KC in S.B.
KC in S.B.
Santa Barbara, California
quinten 70
NickL 27
quinten 26
doug_chambers, NRpolo, Ianc15, chuckhaz, Motorelic
12,119 Registered Users
4 members (quinten, konon, Tom A65LR, Howard Inough), 37 guests, and 16 robots.
Topics76,038
Posts769,260
Members12,119
Most Online151
May 8th, 2022
#838575 01/30/21 8:47 pm
Danam Offline OP
on this 1971 A65 triple clamp I am using the shims that accommodate 7/8" bars. I have torqued the clamp bolts down so hard I'm afraid they will snap, yet with a little pressure the bars still rotate. Is there any tips for resolving this?
Thanks!
Danam #838576 01/30/21 8:56 pm
Are the two half pieces touching at both ends? If so this will stop the P clamp gripping the bars. The fix is easy, grind some of the shim away. If it isn’t touching at both sides then find yourself some new P clamps.
Also do your bars have the knurled sections for where the P clamps go?
There should also be some distance prices under the bolt heads and I believe the bolts should have a smaller hex. You might have a situation where the hex on your bolts is fouling the P clamp.
Danam #838577 01/30/21 9:16 pm
Danam Offline OP
You were spot on, the shims were touching. I ground some off and now they clamp down properly. Thank you!
btw, I'm going have to get used to these rubber mounts, not used to having and play at the handle bars. And they are a pain in the ass to install. clap
Danam #838585 01/30/21 10:11 pm
If the mounts are decent there shouldn’t be much play. The ones I’ve just fitted to mine take some effort for them to budge.
You can buy a kit compromising of all the rubber parts and metal cups etc. They don’t fit the way you would think and I believe this will effect how much rock there is also.
Danam #838586 01/30/21 10:16 pm
Do not go by the BSA parts book regarding the conical washers , the parts book only shows one per clamp, there should be two per clamp, top and bottom.
with the narrow part of the cones facing the rubbers.
Danam #838704 02/01/21 12:12 am
Danam Offline OP
If I use all the parts the book shows, the p clamps aren’t long enough
Danam #838707 02/01/21 12:30 am
Have they been cut down? perhaps converted to solid mounting without the cones, spacers, rubbers and cups?
I know people who have done this, claiming they dont like the spongy feel. Personally, having suffered the vibration of missmounted rubbers for years, I was stoked when I got them right, its very fatiguing when they vibrate,, sup to you, I reccomend getting new Pclamps if you like a smooth ride.
Danam #838759 02/01/21 4:16 pm
It's odd to me that I only notice the wobble when pushing it around. Never while riding.
69 A65T
71 B50T
85 K100RS
54/59 A10SR
69 B44VS
71 A65FS
95 Trident
