Topics77,075
Posts792,675
Members12,520
Most Online230 Mar 11th, 2023
Posts: 6,161 Likes: 161
Posts: 6,161 Likes: 161 |
![[Linked Image from i.postimg.cc]](https://i.postimg.cc/KjfTQGKL/GEDC1698.jpg) The oil lines on my BSA are 5/16", but the spigots on the oil filter are 3/8". I can't change to 3/8" hose, because all the fittings on the bike are 5/16". It looks like the fittings on the oil filter are not removable. I can get the 5/16" hose onto the filter, but it's a "stretch" (literally). It's not pretty but I guess it'll work. Is there some other solution to this problem that I'm not seeing? (BTW, the blue is masking tape. The bracket will either be painted black or remade in stainless steel.)
'65(lower)/'66(upper, wheels, front end, controls)/'67(seat, exhaust, fuel tank, headlamp)/'70(frame) A65 Bitsa. 2007 Triumph Bonneville Black
Posts: 3,447 Likes: 57
Posts: 3,447 Likes: 57 |
I usually just use NAPA fuel hose, I haven't ever damaged a 5/16" hose by working it onto a 3/8 fitting. At least never damaged one that I could tell, and that stuff needs changed every few years anyway. When working conditions are tight I use some vaseline and a shot from my heat gun.
Allan G |
Posts: 10,878 Likes: 314
Posts: 10,878 Likes: 314 |
P-80 is the way to do this. Google p-80 and get a sample.
Jon W. Whitley |
P-80 is the way to do this. Google p-80 and get a sample. Ok, I know about P-80; we have some at the shop. Thanks, I hadn't thought of that. I used slightly diluted Dawn to get the hose on, but that doesn't do anything beneficial for the hose.
Posts: 4,279 Likes: 99
Posts: 4,279 Likes: 99 |
Hello MarkZ, I have one of those filters for a project but still without fitting. I bought it several years ago and I do not remember the way the hoses go. Can you enlighten me?
Posts: 9,219 Likes: 342
Posts: 9,219 Likes: 342 |
Have you had to cut away the tool tray Mark to stop the hose fouling?
The only thing I can say about 5/16 hoses on 3/8 pipes is that I had to do this with the hoses I have on my A65 now. The inlet as we all know is 3/8 on the later bikes however the hose I bought was actually metric 10mm and not the 3/8 as stated (which is about 9.5mm) it was almost impossible to stop the leak. The smaller hose 5/16” may have been 8mm but 5/16 is closer to 8.3mm so it was a decent fit to start with. In the end I used the excess hose from the 5/16 /8mm for the inlet as well. Just warmed it up in a cup of boiling water for it to fit. Or as Leon said, use a heat gun to soften it.
Now lets all have a beer!
Posts: 2,565 Likes: 497
Posts: 2,565 Likes: 497 |
gavin eisler |
So Nick, do they make those fittings 3/8" on one end and 5/16" on the other? If so, that would solve my problem nicely.
Posts: 7,926 Likes: 220
Posts: 7,926 Likes: 220 |
So Nick, do they make those fittings 3/8" on one end and 5/16" on the other? If so, that would solve my problem nicely. Mark, If you look at more than the one picture and use the drop down menu, you will see that they do.
1957 6T Thunderbird 650 1968 T100R Daytona 500 1971 TR6R Tiger 650 1970 BSA A65F 650 1955 Tiger 100 - Project 1971 BSA A65 650 - Project 1972 Norton Commando 750 "Combat"
"Charlie don't surf"
Posts: 715 Likes: 22
Posts: 715 Likes: 22 |
P-80 is the way to do this. Google p-80 and get a sample. John I've heard you suggest that before but... From the IPC website: "Samples may be requested for larger-scale industrial or commercial applications and are not available for general or household use" Amazon has small dispensers at @$9.
