Jon W. Whitley
Jon W. Whitley
#835241 01/02/21 8:03 pm
Ragmanx Offline OP
Which plug would you prefer for my '68 Lightning ?
Thank you
SteveG
i use champion N4G in mine
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1969 Honda Mini Trail
1939 farmall f30 tractor
2004 Honda Shadow Aero
1975 yamaha xs650b
1972 Norton commando
Weren't Champ N4 plugs directly specified for BSA A65s? ?
N3 was standard, but N4 works fine as well for normal riding.
i ride 'moderate' speeds use the N4Gs in all my bikes they work great the N3s were too cold...but that's just my experience
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1975 yamaha xs650b
If I recall correctly, BSA had specified Champion N3 for the Lightning, N4 for the Thunderbolt.
I run Champions N3C in my Lightning and the Firebird, the plugs are absolutely fine and troublefree.
There is a chance that Federal Mogul has changed or will change the type designation for the plugs, I have read the N3C would be listed as Champion 801C in the future. Slightly confusing but no worrisome.
Cheers!
Phil
Best regards
Phil
Duesseldorf/Germany
'62 A 65 Star (disassembled)
'69 A 65 Lightning
'71 A 65 Firebird
'84 Yamaha SR 500
should have said my 68 A65 bitsa is single carb....
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1975 yamaha xs650b
Ragmanx Offline OP
Thanx for all the replies.
My bike, with C3's, was getting hard to start in the cold. Removed and cleaned the plugs. Replaced them and it started right up with help from the choke.
I ordered two C4's from WallyWorld for $9 including shipping to try them out.
The BSA work Shop Manual calls for C4 plugs.
So all is well and you guys opinions backed that up.
Thanx again
SteveG
H
H
Factory Manual says NC3 for Lightening, NC4 for Thunderbolt. Which is a bit strange because the engines at least in the late sixties bikes were identical except for the carbs and the tach drive. Maybe they figured the Thunderbolt was the sedate tourer and need a slightly hotter plug. Probably either will work in either bike except maybe a preference for the 3 when doing a lot of higher speed riding in hot weather.
1978 Bonneville T140E
1974 Trident
1970 BSA Thunderbolt
1971 Norton Commando
1973 Norton Commando
1974 Norton Commando
2018 Kawasaki Z900RS
Ragmanx Offline OP
Thanx for your reply.
The work shop Manual that I have says Champion N4 for the A65 Lightening. Page GD 11.
From all the responses I read, I think the are very comparable. Probably depends on the owner and their particular bike.
I will run theC3's (now cleaned) and try the C4's when they arrive.
SteveG
Ola Offline
Many plugs will fit the A65. The question is, what plug will fit the rider?
(Doug Hele, 1919 - 2001)
There is much confusion when it comes to plugs. A change in grade of spark plug can be required because of changes made to the engine. Raising or lowering compression is one such example. But change the factory recommended plug because a plug fouls either from fuel or oil is not a wise decision. This especially true if the fouling is fuel related.
Take a Mikuni VM or one of the AMAL series carburetors. There is one throttle position we use the most. That is between 1/8 and 1/3 throttle. This is where the straight portion of the needle sits in the needle jet's orifice. Because the the needle moves back and forth, sliding on the brass jet, with each change in air flow as the piston draws air into the cylinder. This cause the inside diameter of the jet to enlarge over time. This leads to a rich condition in only a narrow part of the power band. The one most of us use the most: the point where the straight portion of the needle is in the needle jets orifice.
This incidental enrichment can cause the factory recommended spark plug to foul. This is happening not because you are using the wrong plug, but because the real fault is not being addressed.
Why is this important? When you changed the grade of the plug to cure the rich condition at low throttle openings the jetting when the taper takes progresively returns to normal with no change from factory jeting as the slide approaches 3/4 throttle.
So the first time you open the throttle above 1/3 throttle without the bike increasing speed (this is what is called lugging) your hotter plug that was a cure for low speed fouling now becomes a problem. It puts you one step closer to destructive detonation and detonation induced pre-igntion.
Oil fouling can create the same problem. Oil or fuel fouling is not a problem to be solved by changing plug grades! If the factory recommended plug doesn't work, and you foul plugs (either fuel or oil) it is not the plug's problem.
I see another post where someone wants to use a hotter grade plug because it has got cold and he has to use the choke. This is not a plug problem! In a properly jetted engine it is normal to have to choke the carburetor to get the engine running.
4 members like this: The Bonneville Shop, Ragmanx, Shane in Oz, Allan G
Ragmanx Offline OP
Thanks for your good insights.
I suspect I maybe be the cause of my problem by tickling the carbs too much, thinking that the engine was being starved of fuel.
Thereby fouling the plugs.
I say this because after I cleaned the plugs, the bike fired right up.
The weather here is pretty bad and I cannot ride enough to really make any meaningful determinations.
The plan , weather permitting, is too continue with the C3's. The book calls for C4's and I have some coming. Then will go from there.
Thank you,
SteveG
It’s already been mentioned but Lightning’s and other more sporting twin carb variants got N3’s and touring bikes for N4’s.
I’ve found that both bikes are happy on N3’s. I’ve ran my lightning on N4’s.... but it does seem happier on N3’s
Ragmanx Offline OP
All good insights.
I'm getting conflicting info. Which plug is hotter?
N4 is hotter than an N3.
Ragmanx Offline OP
Thank you.
Another thing that was not mentioned is the change in fuels over the years. These days the rims of the plugs are always black even if the porcelains are light tan to white. As I recall, in the "old days", I could achieve a tan color all over the plugs.
I have always run the highest octane fuel I can get at the pump, which today is 93.
That sounds like a rich idle mixture or high float level Mark if you have dark rings on the plugs. If you remove a plug from a car with fuel injection then the whole plug metal area will be a nice tan colour.
That 93 number on the pump is not the fuel's octane rating!!It is the anti-knock-index. A US fuel with a 93 AKI will have a RON (research octane number) of 98.
Using RON as a target, which is the number we used in the US for decades, the highest pump gasoline you can get is 98 RON (plus or minus a bit).
From my experience reading plugs is nothing but confusion.
When I installed new Premiers on my Trident I immediately went out for a ride, holding the throttle at a constant opening I got plugs which looked perfect, ashen colored with a good color ring when viewed through an otoscope. Tuned the idle mixture using the Color Tune. Ever since the plugs come out black.
FWIW I use N4's in my A65. The deposits start just at the bend in the electrode.
These days it's better to see some colour on the plug, err on the safe side
unless you can guarantee the fuel you buy is good. The poofteenth of power
lost is worth not holing pistons.
More likely to see some colour with the right mixture on the right plug than a suspect or right mixture on a hotter plug.. and you minimise the risk of holing pistons.
my go-to plug for most purposes has always been the NGKB8ES. but its been discontinued. i thought about spending a bunch of money for some to use up, but unless i spend several hundred bucks on those and a lot of B9s i'll have to get an alternative pretty quick anyway.
i suppose i'll go back and see whether the champions will work for me this time around. i gave up on em years ago but maybe it was just me.
in the meantime i don't know what to do about the magneto machines, as the NGK replacements for the B8ES and B9ES aren't reccommended for magnetos.
I think you willfind it has been replaced with the BP8ES
Most standard plugs are being replaced with the projecting electrode type "P" .
Unless you are running bigger pistons than 10:1's or have shaved the head past its functional limit they should clear the pistons.
