7 members (Al Navecky Jr, hardarser, pushrod tom, JDH, Tom A65LR, Dave Comeau, konon),
27
guests, and
15
robots. |
Key:
Admin,
Global Mod,
Mod
Topics76,065
Posts769,652
Members12,125
Most Online151 May 8th, 2022
Posts: 2,657 Likes: 18
Posts: 2,657 Likes: 18 |
Asking for a friend who has a 1967 B25 with a glass tank. He tried and failed with the Caswell liner. He has a line on a B50 rolling basket case that has a steel tank (model year unknown right now). Does anyone know if he could use the B50 steel tank on his B25? If more info needed, what should I tell him to look for?
Posts: 11,625 Likes: 253
Posts: 11,625 Likes: 253 |
The backbone on the B50 frame is much larger than on the pre OIF B25 so with work to the frame buffers, mounting hardware and possibly the seat position it can be done but much easier just to go for a B25 1969/70 steel tank as they are a straight swap with minimal work on the central pull down mount and a useful 3 1/4 gals capacity on the 69 version. The 69/70 B25 UK general export is the same as the US 69 but for 70 the US B25 went for a smaller tank but the fitting is just as easy as a 69.
Posts: 616 Likes: 99
Posts: 616 Likes: 99 |
![[Linked Image from i.postimg.cc]](https://i.postimg.cc/TwmNG69F/B44-2-right-side-finished.jpg) ![[Linked Image from i.postimg.cc]](https://i.postimg.cc/jSwFvPfR/B44-gas-tank-rear-rubber-mount.jpg) B44 with TR25 OIF tank. Tank rubbers have added foam rubber to help centralize the tank. Only trouble was clearance for the fuel spigots with the B44 motor, but in any case, I think the B50 tank (slightly different shape in front) has the fuel taps further back. Non-standard seat so I don't know if that will be a problem. Tom
Life's uncertain - go fast now! Anything worth doing is worth doing well. Steve said that. Anything worth doing well is worth teaching to others. I said that.
Thank you very much, kommando. That's exactly the kind of info I was after. I'll pass that on to him.
(edit) Tom, I guess we were typing at the same time. Thanks for your input too, and for the pics. That is a very cool looking machine you have there.
Posts: 4,637 Likes: 154
Posts: 4,637 Likes: 154 |
Good to hear from you, Ray. It's been a while.
We got an inch of snow in northern Illinois last night.
