New Front Fork Restrictor Locking Tool By CBS
Those that have rebuilt Triumph forks understand that locking the bottom fork restrictor can be a challenge
There are a couple things when locking the restrictor that need to be noted
-How to prevent the restrictor from spinning
-How to properly locate and index the restrictor slots
Locating the restrictor slots and preventing the restrictor from spinning can now be done in a quick and easy manner by a new tool that Kyle has developed
This tool simply threads into your bottom drain screw and catches onto the tapered slot allowing you to lock (or loosen) the bottom restrictor bolt
Works with the following applications that have the correct fork legs:
-Triumph Unit 350 / 500 (3TA / 5TA / T100R / T100C / Etc) 1957-1967
-Triumph Pre-Unit 650 (All Duplex Models) & Unit 650 (6T / T120 / TR6 / TR6C / Etc) 1961-1967
Should you be interested, please click on the link below
https://www.classicbritishspares.co...ducts/front-fork-restrictor-locking-tool
