Posts: 50 |
I haven't been on line for quite some time but with a recent move, setting up a new work space and this whole Covid thing, I am starting to look at my projects again. I am going to build up a 750 motor, nothing radical, just an SRM big bore kit with the iron barrel which I have had for some time, using the stock crank and timing side bush and maybe a camshaft with a little different profile from stock, possibly a Bob Newby Belt Drive and a 5 speed cluster. My goal is to have a nice running sport/touring bike with enough grunt to tackle the hills here in British Columbia occasionally. So my questions to this knowledgeable group is which camshaft profile is recommended, from which supplier and which 5 speed cluster? I know of at least 2 suppliers of 5 speed, Nova and Performance Engineering. Is one better than the other? Is there another option I am unaware of? I am not going to be racing this bike so looking for the best ratio for the road. I may try and get the head flowed and ported as SRM recommend but for me to send it over to the UK and back is a pricey undertaking. Would the standard head suffice? Any experience/input appreciated, thanks. Forgot to mention that I also have a pair of billet rods to go into this motor. Not steel but should be better than the stock ones.
Posts: 1,270 Likes: 95
Posts: 1,270 Likes: 95 |
The 750 kit is a great bolt-on, it works very well with the standard cam. Any twin carb head will be fine, a set of slightly larger inlet valves is a fair plus PM do some good ones. Do some work on the top of the ports and open the seats and bowl for the valves, no need to go bananas. The PES 'box is a lovely bit of kit. Don't know about the other one. Rather than a belt drive i'd spend the money on a set of steel rods and a 7 plate clutch conversion, but that's just my opinion. Unless you plan to ride at 6k+ all the time, 30mm carbs will be fine.
Nick
Posts: 4,882 Likes: 63
Posts: 4,882 Likes: 63 |
Considering a Nova gearbox is $3500 sending head head back and forth across the Sargasso appears cheaper.
Kevin E |
Posts: 408 Likes: 6
Posts: 408 Likes: 6 |
Hi
Plus 1 on what Nick said. I no longer have any involvement with the PES 5 speed cluster. However people may try and tell you its CR cluster and not good for the road, which is untrue. You can adjust your final drive gearing to allow it to work well on the road. Of the ones I was involved with, most are in road going bikes.
regards
Posts: 5,670 Likes: 119
Posts: 5,670 Likes: 119 |
I run my 750 with the following mods. In order of importance IMO. Boyer EI End fed crank. 7 plate clutch, 5 speed John Hill/ PES box. With outrigger bearing in primary seal plate. Big valves , ported head. Still stock, con rods , cam, carb size. 9:1 pistons. No pinking on regular fuel. Like this the bike is V reliable, end feed increases oil flow to big ends and deletes the TS bush using a bearing to control end float. The bike has much more stomp through the mid-range than a stock 650. I have nothing against belt drive except you may want to change engine breathing through the primary, the stock triplex chain wont mind this, belt drive will. The stock 650 overpowers the timed breather if kept over 5K rpms, a 750 is worse, I keep meaning to delete the timed breather and go to breathing through the main bearing , until then I will live with a bit of splatter from the timed breather after a caning. The NOVA 5 speed has a re engineered selector system which could be a good thing, I have no experience of it, the PES 5 speed is a good bit of kit with needle rollers everywhere and works very well on the road. Big valves are not absolutely necessary, mine ran for years on stock valve sizes , if you look at Mark Parkers port work, he gets much improved flow by tweaking the ports using standard size valves. Regarding con rods I have a set of steel rods on the shelf, the reason rods fail is not because they are weak or alloy, its because the furthest big end ( drive side) gets starved of oil when the timing side bush wears, the results are generally catastrophic,, the DS big end seizes then the rod lets go, often taking the cases with it, one day I will fit the steel rods , but so long as the motor is end fed i dont think its a priority.This comes up over and over , if the timing side bush is done right and the oil is kept clean its fine,, two big Ifs,finding a shop familiar with the timing side bush tolerances might be difficult, the stock oil filtration system is crude , a paper cartridge type is a very good mod. . the end feed needs no pressure to the timing side bearing, once its done its done and is a far better solution IMO.
