Posts: 239 Likes: 2
Posts: 239 Likes: 2 |
Hi all,
I'm having two issues with the gearbox on my 1949 M21.
1. It's getting increasingly hard to find third gear. It was always the hard one, but on the last ride I missed it more than 50% of the time (over shifted). It feels like the detent is really slight so I can only feel it if I really concentrate.
2. When I do find third, it feels like the clutch is slipping when I release it. There will be minimal power transfer for a second of two (you can rev and nothing happened), then it just kicks in suddenly, with a bit of a jolt. This happens on up and down shifting, and only going to third.
I thought the primary may have been full of oil from wet sumping, causing the clutch to slip, but it's fine.
Any ideas as to what could be causing these issues?
Luke
Last edited by Howley; 12/19/20 1:58 am. Reason: Changed the word '[***]' to 'jolt' to prevent censoring
Posts: 13,750 Likes: 79
Posts: 13,750 Likes: 79 |
I'll be interested in hearing what the experts have to say because my M21 transmission has been doing exactly the same thing for years. I've just been putting up with it, but it's a pain.
Shifting from second, it will engage third about 1 out of 10 times. Shifting down from fourth to third, it shifts perfectly. The little ratchet mechanism on the shifter is tight and timed right ... you can see and feel (shifting by hand with the cover off) that whatever is happening wrong is happening down inside the transmission ....
Time to get it out of the bike and onto the bench, I suppose! Maybe your situation is what I've needed to kick myself into action on this ...
"Why do you wear that thing, Dobby?" "This, sir? 'Tis a mark of the house-elf’s enslavement, sir."
Posts: 1,854 Likes: 29
Posts: 1,854 Likes: 29 |
Howley : anything to help a fellow sand hopper ( im originally from Kal , love the skimpies ha) you can pretty much guarantee from what you have said that the selector shaft cam are shagged out on the crest of the part where 2nd 3rd are selected ,,,this lets the follower have to much clearance and you will kind of miss 3rd and go straight to 4th when changing up from 2nd .and visa versa ...sound familiar ? that is where they always wear Lannis ....only solution is either build up the cam ( i dont recommend this) or replace the entire selector (replace is best) step 1 gear box out...you can just pull the cluster but honestly to much other stuff worth doing while you have it out. Besides the only way to check all sorts of other stuff (too much to go on about here ) is on the bench were you can see it ...its a painstaking job but very satisfying when its all in order . They are an excellent piece of engineering i have mucked around with these M series boxes a lot have done dozens of them ,,,dang people all round the country sent them to me (gee thanks) i will try to find a pic of the selector and cam ...... https://www.britcycle.com.au/wp-content/uploads/2017/02/DSCF1895-416x312.jpgyou can see where the area i am talking about is ....its the apex of the cams it will be obvious where the wear is when you pull it a better pic showing cam follower sitting right on apex im talking about https://www.trojanclassics.com/assets/alt_2/66-3288.jpg?20200707032639
I'll get out the Manual and see how to get the box out of the bike ... looks like a right bugger of a job compared to the simplicity of most stuff on this old sidevalve; oil tank out, etc .... Lannis
I'll get out the Manual and see how to get the box out of the bike ... looks like a right bugger of a job compared to the simplicity of most stuff on this old sidevalve; oil tank out, etc .... Lannis nah its pretty straight forward real easy if you can get it up off the ground somehow .......probably take 4 hours with swearing breaks ...if you want a difficult one try the semi unit plunger box whole motor needs to come out
Well let's get to work then, Shaun's been taking the mickey out of me for 12 years because I haven't sorted out the M21 transmission third gear. I have a spare M20 transmission so let's practice on that one. I was at MidOhio with Bonzo and was talking about my transmission trouble, he got up from his camp chair, went to the swap meet, and came back in an hour with this transmission: ![[Linked Image from photos.smugmug.com]](https://photos.smugmug.com/Matchless-work/i-rF9zjpd/0/8064e246/X2/SAM_1010-X2.jpg) So let's do it. I took off the small square cover: ![[Linked Image from photos.smugmug.com]](https://photos.smugmug.com/Matchless-work/i-HFwkSw3/0/d3c82901/X2/SAM_1013-X2.jpg) Then took off the outer cover where the kickstarter and shifter shafts come through: ![[Linked Image from photos.smugmug.com]](https://photos.smugmug.com/Matchless-work/i-h3bKKLF/0/5221d15a/X2/SAM_1018-X2.jpg) And this is what's under there: ![[Linked Image from photos.smugmug.com]](https://photos.smugmug.com/Matchless-work/i-ZgN8Lgw/0/b6bcbc15/X2/SAM_1019-X2.jpg) What's the order of disassembly? The shifter ratcheting mechanism, then the pinion gear, then the recessed mounting screws? Thought I'd ask while I had you guys here ... Lannis
