MikeG
MikeG
New Hampshier USA
Page 2 of 2 1 2
Hi Matty, you might get more success starting a new thread...
However, personally, I am not an advocate of having a nut each side the rim, I have tried this and find the tube isn't sitting snugly to the rim, the other thing I do is NOT clamp the nuts down from the top of the rim either, Instead I screw them up against the dust cap. These nuts will never hold the tube in place and if the tube does creep then before you know it you will have ripped the valve out with no sign of anything (if you have a nut each side you have even less warning as the valve will still sit pert on the rim). with no nuts locking you'll see the valve angled one way or the other giving plenty of time to let out some air and move it along the rim.
as for why its leaking air, its possible that there is air trapped between the tube and tyre and slowly working its way out (if you've had the tyre off recently) if youve inflated the tube and submerged the tube alone in water then there shouldn't be a problem there... Either that or the valve could be leaking itself and with not being mounted isn't adding enough external pressure to allow any to leak out. a change of valve core sometimes works or a bit of spit on the end of the valve then pump it up often works too.
Are the latest tubes from Michelin and another supplier I have used porous in some way
I think it depends on the thickness of the inner tube wall and material, Michelin make 3 different grades of inner tube, standard, heavy duty and ultra heavy duty. The thickest (4mm) and most puncture resistant is the ultra heavy duty version intended for motocross use see This link
Just to show that there is nothing new under the sun, I remember when BeezaBryan told us THIS back in 2010. laugh
Hi, Bryan!
Page 2 of 2 1 2
Moderated by  Jon W. Whitley
