title
by bill50cal - 05/23/22 2:50 pm
Topics76,112
Posts770,172
Members12,129
Most Online151 May 8th, 2022
Posts: 11,625 Likes: 253
Posts: 11,625 Likes: 253 |
If you email the librarian at the VMCC with the details they are known to reply with bare info for free.
Posts: 17 |
Awesome!!! Great information! Thank you!! If it's only an exhaust difference, then I'm totally cool with that... the halo headlight configuration is likely going to sting quite a bit financially, but it'll at least look and be correct. Now, would a updated center stand bolt up or would I have to use the U shaped scary looking stand? Also, seeing as there was a gap in the production numbers, is it known what filled in the gap in the numbers? Curiously, mine also has the jugs painted with a heavy black paint.
Posts: 5,328 Likes: 76
Posts: 5,328 Likes: 76 |
Now, would a updated center stand bolt up or would I have to use the U shaped scary looking stand? I believe it is possible to fit the later (cradle-mounted) stand but holes would need to be drilled in the cradle or a later cradle fitted. Also, seeing as there was a gap in the production numbers, is it known what filled in the gap in the numbers? I don't know but they would also have been building Fastbacks. Edit: Also the factory numbers are not always absolutely accurate.
Posts: 4,660 Likes: 80
Posts: 4,660 Likes: 80 |
Its also worth comparing these 'factory numbers' on various lists. Some of them diverge, wildly, with each other. !!!!
A list someone quoted recently was rather different to anything I've ever sighted before. And seemed rather dubious. I'll find it...
Posts: 17 |
A list someone quoted recently was rather different to anything I've ever sighted before. And seemed rather dubious. I'll find it... Very cool.... thank you! While part of me is happy that I won't be tempted to put the high pipes on it to make it "correct", it'd still be cool as hell to have acquired one of the actual S models by chance!
Posts: 17 |
Ok all... Happy New Year! My latest quest is trying to figure out what kind of handlebar controls were originally on a 1970 Commando Roadster. Left side grip had which electrical controls? Right side had which electrical controls? The bike was never equipped with turn signals, so it'll be rebuilt as such - no turns... my arm works well enough and it'll not be ridden very much or far when completed. This is going to be a sort of amateur restoration, I guess. What am I to be looking for as far as switchgear goes? Thanks all!
My latest quest is trying to figure out what kind of handlebar controls were originally on a 1970 Commando Roadster. Left side grip had which electrical controls? Wipac Tricon sul* (horn, dipswitch [Hi/Lo] and headlamp flash). *(Not Ducon or Tricon) ![[Linked Image from gracesguide.co.uk]](https://www.gracesguide.co.uk/images/2/20/Im195903MC-Wipac.jpg) Right side had which electrical controls? None. http://www.classicbike.biz/Norton/Brochures/1970/70Norton.pdf
Posts: 615 Likes: 7
Posts: 615 Likes: 7 |
Something like this maybe.
Posts: 17 |
Something like this maybe. Where might one find such a thing? My headlight has a switch on it - what will that control then? Off, pilot and regular? Thanks again!
Posts: 1,095 Likes: 80
Posts: 1,095 Likes: 80 |
I'd say maybe horn, hi lo and flash. Switch on headlight is pilot or headlight. Think I may have the switch and halo for the headlight. Have no use for them. Switch goes on left side of bars.
Bill 1974 Norton Commando 1966 Lightning 1965 Lightning Rocket 1966 Norton Atlas 1967 Norton Atlas 1948 Panhead
Where might one find such a thing? There aren't many new, or good condition used Triconsul switch clusters around. Parts suppliers (even Andover Norton!) may try to sell you a pattern 'Tricon' switch but it's not exactly the same as it has a magneto cut-out instead of a headlamp flash button. https://andover-norton.co.uk/en/shop-details/15421/horn-dipswitch-tricon-My headlight has a switch on it - what will that control then? Off, pilot and regular? Yes, the pre-71 headlamp lighting switch would normally be a three-position (Off-Pilot-Main) Lucas 35710.
Posts: 9,062 Likes: 164
Posts: 9,062 Likes: 164 |
One of the buttons could be used to complete a circuit to close a normally open relay, to flash the headlight. Or you could just not have a headlight flasher.
One of the buttons could be used to complete a circuit to close a normally open relay, to flash the headlight. Yes, I should've mentioned that.
There’s no law saying you had to!
Thats the 1st Law of FORUM INFO, isn't it. ? Beware the info that wasn't mentioned !!!
KISS isn't always the only info you need....
Posts: 3,700 Likes: 227
Posts: 3,700 Likes: 227 |
https://www.accessnorton.com/NortonCommando/wipac-tricon-to-triconsul.22585/at least one guy has reconfigured a tricon into a triconsul . the internals are mostly the same . not easy or really sensible for most to try and do , but it depends on your skill and patience level . the linked text unfortunately has the pictures missing .
Posts: 17 |
Awesome info from all! I'll likely just get one of the repops and use the flasher button as a kill switch, although the entire bike will be getting a new harness, so all wiring options are on the table. I like playing with circuits.  Think I may have the switch and halo for the headlight. Have no use for them. Thank you but I recently found an entire halo/headlight assembly with all parts (gauge, switch,hardware, etc) on FleaBay... all together was a reasonable price and they're all getting rechromed now. My next searches are going to be for a pair of the second series of Norton gauges (the ones with the solid green blob and 7k redline indicated on the tach) and a complete tail light assembly. Tail light is looking like it's mostly made of unobtainium at the moment lol...
I have most of the tail light parts.
I'll likely just get one of the repops and use the flasher button as a kill switch, If you mean a "repop" Tricon then it doesn't have a flasher button. It has a horn (ground) switch/button and magneto cut-out (ground) button.
Posts: 615 Likes: 7
Something like this maybe. Where might one find such a thing? That particular one I got from here https://www.britcycle.com.au/ advertised as NOS. They were made in bulk so should be out there.
Posts: 17 |
I'll likely just get one of the repops and use the flasher button as a kill switch, If you mean a "repop" Tricon then it doesn't have a flasher button. It has a horn (ground) switch/button and magneto cut-out (ground) button. Ah - I'm clear now. That'll actually work too... kill switches are nice providing you don't hit it by accident.
Using a magneto cut-out won't work with points ignition or most Commando electronic ignitions without further modification (relay etc.) as the Tricon cut-out is a ground switch. Edit: Or, just not connect the cut-out? Or, fit a Ducon?
Posts: 1,803 Likes: 10
Posts: 1,803 Likes: 10 |
I got one from CBS (vendor here BSA like logo) that looks like the ad LAB posted
I got one from CBS (vendor here BSA like logo) that looks like the ad LAB posted That would almost certainly be a Tricon (or Ducon) not the Triconsul in the ad. https://www.classicbritishspares.co...ches?_pos=1&_sid=c446f38bb&_ss=r
