Posts: 1,031 Likes: 52
Posts: 1,031 Likes: 52 |
Just got a new CWC rim for 8" half brake front wheel and having problems lacing it correctly. Usually I lace them the same way the original was and everything works out fine. This rim seems to be drilled differently and is causing problems. I think it matters which way the rim goes but don't know how to figure that out. Hoping the rim wasn't drilled completely wrong. With wheel laced as in pictures the hub side outer spokes are about 1/2" too long. Usually means it's laced wrong. Also brake side spokes will only go in opposite direction of oem rim and spokes. ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/10650/filename/20200323_132412.jpg) ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/10651/filename/20200323_132345.jpg) ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/10652/filename/20200406_171433.jpg) Any help appreciated.
Bill 1974 Norton Commando 1966 Lightning 1965 Lightning Rocket 1966 Norton Atlas 1967 Norton Atlas 1948 Panhead
Posts: 11,142 Likes: 103
Posts: 11,142 Likes: 103 |
The rim is sided and should be marked usually inside the rim. I stopped using CWC as they do not always mark the rims and use changes to suit them and not either the end user or originality. On the non CWC rim I have it has brakeside written inside the rim on one side. On the small hub side between each pair of parallel spokes there should be 7 other spoke heads. Your 3rd image does not show to me. Also be useful if you read this thread on problems with the same hub. https://www.britbike.com/forums/ubbthreads.php?ubb=showflat&Number=552625
Read the thread and it might help. Least now think I can identify the brake side. On my wheel as in the pics, there are 7 spoke heads between the parallel spokes. Will look at it after bit with a clear head and maybe will figure it out. The 3rd pic was deleted( wrong one).
Posts: 321 Likes: 7
Posts: 321 Likes: 7 |
If you go to Devonrimcompany.com, the have a nice video for the BSA 8” front wheel lacing.
1951 ZB GS 1953 BB GS 1953 Super Flash 1954 Vincent BS 1963 RGS 1956 Triumph T110
Posts: 3,376 Likes: 25
Posts: 3,376 Likes: 25 |
Bill: Did you try to build it flipped over to the other side? You might have the correct holes for the two sides of the hub but they are coming from the wrong side so as to influence the effective 'length'.
Good idea. Will try that next.
Posts: 908 Likes: 14
Posts: 908 Likes: 14 |
I have found that there are a couple different ways the rims can be drilled and still lace up fine with the correct spokes. Rather then try to duplicate your old rim pattern, clear you mind and approach each side sort of separately. Meaning the pattern for each side will be the same as on your old rim but how they relate to the other side may be a bit different. This is also true for the 6" conical hubs on the B50s. A couple different drillings that use the same spoke lengths and lacing pattern on each side. CWC rims seem to use the "alternate" drilling from what most of the stock rims come with. Folks often enough call me an say I must have sent them the wrong spokes, but with a bit of encouragement they always end up figuring it out.
I have found that there are a couple different ways the rims can be drilled and still lace up fine with the correct spokes. Rather then try to duplicate your old rim pattern, clear you mind and approach each side sort of separately. Meaning the pattern for each side will be the same as on your old rim but how they relate to the other side may be a bit different. This is also true for the 6" conical hubs on the B50s. A couple different drillings that use the same spoke lengths and lacing pattern on each side. CWC rims seem to use the "alternate" drilling from what most of the stock rims come with. Folks often enough call me an say I must have sent them the wrong spokes, but with a bit of encouragement they always end up figuring it out. Appreciate the info. Using my original spokes, so know they're right. I think your clearing my mind and just figuring it out is a great idea. Was kind of stuck on how original was laced.
Posts: 1,741 Likes: 34
Posts: 1,741 Likes: 34 |
Using old spokes is not a good idea, they are highly stressed in use
BSA B31 500 "Stargazer" Greeves 200 "Blue Meanie" Greeves 350 Greeves 360 Suzuki GSX1100 EFE "Sorcerers Apprentice" GM500 sprint/LSR bike "Deofol" Jawa 500 "Llareggub" Aprilia RSV Mille "Lo Stregone" '35 & '36 OK Supreme Kawasaki ZZR1400 "Kuro no senshi"
Posts: 156 Likes: 19
Posts: 156 Likes: 19 |
Just got a new CWC rim for 8" half brake front wheel and having problems lacing it correctly. Usually I lace them the same way the original was and everything works out fine. This rim seems to be drilled differently and is causing problems. I think it matters which way the rim goes but don't know how to figure that out. Hoping the rim wasn't drilled completely wrong. With wheel laced as in pictures the hub side outer spokes are about 1/2" too long. Usually means it's laced wrong. Also brake side spokes will only go in opposite direction of oem rim and spokes. Any help appreciated. Hi Beach, Don't know if it will help you but I bought a stainless steel rim and spoke set from the Devon rim Company and used their online wheel building video. It all went perfectly and the rim was marked up by them as to which side was the brake drum side and where the brake side inner spokes started. I have attached pictures and hope they might help you. Kev E
Posts: 63 |
After looking at your wheel, I noticed that you have a cross 3 spoke pattern on the hub side. On my BSA 441 Victor Special my wheel has a cross 4 spoke pattern. I believe your wheel should be laced in a cross 4 spoke pattern as well. That would definitely explain why your spokes are 1/2 inch too long. I could submit a picture if you would like.
