I have my name down for a stroker set for my NORBSA.
yes, I would like another set of barrels, for my second bike, 650 cc std stroke
Is there a price guide (UK)
Thrash, Bang, Re-Build...
Contact John for prices , "JER. Hill" for his forum PM, bear in mind you supply the pistons and this is a relatively small batch of unobtanium, SRM have a similar product , they use a liner. John's will hopefully have nickasil lining if the casting is good enough quality.. i dont know exact numbers. I do know that these opportunities do not come up often, I waited 20 years to get a replacement for my worn Devimead barrels. John supplies suitable Fasteners with barrel to mate with the head.
Also bear in mind the spigot sleeves are longer than stock to accommodate stroker cranks, crank case mouths will need material removed for big bores due to larger Spigot ODs.
My big bore set from the first batch have done around 17k miles with no appreciable wear. The bike has air filters, I have read elsewhere that Nickasil does not last well with unfiltered inlets., I dunno, but I am not taking any chances.
I'll take another one!
Ray Elliott
John if you are watching this you are over your PM limit.
BSA 1969 A65F
BSA 1966 A65H
Triumph 1968 T120
Kawasaki A1R
& too many projects!
John, Please make one for me. Not sure of specs yet. Thanks, PRT
Hi Tom
Ok, I'll add your name to the list, we're a bit away from the machining stage so we can sort that out along the line.
regards
Hi
As Ray pointed out to me my pm box was full. Apologies to anyone trying it, I've now deleted a bit of space or just email me on [email protected]
regards