Posts: 11,054 Likes: 92
Posts: 11,054 Likes: 92 |
I keep meaning to delete the timed breather and go to breathing through the main bearing , until then I will live with a bit of splatter from the timed breather after a caning. I am going away from the breathing through the main bearing as the clutch is best using an oil designed for wet clutches and the debris coming from the primary into the engine is no doing any good filter or no filter. So for the next Unit Single I do will keep the timed breather but augment it with a reed valve sump breather. On the Unit single if you replace the steel sump plate with a thick piece of alloy there is room for a reed valve plus extension to reach up above the returning oil to catch the air in the crankcases. Here is my Commando version on its screw in sump plug which is even smaller. ![[Linked Image from i.postimg.cc]](https://i.postimg.cc/mksgmYpZ/IMG-20210116-112335.jpg) and screwed into the case. ![[Linked Image from i.postimg.cc]](https://i.postimg.cc/XJFvKH8D/IMG-20210116-112245.jpg) as the Unit Single square sump plate is the same as the Unit Twin it should carry across, if the reed valve sticks out too far then just add a banjo to the sump plate and run a tube to the reed valve a bit further away.
gavin eisler |
Thats V natty John. Keep us posted on how it works out.
Posts: 1,905 Likes: 25
Posts: 1,905 Likes: 25 |
Could you still protect it with the skid plate?... great idea, but that is a mighty vulnerable position.
That is why I mentioned the Banjo if space is tight. then it will be the thickness of the alloy sump plus the banjo of maybe 20mm with the outlet running backwards and the reed valve being of the Yamaha YZF125 2008 2014 air valve type that fits in a straight tube say going up behind the gearbox. ![[Linked Image from i.ebayimg.com]](https://i.ebayimg.com/images/g/1AUAAOSwIMxdXsCS/s-l1600.jpg)
Posts: 1,721 Likes: 28
Posts: 1,721 Likes: 28 |
I have a Yamaha XS650 breather valve on my B31 20170211_100110 by Sigma Projects, on Flickr 20170211_100055 by Sigma Projects, on Flickr
BSA B31 500 "Stargazer" Greeves 200 "Blue Meanie" Greeves 350 Greeves 360 Suzuki GSX1100 EFE "Sorcerers Apprentice" GM500 sprint/LSR bike "Deofol" Jawa 500 "Llareggub" Aprilia RSV Mille "Lo Stregone" '35 & '36 OK Supreme Kawasaki ZZR1400 "Kuro no senshi"
I like the primary case used as a vented breather chamber. I just use SG oil, it's fine for the clutch. I've only ever removed the sump screen once in 20k miles (that was because someone on here said i should) and it only had a small amount of debris on it. You do get a bit in the primary drive area but i only have a 3mm hole drilled about level with the chain tensioner rod as a drain back to the sump, it's drilled at an upward angle. I doubt it is necessary at all really, the bearing vent is probably all that's needed. Don't have to mess about checking primary oil level, one type of oil, great.
Quote Gavin "Big valves are not absolutely necessary, mine ran for years on stock valve sizes , if you look at Mark Parkers port work, he gets much improved flow by tweaking the ports using standard size valves."
Yes if you have a flow bench etc for testing, you can get very good results with port work.
For an amateur a set of larger valves and a little work with rotary files/emery will get some extra flow and a noticeable improvement on a road bike.
Also 90% of the blokes who successfully raced these things never saw a flow bench.
gavin eisler |
Posts: 1,481 Likes: 69
Posts: 1,481 Likes: 69 |
Here are my thoughts on your 750 conversion:- - as you already have the billet rods, use them together with a new oil pump and OPRV and add an oil filter. These are the most important factors in maintaining reliability IMHO. - I would avoid using the primary case as a breather area as it will blacken the now shared engine oil rapidly and tiny bits of swarf from the chain & clutch will get sucked back and forth through whatever breather hole you add. Maybe you could add a breather to the rocker box or elsewhere and use a reed valve. - The standard A65 Spitfire cam is considered as about as best as you can get, not sure how well it works on a 750cc variant but presumably as good. - use Pazon, Boyer or Wassel Vape electronic ignition, they are all fairly similar and should serve you well. - Don't know what carbs you are going to use but consider new carbs like the AMAL Premiers or maybe the Kehin PWK replicas like JRC, OKO etc.