biggest trap is if you dont pull the speedo drive shaft ( the 1/2 nut you can see on top of the inner cover) first ,, you need to undo teh small screw FIRST (the one you see above the bronze bush !/4 BSW for a few turns then long 3/16 plain section on it that does the retaining (think turned down grub screw) ...if you dont take that lock screw out ( its quite long but only a few turns of thread you wont be able to pill the bronze speedo drive spindle bush ....i have seen lots where morons havent pulled the screw and then wonder why it wont come apart so they end up forcing things and rooting it
get hold of a parts book and you will clearly see what im talking about
apart from that into it , its not rocket science ....the selector mechanism is a confusing damm thing but that wil come off with the inner cover as a unit take photos ! try to keep the selector unit in one piece if you can , easy when u have done a few but oh man when u havent ya know
dont lose the small detent spring loaded pins .....one small one that is supposed to help keep selectors neural (behind selector u can see) and a larger one behind tHE cover which goes into the 1/2 cog which drives the selector shaft i put a pic of on previously
seriously get a parts book pic that will save you a lot of head scratching at reassembly time
i can help talk u through reassembly when you need
honest man its not that hard
1. Take photos - CHECK 2. Look out for little springs - CHECK 3. Take the selector clockwork out in one piece - CHECK 4. Pull speedo drive shaft first - CHECK 5. Get out the parts Manual - CHECK I've got to make a few goodies for our family Christmas get-together tomorrow so not sure if I'll be able to put in a session today, but ... Thanks! Lannis
Get a new oil seal on the way , also figure out how you are going to get bush , or get made bush for top gear 7/8th id , you can get bushes ready made at the bearing suplier but they must be reamed when fitted ( the long bush the main shaft runs in for final drive ) you WILL need both ! ....Replace both bearings while you are in there ....they are an easy size to find just at a bearing supplier ...way cheaper that way ,,,you will aslo need a selection of shims , 7/8 id from memory for setting working clearance on mainshaft etc
Get a new oil seal on the way , also figure out how you are going to get bush , or get made bush for top gear 7/8th id , you can get bushes ready made at the bearing suplier but they must be reamed when fitted ( the long bush the main shaft runs in for final drive ) you WILL need both ! ....Replace both bearings while you are in there ....they are an easy size to find just at a bearing supplier ...way cheaper that way ,,,you will aslo need a selection of shims , 7/8 id from memory for setting working clearance on mainshaft etc Oil seals I know, shims I know, bearings I know ... but how does a regular guy deal with "must be reamed when fitted"? That's the way my BSA A65 bottom end goes in, but that's a specialist job in a shop with proper fixtures. Surely the every-day go-to-work guys that ran 90% of these bikes didn't send their gearboxes off to be done? Lannis
oil seals arnt a standard size .....i got some which were correct iD and had to skim maybee 20 thou off od made up 10 cause it was such an act you wont be able to fit a standard od off the shelf seal it will be way to tight on od
no the reaming isnt a big deal you are only taking a thou or so out to compensate for the bush collapsing a little when pressed in ...just wind a hand 7/8 reamer through it .........you can hire one for bugger all .....the clearance is on the shaft which is maybee 2 thou under 7/8 u know built in clearnce IF the bush id is exactly 7/8 .......i relieved the od of the off the shelf bush so it wasnt such a tight press fit heated up the pinion and squezzed it in with a vice and locktigh easily done with 220 paper and time
at a pinch just get a peice of round dowling wood , say 3/4 diameter and glue a few turns of 220 grit wet and dry paper to it and kind of work it a bit and keep checking for nice working clearance against main shaft till u are happy (but i didnt say that or we will get all sorts of chime ins about oh no no no it must be done like this or that ..dont worry about exact reamed size you are after working clearance
its nothing like the BS talked about line reaming ect .TS main ect ....easy to do just with hand tools !
