BikeVice
BikeVice
San Rafael, Ca.
#840203 02/16/21 2:59 pm
W
Woodsie Offline OP
W
I took the OPRV out of my 75 T160 and it does not have a screen. Is this an issue? or is a new OPRV recommended? thanks,
Woodsie #840232 02/16/21 10:07 pm
I think the screen is more to differentiate it from the twin OPRV. If anything as large as the screen mesh holes went through the pump you would have other problems.
I have not had a screen out but the shell that holds it may also be what keeps the piston in against the spring. You should check that.
W
Woodsie Offline OP
W
Thanks for that Dave. Upon closer inspection I believe the shell is still in place and the piston does seat against it. I see some marks that may indicate that the mesh has been removed. There is the number 70 stamped into the top of the domed nut. What does that signify?
70 psi rated, triples are 90 from memory....maybe you have a twin OPRV? I think they are 70.
Triple OPRVs have coarse mesh and are stamped '70'.
https://www.classicbritishspares.com/blogs/news/service-bulletin-oil-pressure-relief-valve
I just replaced mine. The old one had the coarse screen and 70 on the end cap. The new one from Harris has a fine screen and nothing stamped on the cap.
Cold starting pressure is now over 120psi, so I assume that it's the correct OPRV.
Woodsie #840271 02/17/21 10:30 am
Manual states 90 psi....interesting...I'll have to go down to the shed and see what mine has on it.
Not the easiest thing to get a photo of, but it is stamped '70'.
T160 Manual states
"Oil Pressure Relief Valve
Release pressure 85-75 p.s.i."
BSA A75 manuals state "Blow-off pressure (oil at 80°C) 70-90 lb./sq.in."
L.A.B. #840283 02/17/21 1:58 pm
W
Woodsie Offline OP
W
Thank you all. I am going to install a new spring and call it good. Thanks
Moderated by  Tridentman