Posts: 50 |
Thanks all for the replies, lots to consider. I don't intend to do an end feed conversion as there is no one local here with any experience with it and given the amount of miles this motor is likely to see I should be fine with standard timing bush. I will fit an oil filter. The sump breather is not something I have ever heard of before and sounds interesting if the 750cc proves to be an issue with excess pressure. Might be able to find someone local to add larger intake valves. That would mean seats as well? Not sure what size valves as looking at the head there doesn't seem to be a lot of extra room. The motor will eventually find its way into my Spitfire mark IV project with the idea that I could remove it and re install into any other project as this is being built up using NOS unstamped cases.
Posts: 50 |
Hi
regards
John John, I didn't realize that was your 5 speed cluster. What final drive would you recommend for road use? In the past with the regular 4 speed I have gone up a tooth on the gearbox sprocket from 19 to 20 keeping the rear drive at 47. Are you still involved with Alloy Barrels? Cheers, Bruce
Posts: 50 |
Considering a Nova gearbox is $3500 sending head head back and forth across the Sargasso appears cheaper. Yes that's probably true, I should contact SRM and see what the turn around time and shipping would be. Cheers, Bruce
Posts: 50 |
Nick Nick, That's good to know. I am still looking into cams but I know the Spitfire cam is supposed to be very good as is, just didn't know if it was suitable for the 750. I have put a 7 plate conversion into my current Lightning build but won't know how it works out until I am finished and on the road but if it proves good I may just add one to the 750. Cheers, Bruce
Posts: 7,672 Likes: 101
Posts: 7,672 Likes: 101 |
Having had the 7 plate clutch and the Bob Newby... fit the Bob Newby. In my every attempt to destroy it.. I cannot. Also if you have the PES 5 speed box, Bob will make you a clutch centre to fit the spline on the mainshaft.
The standard cam is useful, it can be advanced or retarded and still give a good power spread but move the peak torque up or down the revs. If you fit the SRM race cam it give you a lot more torque throughout the range, it makes for a very tractable yet quick bike. I currently have the X12 in my bike and it’s not bad but I think I should have saved my money and stuck with the SRM item.
Now let’s all have a beer  68’ A65 Lightning “clubman” 71’ A65 823 Thunderbolt (undergoing restoration) 67’ D10 sportsman (undergoing restoration) 68’ D14 trials (undergoing transformation)
PM Kibblewhite do the valves i was on about. You will need to cut the seats back to get the correct fitted height. May as well fit new guides at the same time.
If you do decade to fit a different cam the SRM 'race' one works well with the 750 kit, it's not radical, it's quiet, and the motor will idle. It does increase torque above around 4k. You will have to mess about with carburation/mixture a bit though. You will also need different springs. (personally, for the road i'd leave the spitfire cam in, guides will last longer, use standard springs etc)
As i've run primary type breathing for around 30 years on the track and on the road, i suppose i'm rather convinced it works well. Believe me, i wouldn't run/put up with it if it caused the problems others say will happen. I'm a lazy sod and if it made more work i wouldn't do it. As long as you have a filter it's fine, Triumph did it for years, i know that's no recommendation but it's not a unique setup.
Posts: 408 Likes: 6
Hi Bruce
For clarification regards the 5 speed. It was Mark at PES who made/makes the clusters, it was I who got it kicked off and had the first 12 sets made. I think 28 x 58 & 20 x 47 (26" OD tyre) will work fine for road work, bit of traffic and twisty roads will be Ok. Although my gearing is slightly different it works out more less the same and it'll hit 85 at 5k RPM in 5th and can still work traffic in 1st.