So, unbuttoning the inner cover - the shop Manual says "4 screws" but there are five; 3 cheese-head screws and two hex-head bolts ... ![[Linked Image from photos.smugmug.com]](https://photos.smugmug.com/Matchless-work/i-HN9wnMC/0/0f5fd09b/XL/SAM_1027-XL.jpg) and off it comes. There was no oil nor any trace of it in this gearbox, but there's no rust and everything looks to be in pretty good shape. ![[Linked Image from photos.smugmug.com]](https://photos.smugmug.com/Matchless-work/i-Ts8LBrD/0/d9ce5265/X2/SAM_1028-X2.jpg) Since the mainshaft still has some bits on the drive side, it stayed in the case ... ![[Linked Image from photos.smugmug.com]](https://photos.smugmug.com/Matchless-work/i-dpDsDLN/0/fc07fefe/X2/SAM_1030-X2.jpg) Things look pretty good to my unpracticed-on-transmissions eye ... ![[Linked Image from photos.smugmug.com]](https://photos.smugmug.com/Matchless-work/i-TDq6bwn/0/b418ee97/X2/SAM_1031-X2.jpg) ![[Linked Image from photos.smugmug.com]](https://photos.smugmug.com/Matchless-work/i-8VrGg8S/0/cf785506/X2/SAM_1032-X2.jpg) In order to complete stripping it, I need to take these clutch/drive things off the primary side, but the Manual is vague on the subject: ![[Linked Image from photos.smugmug.com]](https://photos.smugmug.com/Matchless-work/i-vJVnS2X/0/2950532d/X2/SAM_1033-X2.jpg) ![[Linked Image from photos.smugmug.com]](https://photos.smugmug.com/Matchless-work/i-q7Wdwj3/0/db3aa1c0/X2/SAM_1034-X2.jpg) Thanks in advance! Lannis
Posts: 737 Likes: 211
Posts: 737 Likes: 211 |
Oil seals I know, shims I know, bearings I know ... but how does a regular guy deal with "must be reamed when fitted"? That's the way my BSA A65 bottom end goes in, but that's a specialist job in a shop with proper fixtures. Surely the every-day go-to-work guys that ran 90% of these bikes didn't send their gearboxes off to be done? Lannis Depending on the situation, for the home shop lapping can be a good way to go. A transmission bushing would be a good candidate. In the end, the bushing would still be round and not barrel shaped, given a more consistent clearance.... spreading the load and retaining the oil. You could do some reading on Time Saver Lapping compound. They have some in different grades for soft metals and hard metals. It won’t imbed itself into the bushing. I have a box of it containing the different grades of both varieties. 8 small tins. Don’t know what they sell for today. Handy stuff and in the home shop, the little tins will likely last a lifetime. Ps... another good method is ball sizing. Have a look at the new Triumph cam bushing setup (I think from CBS).. it gives an example of how it works. A search will give you the name of a US company that specializes in manufacturing the balls. Worth a search and reading some of the info there. If you can’t find it, let me know... I have the link saved elsewhere.
Lannis: what you have there is the early version of that M box , you can tell the deference by the size of the selector fork carrier shaft ...compare that size to the pic i posted in the beginning of this thread , they are NOT interchangeable
also the box you have shown doesn't have the oil seal they have s slinger system with a sort of helical grove which is supposed to keep the oil n the box ,,good luck
Did you say something about this is just a practice one and not the one in the bike you are going to fix?