1966 BSA Lightning (2) 1967 Triumph "Choppa"s 1974 Indian ME125 1960 Harley Servi-Car 1952 Harley 45" G motor in Paugho frame project
Posts: 6,794 Likes: 397
Posts: 6,794 Likes: 397 |
well, here's a liter for fifty bucks on eBay. P80 on eBaythis is an excellent deal for P80, if its the real thing. i buy mine from apparent one-off liquidation sales like this. i got a half quart once for about twenty bucks, and then a liter for about twenty.
and other stuff
Nick H |
Thanks The bottom, or center spigot on the filter is the inlet (from the engine). The side spigot is the outlet (to the reservoir). I have a two-pipe oil junction, and the rocker feed is off the oil tank. This makes my installation simple. Have you had to cut away the tool tray Mark to stop the hose fouling? I didn't/don't have a tool carrier on this bike. The "bracket" you see is just a flat piece of stock and two L brackets. I did have to work around the lower frame lug though. Ironically, as I was reading the instructions to answer reverb's question, I noticed that the supplier's prescription is to use the passenger peg mounting bolt. That would have been much simpler, but I did want to cover that area below the oil tank, since I don't have side panels on this bike either.
So Nick, do they make those fittings 3/8" on one end and 5/16" on the other? If so, that would solve my problem nicely. Mark, If you look at more than the one picture and use the drop down menu, you will see that they do.  Got it; thanks. Ordering...
Posts: 8,476 Likes: 443
Posts: 8,476 Likes: 443 |
NAPA sells a rubber lubricant also. I've never tried P80, but the NAPA stuff works well. I forget what I paid for a jug but it was no where near $50 for a liter.
it was no where near $50 for a liter. A liter should cost around $20.00.
Since we're on the subject of P80, I'll take the opportunity to repeat my testimonial regarding the use of this stuff on fork gaiters. It's been a few years now since I've been using it, and the gaiters are holding up very well.
As to my original query, I've ordered barbed brass "reducing" fittings, 3/8" to 5/16". They're coming from China, so I'll be waiting a while for them, but that's ok; I'm not planning to install the oil filter until the riding season is over. For appearance's sake, I'll first try them without clamps. (There WILL be clamps on the oil filter spigots though.)
Thanks NickL and Jon W. for the tips on where to find these fittings.
Jon W. Whitley |
...regarding the fitting; you would do that in a late in no time...no need to wait for China men.
...regarding the fitting; you would do that in a late in no time...no need to wait for China men. Assuming you meant to type "lathe": Right, but I don't have one. That's ok, I'm not in a rush to install this filter; I'm waiting until this riding season is over, which looks to be soon (I'm not a cold-weather rider), and I still have to paint the parts I made. Did you see my response to your question about the inlet vs. outlet? It got kind of buried above.
Posts: 2,162 Likes: 47
Posts: 2,162 Likes: 47 |
Sticking a narrow hose on a slightly large end fitting can risk small shavings of rubber inside the hose, so be careful. I have used a mug of hot water often, one quick flick throws any trapped water away and the hose is malleable for a few mins
Allan G |
Hi Mark; sorry; yes "lathe". Yes; I read your response.
Sticking a narrow hose on a slightly large end fitting can risk small shavings of rubber inside the hose, so be careful. I have used a mug of hot water often, one quick flick throws any trapped water away and the hose is malleable for a few mins Anglo, read on; I'm getting inline "reducing" fittings to make the transition from 3/8" to 5 /16", so I won't have to stretch the hose.
Posts: 808 Likes: 1
Posts: 808 Likes: 1 |
i find that odd. i installed 4 of those from map one on a '65 t100sr,a '54 bsa b33 and the other two were on a65's,its been 15 yrs but i think theres a screwup somewhere and a call to map is in order.i can assure you they were ALL 5/16'' i.d. hose connections.feel free to quote me.
Assuming you meant to type "lathe": Right, but I don't have one. Judging from the answers I get on the BSA forum, I thought all you BSA guys had lathes. Maybe that's just the Aussie contingent?
What you mean "you guys?" I'm just an amateur enthusiast who has owned BSAs for a very long time. I don't paint (except for little stuff), I don't weld, and I don't do machine work, except for what I can do with a band saw, a belt sander, and a drill press. Somehow I've always managed to avoid or contract out all that stuff.
