Zimm
The land of pleasant living
Novice poster
Novice poster
Posts: 4 |
Hi All, I’m removing the clutch from the primary and the washer, that I need to remove to be able to attack the clutch puller, is tight like #%*& Tried brake cleaner, penetration catalyst, and finally heated the outer plate, but nothing. Anyone with an idea/hack? Thank you Stefan
Posts: 4,883 Likes: 63
Posts: 4,883 Likes: 63 |
Tried tapping with a flat face punch around the perifery to rock it off the surface?
Posts: 1,477 Likes: 52
Posts: 1,477 Likes: 52 |
Hi Stefan, Loctite when used on nut can hold the washer very strongly.
I know you used heat. How hot? I find hot enough to sizzle spit is what is needed with loctite. The washer is hardened. I tried to drill it, thinking I could use a wire hook or even tap it & use a screw with slide hammer.
Some have fabricated or found a puller such shape they used the spring studs & spring nuts & was able to pull clutch that way. I've not tried that. Good luck, let us know what happens. Don
Posts: 3,330 Likes: 17
Posts: 3,330 Likes: 17 |
Hi; I used the rotor to remove that washer; then sanded it a bit the edges to be microns smaller.
Posts: 6,898 Likes: 92
Posts: 6,898 Likes: 92 |
I always use two magnetic pickup probes to pull mine out, though I've never had one really tight as you describe.
71 A65L "Zelda" 92 BMW K100rs "Gustav" 72 T120V cafe project "Mr. Jim" 72 T150V "Wotan"
Posts: 1,595 Likes: 23
Posts: 1,595 Likes: 23 |
I've used variants of all the suggestions above, and have been successful so far. The last trick in my toolbox would be to try and weld something to the washer. As a related side note, I stripped the threads off of two pullers struggling with a clutch center once. When I finally got it off I saw that it had sheared the key and the subsequent rotation had friction welded it to the shaft.
SR
Posts: 1,068 Likes: 2
Posts: 1,068 Likes: 2 |
+1 :caused by excessive Loctite blue used on thread which migrates to washer.
It was about c1993 but am fairly sure I pulled on the 3 spring studs with a simple puller.