but yes the one u have stripped does look in good nick
pretty easy really eh
Lannis asked : "In order to complete stripping it, I need to take these clutch/drive things off the primary side, but the Manual is vague on the subject:" if you mean the selector pauls or is that pawls (the bits the selector fork moves) in your 3rd pic from the bottom no you dont have to just list the lay shaft and gear cluster and the selector shaft out as "one piece ) ie both together once again be carefull of the spring loaded detent behind the actuator half pinion if you mean the mainshaft shown in last 2 pic yes you do because there is a retainer collar than screws onto the final drive pinion and secures the sprocket ...you cant remove this pinion without releasing that collar
Since the mainshaft still has some bits on the drive side, it stayed in the case ... In order to complete stripping it, I need to take these clutch/drive things off the primary side, but the Manual is vague on the subject: ![[Linked Image from photos.smugmug.com]](https://photos.smugmug.com/Matchless-work/i-vJVnS2X/0/2950532d/X2/SAM_1033-X2.jpg) Thanks in advance! Lannis Sounds like this tranny may not be a parts tranny for my road one. The grease pencil note on this one said it was for a '50 - '54 but that may or may not be right, just what someone thought. Mine that needs fixing is a '55. The thing I'm trying to do is get the collar with two grooves in it in the picture off of the input shaft so that the shields behind the clutch and the final drive sprocket can be taken off .... ?? Lannis
your 55 box will have the selector like this one https://www.trojanclassics.com/assets/alt_2/66-3288.jpg?20200707032639see how the shaft is clearly a smaller diameter to the one u have "The thing I'm trying to do is get the collar with two grooves in it in the picture off of the input shaft so that the shields behind the clutch and the final drive sprocket can be taken off .... ??" ah ok thats the oil slinger it sits on the end of the top gear pinion not threaded or keyed , the clutch backing plate is splined to the pinion shaft would i suggest 2 large screw drivers sharpned down to a point or a couple of old wood work chisels ? nah not realy but hey your call if u want to try that .(dont stuff the pinion spline) ....dont force it too much heat the *itch up a bit first not too much just say hot air gun hot ....it will move
Posts: 832 Likes: 96
Posts: 832 Likes: 96 |
Hi You will need to pull the clutch centre from the tapered main shaft, it has a thread to take the puller , but in this situation you miaght be able to use a split collar puller to get behind it once the clutch rear plate is off
John Whew, been a couple weeks of Christmas and New Years and a lot of other work getting done and re-doing a chainsaw fuel system and ... and .... Anyway, back to the tranny now. Successfully pulled the clutch center with a standard gear puller and a bit of tapping, pulled out the main shaft, then heated the case and tapped the big Hoffman 135 bearing out of there .... It's completely seized up, won't move at all, probably the ball race is corroded, I'm soaking it in oil now because I just want to free it up so that I can test-assemble the transmission. I want to learn to assemble it, and bench-test the shifting so I can learn how it works, so won't install new bearings and oil seals at this point, just dry-assemble and shim and time it, oil it enough to work it, and once I'm ready to tackle the one on the bike, just set this one aside as a spare, leaving a tag on it that it needs bearings and seals so's I don't forget ....
Posts: 4,745 Likes: 58
Posts: 4,745 Likes: 58 |
Get a 2RS replacement bearing & pull the inner off. Helps slow the flow These boxes are a lot of "fun" If I knew Ignoramus was an expert, I would have sent him mine too . M series had the heavy weight box for hauling side cars & B series got the medium weight box for speed. AFAIK the gears , mainshaft & the ratchet pinin interchange and that is about all. There are 4 different shift forks and as well as the pin size and std or roller pins. The distance between the actual fork and the pin also varies. I had a good box that I stuffed listening to "knowledgable" others who said to run liquid grease to prevent the oil spewing out. That might have been fine for a 1 hour putter around the foot hills but a lot of 400 to 600 km runs totally stuffed my box I thought I knew what I was doing & built up a best of bad bits box for the the 2019 BSA national. Got 1/3 into the first run & the box spat the dummy Add to that the hand change box is very similar and they came in light & medium weight as well. The gears interchange with hand change boxes, but that is it . So you have to be really careful buying parts because very few vendors actually know what they are selling. I used to get my bits from an M20 only specialist who has closed down so now it is Russell Motors in the UK . Down side is they are only open 4 days, open late & close early but LEs is over 80 so you can forgive him for that. Other problem is it calling orders, phone orders or snail mail only . OTOH prices are good, still lots of NOS parts or pattern parts that are dimensionally correct . And despite som who lurk here that like to measure to +/- 0.00001" , these boxes were designed to be fixed on the side of the road with a hand full of sand & a bent stick. The fact there are so many around running original boxes some 80 or more years latter is a testiment to their robustness. In the technical section of the WM20 forum web page you will find a wealth of tips & tricks .
Bike Beesa Trevor
Trevor Said :
"If I knew Ignoramus was an expert, I would have sent him mine too . M series had the heavy weight box for hauling side cars & B series got the medium weight box for speed. AFAIK the gears , mainshaft & the ratchet pinin interchange and that is about all. There are 4 different shift forks and as well as the pin size and std or roller pins. The distance between the actual fork and the pin also varies."
well i never said i was an expert just that ive done a few.
