SteveM
SteveM
Austin, KY, USA
#824100 09/17/20 7:26 pm
F
friday1 Offline OP
F
can anyone id what year this bike is ?
the photo is from 1968
tank looks like sportster or Brit
[img]https://advrider.com/f/attachments/elmo-panther-jpg.2547976/[/img]
friday1 #824130 09/18/20 7:38 am
Telescopic forks make it 47 onwards, rigid rear end means pre 58.
friday1 #824166 09/18/20 7:05 pm
F
friday1 Offline OP
F
hey , thanks
friday1 #824171 09/18/20 7:43 pm
Are they Panther forks?
Is that a BSA M20 gearbox?
friday1 #824190 09/18/20 10:30 pm
F
friday1 Offline OP
F
this is the owner of that Panther
[Linked Image from 2.bp.blogspot.com]
friday1 #824208 09/19/20 8:30 am
“What are you reballing against, Elmo?”
"Society, Man!"
Actually, I see that the 13 Rebels were/are a "family oriented" M/C and AMA sanctioned.
1966 BSA Lightning
(2) 1967 Triumph "Choppa"s
1974 Indian ME125
1960 Harley Servi-Car
friday1 #824224 09/19/20 6:47 pm
F
friday1 Offline OP
F
this early bike has that box, later seem to have Burman CP
[img]http://https://th.bing.com/th/id/OIP.x_RrKhZGSzWZPhIQbfn_EwHaEg?pid=Api&rs=1[/img]
friday1 #825455 10/02/20 8:12 pm
The later Panther heavyweights have Burman BAP boxes
This is my M120 box:
[img]https://photos.app.goo.gl/2hWGYuSHs9fGeJUn7[/img]z
BevanC #830278 11/19/20 1:24 am
[img
Thats a CP gearbox !
Identical to whats in my 49 Ajay.
A BAP gearbox is like this
[Linked Image from 2040-motos.com]
The top picture with blue tank also looks to have a BAP box.
friday1 #830567 11/22/20 12:00 am
Sorry mate, my Panther's box is a BAP - I know this because I rebuilt it and it is the correct box for a Heavyweight Panther.
Cheers, Bevan.
BevanC #830578 11/22/20 1:46 am
Are you saying this box (clicked link) is a BAP ?
I think a lot of folks are going to disagree with you.
That is identical to the Burman CP in my Ajay.
(And Ajays never used the BAP box.)
Here is a pic of another CP one, at home in a Matchy
https://matchlessclueless.com/wp-content/uploads/2010/11/R0032315-small.jpg
Here is a CP gearbox housing on fleabay - upside down.
https://i.ebayimg.com/images/g/kGMAAOSwIAxffkpA/s-l1600.jpg
And the shell - you can see the CP casting number ...(1CP)
https://i.ebayimg.com/images/g/zaMAAOSwVH1ffko-/s-l1600.jpg
If you get a BAP box, you can see the BAP in the casting number details
http://www.2040-motos.com/_content/cars/images/64/395364/003.jpg
You can also see the BAP number in the stamped number/details
http://www.2040-motos.com/_content/cars/images/64/395364/008.jpg
friday1 #830579 11/22/20 2:17 am
Here is a BAP box on UK fleabay.
https://www.ebay.co.uk/itm/VINTAGE-...-MATCHLESS-PANTHER-VINCENT-/283983397129
(Doesn't help he doesn't know what it fits !)
https://i.ebayimg.com/images/g/mTAAAOSw22ZfO-xW/s-l1600.jpg
Internals are very similar (same ?) as the CP, but in a different housing - BAP housing ...
https://i.ebayimg.com/images/g/--0AAOSwLT5fO-yc/s-l1600.jpg
friday1 #830581 11/22/20 2:40 am
friday1 #830584 11/22/20 3:10 am
Do you a photo of the rest of your BAP shell. ?
OK, I just found this. On a Vincent forum !