I don't have any barrels at the moment. I have been looking for a foundry, but so far the ones I've tried are just doing their own in house work. Or their prices have been scary in comparison to what the last batch cost.
regards
John, sent you an email with link to a guy doing B40/C15/B25 alloy barrel castings.
Posts: 408 Likes: 6
Hi Kommando
Thanks for that.
John, sent you an email with link to a guy doing B40/C15/B25 alloy barrel castings. A friend of mine is using one of their barrels on a very much used B40. It seems to run quite well!
Ive been thinking about the reed valve in the sump plate, i doubt if it will work on a twin with the central flywheel, there should be more free space in a single so long as the conrod clears the intake.
It works on a Commando, mine is just my cheap copy of a 300 USD, the objective is to get as near to the high pressure air. ![[Linked Image from nycnorton.com]](https://nycnorton.com/wp-content/uploads/2018/05/BreatherKit1.jpg)
gavin eisler |
Posts: 2,974 Likes: 80
Posts: 2,974 Likes: 80 |
the objective is to get as near to the high pressure air. ok , which according to pascals law would be anywhere inside the crankcase when pressurized , with equalization happening at the speed of sound
Posts: 50 |
The standard cam is useful, it can be advanced or retarded and still give a good power spread but move the peak torque up or down the revs. If you fit the SRM race cam it give you a lot more torque throughout the range, it makes for a very tractable yet quick bike. I currently have the X12 in my bike and it’s not bad but I think I should have saved my money and stuck with the SRM item. Alan, What is the X12 cam? I was wondering about the SRM race cam and what the difference was. As mentioned I am not racing, just looking for a good road bike. Do you have the 750 barrels? Are you saying that the Bob Newby Belt Drive Kit is not compatible with the PES 5 speed box unless you have a different clutch centre? Cheers, Bruce
As long as the oil drain back when stopped does not reach the level of the breather tube. Mikesxs.net has a XS650 reed valve breather with pipes fairly cheap. I am looking at the reed valve unit off a KTM 1190. Reed valve with cage and rubber gasket around it. Just needs a case. Could be incorporated into the top of the rocker, primary or timing cover.
Posts: 50 |
Hi Bruce
regards
John Thanks John, I think I may try this 750 with the original 4 speed first and see how it goes before springing for the 5 speed. Sorry I didn't get your barrels when you still had them! I would have prefered the alloy barrels to save some weight but I have had these SRM cast ones for a long time now so will use them. Cheers, Bruce
As i've run primary type breathing for around 30 years on the track and on the road, i suppose i'm rather convinced it works well. Believe me, i wouldn't run/put up with it if it caused the problems others say will happen. I'm sure you're right and only mentioned my concerns having converted my B44 to B50 style breathing via the chaincase. Having done the conversion I noted the engine oil blackened rapidly probably because I'm using sureflex clutch plates which seem to be made from a rubber compound rather than cork which probably accounted for the rapid blackening. I also noted a small amount sparkles in the chaincase, probably from the clutch plates, chain or rotor contact with the stator. I'm using a Magnifine filter in the return line and an alloy sump plate with magnetic sump plug so I assume any debris is immediately filtered out. I'm intrigued by Kommando's breather and personally would prefer the breather to be higher in the engine and combined with an appropriate reed valve. However if Kommando says it works then I'm willing to believe him.
