Ron T. in KY
Ron T. in KY
Northern KY
#840637 02/20/21 8:53 pm
Maybe saw it here.
You get 150 grit self adhesive sand paper strip or roll. After the drum is turned, spokes trued and new shoes installed to the backing plate. cut the sand paper to the width of the drum and stick on, doesn’t have to go all the way round. Install the backing plate with the shoes. Have someone hold the wheel while you rotate the backing plate.
This is suppose to arch the shoes to the drum.
I believe the author said you can mount a wheel and tire assembly to the bike. Then walk the bike around.
Anybody try this
That's the way I do it.
1974 Norton Commando
1966 Lightning
1965 Lightning Rocket
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
That is better than nothing, of course you need to get the sand paper in there first so there is close to 0.5 mm (0.020") gone already so by the time you grind any high spot off the shoe (at a radius less than the drum due to the sandpaper) all further adjustment will be on activated cams.
I simply get oversized linings installed (in a modern compound to suit the drum material) then grind them to size in the mill and rotary table which avoids any form of power feed (as in a lathe) pushing the shoe sideways. (Radial cutting versed Axial)
It also means the ID and OD's are matched eliminating actual bedding in beyond not overheating the lining in the initial applications.
I use Villers Services in the UK, give then accurate drum ID, linerless installed shoe OD and they fit linings with 20 thou clearance to your measurements.
The last couple of sets i've done, i just used proper asbestos based old linings
and riveted them. I have tried a couple of modern linings and they are crap
compared to the old asbestos based ones. We don't have anywhere like Villiers
here that offer decent linings, all the relined shoes i've seen are done with car
linings and are miles too hard, i suppose if i had servo assisted hydraulic brakes
they may be ok but i haven't so i'll carry on with old ferrodo and lockheed while
i can still get them.
Nick
I use these guys in Sydney and the product on this page of theirs. Its very good.
https://bcafrictionmaterials.com.au...ials-data-sheet-mz-gold-woven-lining.pdf
It definitely wont be as cheap as DIY. Based on experience, but it leave the shite modern compounded linings for dead.
Ive heard that there a couple of places in the South of Brisbane that will do this material also but havent used them.
BSA 1969 A65F
BSA 1966 A65H
Triumph 1968 T120
Kawasaki A1R
& too many projects!
Villers use the MZ gold linings, works very well and as good as the old asbestos linings of not better.