"Early post-war AJS's were fitted with a Burman box, and I believe that the kick-start cover is visually the same.
If my memory serves me correctly, it is the main bearing at the sprocket end that is larger on the BAP box."
(So the CP and now the BAP box have the same end covers ?)
That means there are different varieties of BAP boxes then, if you compare with the Ariel type ?
Wonder if the shaft and gears are the same, or stronger ?
Also, Burman ceased production of Burman boxes in 1955/56, what did Panther do after that. ??
It mentions that the AMC box was going to be 4 x more expensive than what Burmans supplied.
friday1 #830593 11/22/20 4:24 am
Prewar Panthers had yer more usual looking type of BAP box.
So when did the externals change ..
https://images.prewarcar.com/pics/r2w-1200x800-caradverts/227559/3332_1507026974_resized_panther.jpg
friday1 #830596 11/22/20 4:33 am
According to my Panther reference material:
P & M was Burmans last gearbox customer. Even though they were long declared obsolete, and no longer used by other marques, Burman continued to supply BAP boxes to P & M through to approximately 1962 (possibly from running down their remaining stock towards the end). Burman finally scrapped their gearbox making facilities around 1962-3 I think.
Between 1963 - 5, while under receivership, P & M continued to assemble M120s, but with AMC boxes (there is some suggestion that they may have also fitted reconditioned BAPs). The AMC boxes ultimately proved too expensive - 4 times more than the old Burman box as you say. P & M motorcycle production officially ended in 1966, although a few further bikes were assembled from spares.
Regarding my 1960 M120 - the POC machine dating registrar has confirmed that it is highly likely the frame and engine left the factory together (numbers never matched, but mine are very close, thus likely to be "original", not that I care). My magdyno is the correct model but from 1954. Similarly, my gearbox is the correct model, but is from 1956. If I recall correctly from 1958 or 9 onwards, the BAPs were oil filled, thus had an oil seal and drain plug. My BAP is the earlier box filled with semi-fluid grease.
The BA box on my 1950 Ariel is internally very similar to the BAP I think, but has the external clutch lifter arm. I think the mainshaft is a different length also.
Cheers, Bevan
friday1 #830598 11/22/20 5:23 am
Thanks.
History is a convoluted thing !
Burmans actually sold out in 1955, and then announced they were going to concentrate on making steering racks.
So Panther must have called in a few favours or something.
AMC meanwhile spent a million quid or more for the machinery to make their AMC boxes themselves.
Cheers.
friday1 #830599 11/22/20 6:42 am
You have to love British engineering design. I was unimpressed to find that the Ariels BA box has a shoulder on the mainshaft drive side that retains the gearbox sprocket - meaning that you have to withdraw the mainshaft to replace the sprocket. At least with the BAP, you can remove the sprocket in the usual manner.
friday1 #830604 11/22/20 8:30 am
CP boxes also have that block of metal on the end of the mainshaft, so likewise to the BA box the sprocket can only be changed by withdrawing the mainshaft. I was rather amused at that foible - but my sprocket was in good condition.!,
I must get a good look at one of these thar BAP boxes, details are tough to come by...
friday1 #830605 11/22/20 9:30 am
And with a bit of poking around, the internals of a BAP box (plus a few spare !)
The change in the mainshaft to make the sprocket changing more sensible is immediately obvious.
The larger bearing for the BAP is in the specs.
https://www.marston-sunbeam.org/sun...on=dlattach;topic=312.0;attach=301;image
friday1 #830646 11/22/20 7:20 pm
I don't think the BAP main bearing has standard id, if I recall correctly, the POC supply one with a ground out centre.
BevanC #832710 12/09/20 11:05 am
I remember this BAP main bearing issue,I was rebuilding a 1955 M100 at the time around 1990 and found an old bearing shop not far out of the CBD
close to the North Perth football ground.The owner was very familiar with the bearing and told me the outer surface on them are ground to suit a BAP
gearbox.Strange and a mystery.
Moderated by  kommando