Im going to play dumb here (ok, half play it) When you look at the breathing system on a car, it lets in air as well as it expells toxic blowby, ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/10723/filename/PCV valve.jpg) So, apart from the Bunn breather system which has an inlet and outlet. why is it suddenly a great idea to fit a system on a bike that will give a negative pressure in the crank case? Before PCV valves started getting added on our old heaps, an open breather was quite satisfactory. But if its also such a good idea why don't the boffins that design car engines use the same principle? It should work better surely as not all the engine displacement volume is being evacuated on a 4 or 6 cylinder car engine? If you are going to fit a reed valve then what is the benefit over the timed breather? (I've got no sway either way on this, just asking a question in a critical way)
The standard cam is useful, it can be advanced or retarded and still give a good power spread but move the peak torque up or down the revs. If you fit the SRM race cam it give you a lot more torque throughout the range, it makes for a very tractable yet quick bike. I currently have the X12 in my bike and it’s not bad but I think I should have saved my money and stuck with the SRM item. Alan, What is the X12 cam? I was wondering about the SRM race cam and what the difference was. As mentioned I am not racing, just looking for a good road bike. Do you have the 750 barrels? Are you saying that the Bob Newby Belt Drive Kit is not compatible with the PES 5 speed box unless you have a different clutch centre? Cheers, Bruce The X12 is the megacycle road race cam. I don't race either but I do like to have different bikes with different characteristics. Or rather similar bikes with different charactoristics. I am running +060 on my A65L (so thats about 680cc fwiw), I have a set of John's Aluminium barrels for my OIF A65T, but thats 823cc and has an A10 crank also. A50 cam and mild compression (although the head isn't on it yet so i don't know what it will kick over like) The BNR kit is designed to fit on the original taper shaft. The PES box uses a spline but I beleive has an adaptor... The Spline is a much better system for this IMO & FWIW, I consulted Bob some time ago asking about the spline. He said he can do a clutch centre to suit. Your best bet might be to contact him directly and confirm. If you were going down that route, I would suggest to ask Mark from PES to ship your gearbox to Bob and he will use the mainshaft as a pattern. (unless you have a vendor (Ed V?) in the states for the box) from what I have seen you'll find it be cheaper to buy the box from the UK with the exchange rate as it stands at the moment.
Negative internal pressure reduces oil leaks.
If the timed breather worked well there would be no advantage to the reed valve. IMO BSA unit 650 plus cc timed breathers do not work well, the convoluted path from the crank case to the disc valve gets out of phase with the pressure pulses as the revs rise, the cam shaft has a very narrow drilling for the gas passage about the diameter of a drinking straw, the timing chest is full of oil mist, this gets expelled and gets messy, I have pondered over the small breather passage, i reckon if it was opened up there would be more mess, BSA probably experimented with this and cunningly disguised it with the primary chaincase "chain oiler". My own experiment with a reed valve tapped into the front case timing plug hole did not go well, lots of oil was chucked out with the gases, over a litre in 30 miles. it did sound amusing at tick over .
Negative internal pressure reduces oil leaks. Negative pressure also lessens internal "windage" losses. High performance racing engines often use a vacuum pump to reduce crankcase pressure
Where you send the breathed air will affect how much oil gets carried away. On the Commando the oil tank is the first arrival point for the breathed air, just above the oil return pipe outlet, the oil tank has its own breather pipe outlet hidden behind a screen. So the oil laden air goes into the oil tank over the top of the oil before following a tortuous route to be breathed again out of the tank and into the air filter. On my MK2a with the foam air filter this stays nicely oiled unless you fill the oil tank too far above the low level mark on the dip stick then the filter clogs with oil and the engine is starved of air. The MK3 added an oil separation chamber to refine the system. ![[Linked Image from andover-<a href='http://ebay.us/EodGjF'>Norton</a>.co.uk]](https://andover-<a href='http://ebay.us/EodGjF'>Norton</a>.co.uk/img/imagescaler/de/de71a3cb9ae73c3e288283ce340ae7a0.jpg)
If the timed breather worked well there would be no advantage to the reed valve. IMO BSA unit 650 plus cc timed breathers do not work well, the convoluted path from the crank case to the disc valve gets out of phase with the pressure pulses as the revs rise, the cam shaft has a very narrow drilling for the gas passage about the diameter of a drinking straw, the timing chest is full of oil mist, this gets expelled and gets messy, I have pondered over the small breather passage, i reckon if it was opened up there would be more mess, BSA probably experimented with this and cunningly disguised it with the primary chaincase "chain oiler". My own experiment with a reed valve tapped into the front case timing plug hole did not go well, lots of oil was chucked out with the gases, over a litre in 30 miles. it did sound amusing at tick over . If I may quote PRT, he mentioned that he found no benefit over the timed breather. I have noticed that if you use the cam out of phase then this will have a big difference and I have found leaks start until an aditional breather has been used. I've used open to air breathers off the rocker box on several occasions with no adverse effects, however on my current build, it will be the first time that I have also blanked off the timed breather completely. Like you I feel that the 3/16 hole through the cam is a little small for fast evactuation of the gasses and possibly it is aqequete for a 650 but not anything with more cc's. .............................................................................................................. Kommando, I have thought about using the oil spine on an OIF as the catch tank. I think its a good idea! although it would involve adding an aditional breather pipe to the oil spine for it to work properly. I think then the PCV is absolutely neccesery as you wouldn't want to risk applying any kind of vacuum to the oil tank.
