perfect.tommy
perfect.tommy
vancouver, canada
#806296 04/22/20 10:30 pm
mrcarb Offline OP
I am trying to put a 76 Bonneville basket case back together. My question is about the angle of the two fuel banjos that came with the bike, one is a v-shaped banjo and the other is more than 90 degrees. The pictures that I have found on the internet appear to have both carbs using v-shaped banjos. Would anyone reading this know if one banjo is v-shaped and the other is more that 90 degrees? Or if both are v-shaped?
I hope that this question makes sense.
Thank you in advance.
Both V shaped, I haven't actually measured one [never felt the need to] but guessing at around 120-150 degrees. AMAL website may have the actual V angle?
Both should be 55 degree V-shaped.
https://www.classicbritishspares.com/products/83-3927
Discussed in another thread only recently.
http://www.britbike.com/forums/ubbthreads.php/topics/804166/new-carbs-choke-or-no-and-which-banjos
mrcarb Offline OP
Thanks for those answers.
Does the fuel line from the right petcock go to the right carb?
Surely yes, there's no advantage to having fuel feed lines longer than necessary.
So each tap to each carb, and a link pipe between.
cant see why it would matter .
diagonal crossed lines might be a straighter shot from tank shutoff-bend to banjo .
Yes.
That's how I did mine on my 69 Bonneville, no problems and its cleaner looking
Born To Run
Born To Run
Stock setup IIRC, crossed the lines, i.e. Right petcock w/90 degree elbow to left carb banjo left petcock w 90 degree elbow to right carb banjo. Short straight piece on the other fuel line banjoes This keeps the fuel lines inside the bike for a cleaner look (US tank) the home market tank (breadbin) routed them outside the carbs I believe.
Pardon my drawing, I never claimed to be an artist!!
Banjoes
Same way mine are done, nothing wrong with that art work Prince!!!
Whether the lines cross over or not really makes no difference as each "petcock" feeds both carbs.
Not entirely correct as the same 83-3927 inward angled feed line with 55-degree banjos was used on UK/Gen.Ex. tank (pic below) until 77/78 when the UK/GenEx. tank "petcocks" were repositioned further forward and used a different 83-6209 external feed fuel line with 150-degree banjos.
http://www.classicbike.biz/Triumph/Brochures/1970/77ModelsCanadaTri.pdf
This above
I have tried all sorts, this set up works best.
