The first engaging tooth of my kickstart quadrant is mullered and occasionally locks whilst trying to kick over. I know that the first tooth is a half tooth lead in. Looking at the quadrant it looks fairly symmetrical and I was wondering if the other end first tooth was ground down to 1/2 tooth, could it be turned over and reused? I would doubt if all of the teeth are used at the bottom of the kick. Any thoughts?
Normal bodge is to take off the first tooth completely and then take 1/2 of the 2nd tooth off and lose some kickstart movement. Your version would work as long as the indexing allows it which it does not.
Thanks for your input kommando. I suppose I could do that bodge as effectively that is happening anyway but the loss of important movement is a nuisance. I am not sure what you mean by ' the indexing' though? Maybe you mean that the kickstart lever would end up in the wrong position?