Posts: 5,532 Likes: 71
Posts: 5,532 Likes: 71 |
Im going to play dumb here (ok, half play it) When you look at the breathing system on a car, it lets in air as well as it expells toxic blowby, ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/10723/filename/PCV valve.jpg) So, apart from the Bunn breather system which has an inlet and outlet. why is it suddenly a great idea to fit a system on a bike that will give a negative pressure in the crank case? Before PCV valves started getting added on our old heaps, an open breather was quite satisfactory. But if its also such a good idea why don't the boffins that design car engines use the same principle? It should work better surely as not all the engine displacement volume is being evacuated on a 4 or 6 cylinder car engine? If you are going to fit a reed valve then what is the benefit over the timed breather? (I've got no sway either way on this, just asking a question in a critical way) The closed crankcase breathing was adapted as a result of the first emissions laws in the US in the early 60's. Before that it was offered as an option on slow moving delivery vehicles to limit oil dilution from water vapor. US engines used a road draft tube for crankcase ventilation that needed air flow from road speed to pull vapors from the crankcase. The PCV system does cut down water vapor and sludge in the engine. I notice my 96 Ducati has only one breather, Don't know if newer bikes have a system to pull in fresh air... Drag race cars use vacuum pumps or a tube hooked to the exhaust to keep a high vacuum in the crankcase. I belive this is primarily for ring seal purposes... Is there any proof, lets say on a dyno, that the vacuum one way valves offer any advantage over a proper sized open breather?
79 T140D, 96 900M Ducati ,61 A10 .On a bike you can out run the demons.. “But I don't want to go among mad people,” Alice remarked. “Oh, you can't help that,” said the Cat: “we're all mad here. I'm mad. You're mad.
Allan G |
I can under stand using one on a Norton as there is no plenum to expand into. The primary area on an a65 s probably as large as the Norton lower cases.
Posts: 1,914 Likes: 46
Posts: 1,914 Likes: 46 |
Surely, even though it’s a pre-unit, the primary case could still be used as a chamber? It’s still the same space even though its not unified to the crankcase and gearbox. Admittedly the extra joints mean even more leakage potential though!
Koan, nortons and pre unit triumphs have enough trouble keeping oil in the primary without adding to the problem..............
Posts: 5,501 Likes: 53
Posts: 5,501 Likes: 53 |
Im going to play dumb here (ok, half play it) When you look at the breathing system on a car, it lets in air as well as it expells toxic blowby, ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/10723/filename/PCV valve.jpg) So, apart from the Bunn breather system which has an inlet and outlet. why is it suddenly a great idea to fit a system on a bike that will give a negative pressure in the crank case? Before PCV valves started getting added on our old heaps, an open breather was quite satisfactory. But if its also such a good idea why don't the boffins that design car engines use the same principle? It should work better surely as not all the engine displacement volume is being evacuated on a 4 or 6 cylinder car engine? If you are going to fit a reed valve then what is the benefit over the timed breather? (I've got no sway either way on this, just asking a question in a critical way) Dumb, and not playing: In a multi-cylinder engine with pistons going up and down at different times, wouldn't the negative vs. positive crankcase pressure balance out?