In some of the earlier ones the gears might be the same number of teeth (other than close ratio boxes) however the gear MODUAL is different, meaning that an early gear wont mesh with gears in a latter box. (domt ask me years ive forgotten
the main shafts can also be different lengths depending on year ie how much sticks out of the box
some also have longer selector shafts ( still haven't figured out which box the long ones fit but my best guess would be the "transitional box" made for only like 2 years between the WM box that you have and the latter 50s version .(47/8- 50?)....try finding bits for those! The early ones like WM have a larger diameter than the ones in Landis"s pic
THe selector shaft assy does have 2 different cam grooves you are right , straight cam follower pin ( 1/4" ) or roller follower (3/8 ) BUT the entire assembly will interchange dimensionally they are the same.........no idea what year that change happened.
Then there is the oil seal or no oil seal version .........man it goes on
but yep using grease in those is a real bad idea!
well i never said i was an expert just that ive done a few. No no you ain't going to get out of it that easy Preparing a couple of cartons to send your way as I type
Bike Beesa Trevor
ive been selling off loads of that surplus stuff no way i want more ...( and man it does sell fast and for reasonable $ as well) .......i think 4 fully rebulit M boxes should be sufficient spare gearboxes for 1 bike
All right, back to the M21 gearbox. I freed up the mainshaft bearing, and it spins freely and has no play. It's plenty fine for reassembling the box for practice. So I heated the case and drove the bearing back in .... View from the outside .... ![[Linked Image from photos.smugmug.com]](https://photos.smugmug.com/Matchless-work/i-N2vrpB4/0/0c4cc207/XL/SAM_1040-XL.jpg) and inside of the box ... ![[Linked Image from photos.smugmug.com]](https://photos.smugmug.com/Matchless-work/i-Q5BVsxR/0/bb64c478/XL/SAM_1039-XL.jpg) Then I slide the pinion sleeve back in ... Inside ![[Linked Image from photos.smugmug.com]](https://photos.smugmug.com/Matchless-work/i-hHkvFPX/0/9284f601/XL/SAM_1041-XL.jpg) From outside .. ![[Linked Image from photos.smugmug.com]](https://photos.smugmug.com/Matchless-work/i-VsHM68w/0/0d49e129/XL/SAM_1042-XL.jpg) Now it gets tough. I have this book, which I thought had what I needed in it, but it doesn't. ![[Linked Image from photos.smugmug.com]](https://photos.smugmug.com/Matchless-work/i-c7BgHN3/0/5bfe9e72/XL/SAM_1043-XL.jpg) The ONLY drawing it has of the gears and shafts in the gearbox is this: ![[Linked Image from photos.smugmug.com]](https://photos.smugmug.com/Matchless-work/i-tLZHBx8/0/7a55b4f8/XL/SAM_1046-XL.jpg) and there's no exploded view, no descriptions .... it says things like "If a new ballrace has been fitted to the top gear pinion, make sure that the Oil Flinger washers are correctly positioned." No picture of an "Oil Flinger Washer" and nothing about what "correctly positioned" is. I have the Russell Motors M21 gearbox catalog, but it does not have an exploded parts view, just the few parts that they sell, and there's nothing to key the part number on this page to the name of the part, like "oil flinger washer" or "locknut washer". ![[Linked Image from photos.smugmug.com]](https://photos.smugmug.com/Matchless-work/i-mrVCHTX/0/badc843d/XL/SAM_1047-XL.jpg) I don't want the folks here to have to be my personal walking talking Parts Manual, so where can I get a complete exploded view with part names that will help me relate the parts in my hand to the limited word descriptions in the Shop Manual? I'm gonna need it! Thanks! Lannis
Sorry to be the one to tell you , but out the bearing comes again there are 2 oil flinger washers .one on each side of the bearing 65-3509...the sprocket side of bearing ,it is dished so it rotates with the bearing inside the cover recess and is firmly captured by the end of the sprocket against the id of the bearing ....u will figure it when u see one the other is 24-1225 gearbox oil retaining washer .......this goes on the inside of the bearing facing the main shaft etc it is also dished so it can rotate ....if you dont have these in place you will have like 2 mm endfloat on main shaft and that will bugger the selector ability ok those numbers are off a latter box than yours with an oil seal but i dont thing BSA changed the layout or washer sizes sorry but you did ask yours has that "treaded.grooved" oil pusher back thing you had problems getting off but im pretty sure it also has the 2 flinger washers ...yep its a bran teaser
