Ian Ashdown
Ian Ashdown
SoCal
quinten 88
Rohan 75
Looping, Teager, vanGinneke, Gearhard, yornocT120R
11,841 Registered Users
1 members (JubeePrince), 39 guests, and 75 robots.
#837893 01/24/21 2:45 pm
Has anyone here purchased one and installed it? Are they worth the $$$$? Are they as they say, an easy swap with everything provided that you need? any modifications? Thanks Tom
For an A65 yes,yes,yes,no.
I have one fitted to my 71 OIF A65 and it's the best thing I ever did.. The only thing, on the later casings with the cast in stator housing, you may have to dremel some clearance for the crank pulley / belt if I remember correctly.. I also removed completely the chain slipper adjuster screw and replaced the 2 inspection caps with some ventilated ones.
Just a few Beezers..
For a BSA A10, a TR6, and a Commando, yes, yes no.
Caveat - in my life NOTHING is as easy as they say however.
Rick
Got 3 kits, a racing one which is still awaiting its engine, one that’s covered a hard life on my lightning and it keeps working flawlessly (7000 miles I think) that’s on a 68, no mods needed at all on that.
And just fitting another one to the 71 A65 I’m building. As ian says the late castings are much beefier and you will need to remove some aluminium for the front pulley to clear but this isn’t a lot and doesn’t effect the structure of the alternator casting.
It’s a dry clutch so don’t use any oil, you’ll find it much lighter than the standard clutch despite having 6 springs and clutch slip will be a thing of the past.
Do these kits have a 'cush drive' on the clutch Allan?
Not in the formal sense, its said that the belt adds some form of cush. To be completely honest I have not found any difference when riding compared to the standard setup.
The bearing arangement is far superior on the BNR and you don't get any issues with clutch wobble.
1 member likes this: Kevin E
The bearing arangement is far superior on the BNR and you don't get any issues with clutch wobble.[/quote]
Where can you get these kits in the UK?
I installed a Newby belt drive on my 54 Golden Flash some years ago. It was an easy project and has worked flawlessly. Next up is a Nova 5 speed, when I can find the time.
Yes, it appears I have more money than sense when it comes to my bike. Probably true of many of us.
Where can you get these kits in the UK?[/quote]
Direct from Bob Newby. Look up BNR Racing.