Peter Joe
Peter Joe I think brake side is cross 2 and hub side is cross 4. Pics of yours would be appreciated.
Posts: 63 |
Here are a few pictures of my 441 front wheel spokes. The drum size is definitely a cross 2 spoke pattern and the hub side a cross 4 spoke pattern. On your wheel it appears that the spoke pair that does the initial crossing at the hub goes out to the rim with 11 spoke hole spacing. On mine with a cross 4 it has a 15 hole spacing at the rim. It might be easier to see if I draw a picture if that would be of more help. ![[Linked Image from i.postimg.cc]](https://i.postimg.cc/hPgtx1LF/Wheel-Lacing-Drum-Side.jpg) ![[Linked Image from i.postimg.cc]](https://i.postimg.cc/02f2CKnz/Wheel-Lacing-Close-Up.jpg) ![[Linked Image from i.postimg.cc]](https://i.postimg.cc/nVqLCPQY/Wheel-Lacing2.jpg) Peter Joe
Posts: 10,635 Likes: 63
Posts: 10,635 Likes: 63 |
Looking at the pictures it looks like your nipples are the Metric version (.281 inch in diameter) while the hole is for the .300 inch nipples. In the wheel building world this is not acceptable. When .281 inch nipples are properly tightened they tend to pull through .300 inch holes in the rim. Now it could be the angle the picture was aken, but I would get my verniers.
Posts: 860 Likes: 109
Posts: 860 Likes: 109 |
Hi Beach, Have you checked the spoke lengths against the BSA data? Look at this https://bsac10c11c12.co.uk/smf/brakes-wheels-service-sheets/spokes-all-models/I am sure I saw a better set of images on some other forum ??? If I remember I have a wheel I can measure the short length spokes on tomorrow John
Looking at the pictures it looks like your nipples are the Metric version (.281 inch in diameter) while the hole is for the .300 inch nipples. In the wheel building world this is not acceptable. When .281 inch nipples are properly tightened they tend to pull through .300 inch holes in the rim. Now it could be the angle the picture was aken, but I would get my verniers. Actually am using oem spokes and nipples. Nipples are .250 and hole is .275. Hope CWC didn't drill holes in rim too large.
I would not risk it, in the UK you can buy the nipples separately, suggest you get .275" nickel plated brass nipples from Buchanan's, if they don't do them then try looking for 10ga 7mm spoke nipples. This supplier does 9ga 7mm spokes but not 10ga 7mm. ![[Linked Image from static.wixstatic.com]](https://static.wixstatic.com/media/2c0955_87cd1504fee64dc1a1c0d8b86b5f0029~mv2.jpg) I just checked my non-CWC rim and the holes are 0.255". The other alternative is to drill out the holes to 0.300" and use 10ga 0.300" nipples.
![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/10821/filename/Screenshot_20210227-124716_Gmail.jpg) Hate to drill out holes(place to rust) and then buy new nipples. Just wish CWC would do the right thing. Thinking about buying a Devon rim. Exchange rate isn't very good now.
let's start back at the begining. The Central Wheel rim sold for, and drilled and pierced for the pre-1968 offset hub, will be marked (depending when it was made) 68-5556 or RD.43.03.02.
Did you buy this rim from Central Wheel direct? Their wheel builder is correct! What he fails to take into consideration is most people doing this (even people who consider themselves a wheel builder) are rim replacers. If the rim's lacing pattern fails to match the original, they are usually lost.
For the past 40 years we have tried to make CW understand, unlike in the UK where there is usually a wheel builder in the local village, or local area; in the US wheel builders are few and far between. For the most part we are a nation of rim replacers.
It much easier to stock some 10 odd rims that will work for most applictions, than to stock some 20 or 30 that are specific to a brand or model. It just helps keep the cost down. Then, as some dealers do, offer to build the wheel for nothing if it truly will not mount. You will pay as rarely will it not work.
The rim is handed, but not marked as such. Putting some loose nipples in the holes it should be immediately evident which side is which. The difference in the angle the spokes enter this rim should be obvious. On the brake drum side the spokes should exit the rim at a greater angle than the off-brake-drum side! This as if you are pretending to view the spokes exiting the rim at 90° angle. If you don't see the difference I would walk away giving time for your observations to take hold - and practice.
![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/10823/filename/20210220_083108.jpg) ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/10824/filename/20210219_150620.jpg) let's start back at the begining. The Central Wheel rim sold for, and drilled and pierced for the pre-1968 offset hub, will be marked (depending when it was made) 68-5556 or RD.43.03.02.
The rim is handed, but not marked as such. Putting some loose nipples in the holes it should be immediately evident which side is which. The difference in the angle the spokes enter this rim should be obvious. On the brake drum side the spokes should exit the rim at a greater angle than the off-brake-drum side! This as if you are pretending to view the spokes exiting the rim at 90° angle. If you don't see the difference I would walk away giving time for your observations to take hold - and practice. Was purchased from CWC direct and enclosed is pic of what they engraved. I know about the steeper angle on the brake side. I also noticed brake side holes inner hole is higher than outer a bit. I have laced hub side first with outer spoke going cw viewed from top. Then laced inners . Now laced inner brake side and outer. Looks to be laced correctly but outer hub side spokes stick out 1/2" further(at end of threads. Thinking I can figure lacing out but the too large holes just isn't right. .245" nipple and .274 hole is wrong. I had asked for suggestion on lacing but no help.