Posts: 6,898 Likes: 92
Posts: 6,898 Likes: 92 |
Yes, breathing is much easier to implement in a multicylinder engine, especially compared with a twin where both pistons rise and fall together. My A65 came to me modified to breathe as a Triumph through the primary. I'm not sure that it worked very well, they left the crank seal in place.  They also put the exit tube out the front of the primary case. I don't know why, maybe it puts out less oil without the diverter that's inside the Triumph case? Most of the racing BSAs I've seen have the breather out the top rear of the primary, as Triumph did. I removed the crank seal and ran the hose to a Mike's XS reed valve mounted to the front of the airbox housing. I know it works because I can hear it. I did leave the timed breather in place. Perhaps that's superfluous? All I know is that I no longer get a small bit of oil under the exit of the timed breather when parked.
71 A65L "Zelda" 92 BMW K100rs "Gustav" 72 T120V cafe project "Mr. Jim" 72 T150V "Wotan"
Im going to play dumb here (ok, half play it) When you look at the breathing system on a car, it lets in air as well as it expells toxic blowby, ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/10723/filename/PCV valve.jpg) So, apart from the Bunn breather system which has an inlet and outlet. why is it suddenly a great idea to fit a system on a bike that will give a negative pressure in the crank case? Before PCV valves started getting added on our old heaps, an open breather was quite satisfactory. But if its also such a good idea why don't the boffins that design car engines use the same principle? It should work better surely as not all the engine displacement volume is being evacuated on a 4 or 6 cylinder car engine? If you are going to fit a reed valve then what is the benefit over the timed breather? (I've got no sway either way on this, just asking a question in a critical way) Dumb, and not playing: In a multi-cylinder engine with pistons going up and down at different times, wouldn't the negative vs. positive crankcase pressure balance out? Not dumb, That was my point, there is no negative pressure on the multi cylinder car engine with closed loop breather system. You need the breather to get rid of the toxins, acids and increased crank case compression from piston blow-by.
One of the tricks used when tuning big Japanese fours is to cut large holes in the bottom of the liners between adjacent cylinders. This allows free passage of air from under the descending piston into the space under the ascending piston
One of the tricks used when tuning the a65 engine is to cut a large section of the crankcase out in front of the left hand con-rod, thus allowing free passage when it breaks.........
4 members like this:
pushrod tom, BSA_WM20, Hillbilly bike, BSAonAnyDay |
Sounds like the voice of experience and a load of b----x too. What can mere mortals make of it?
NickL makes commonsense, I don't understand the holes of higham, though I don't appreciate everything at 1st sample.
Posts: 4,745 Likes: 58
Posts: 4,745 Likes: 58 |
NEgative pressure is a by product from the bad old days of long stroke engines that had no oil seals on the crankshaft . Up until 1990 that included Rolls Royce just by the way. The logic being that the air ( unflitered ) would be sucked in around the crank shaft by the partial vacuum in the crank case drawing the oil back in with it.
Now because designerstend to just keep on doing what they have always done, no one bothered to think about it . When Rex did the initial research for the Bunn Breather he was flabbergasted that there was zero published research on crank case venting which is one reason why Auckland University came on board as they then had the opportunity to publish a mass of papers which they did.
And FWIW the 4G 63 & 64 Mitsubishi engines have breathers that provide negative pressure at idle then reverse as the engine speed increases . IT is a problem when fitting LPG as when the system reverses it fills the crankcase with LPG .
Bike Beesa Trevor
Negative internal pressure reduces oil leaks. Negative pressure also lessens internal "windage" losses. High performance racing engines often use a vacuum pump to reduce crankcase pressure Sounds like the voice of experience and a load of b----x too. What can mere mortals make of it?
NickL makes commonsense, I don't understand the holes of higham, though I don't appreciate everything at 1st sample. Imagine a cylinder of 250cc, when the piston descends 250cc of air must be displaced from below the piston. In the adjacent cylinder the piston is ascending and needs 250cc of air to fill the space. On a road engine the route for the air to take is down between the crank webs into the sump and back up between the webs into the adjacent cylinder. At 10,000 + RPM it takes a lot of power to move the air so holes between cylinders create a short cut and an easier passage for the air.
