Robert Dentico
Robert Dentico
Mid -Coast Maine - US
Cyborg 69
reverb 63
Cyborg 17
DucatiPete, mk31755, MAM, Jonez69, Ian Nash
11,976 Registered Users
2 members (Magnetoman, bsalloyd), 19 guests, and 20 robots.
Topics75,252
Posts757,941
Members11,976
#725951 02/18/18 12:23 am
Les P Offline OP
Can anyone identify this part please ?
The long way is around 8 - 1/4 inches (210 mm) ... 6 inch (150 mm) the other way.
It came with a bunch of 'Brit parts I picked up long ago and always wondered what it was, Triumph maybe (The finish is very close to that of the NOS Commando Fastback side cover so guessing British made)
Free to a good home if of any use to someone.
Les P #725958 02/18/18 1:39 am
Trick question ?
What is it made of - plastic or rubber.
It looks like a bumper overrider for a Honda sportscar.
But is that a thumbwheel adjuster I can see there ???
And what is the fastener we can just see a part of - metric or imperial.
Ah, a 2nd pic has appeared, didn't show that a moment ago.
That is a convoluted looking thing, with that little webbing strap...
Les P #725959 02/18/18 1:55 am
Les P Offline OP
Well Rohan, it looks to be the same fibre glass as the Norton side cover I have but near all the parts (except generic) looked to be Triumph so thought it might be off the same being put in with the rest.
It came with many Lucas switch blocks, perches, levers, a lot of AMAL parts, maybe 20 lbs of mostly Triumph Fasteners so not sure it would be off a Honda.
There was so much good stuff (on closer inspection) I sent the 'older gentleman I purchased it off another payment.
The top picture is the mold side and the resin and pin holes are visible in places, I don't recall seeing anything of that construction on a Brit car either.
Les P #725989 02/18/18 7:53 am
Hi Les,
I'm guessing that the grey bit in the middle of the part pointing towards the right of the image is a strap? An educated guess says at least that side of the part is a tool-roll holder? T150 has something very similar, although I don't think that's a T150 bit, although I'm not near my bikes to check. frown
Les P #725991 02/18/18 8:08 am
Stuart is correct, this is how it is fitted on my Trident.
Les P #725999 02/18/18 8:56 am
Well you learn something every day.
The 2nd pic, which isn't appearing again, has a webbing strap and buckle,
which presumably is secured to hold the tool roll in there.
If the tool roll stands vertically, what goes in the space underneath ?
More tool roll, or puncture repair kit, or something else.
Les P #726000 02/18/18 8:59 am
Les P Offline OP
Fantastic knowledge.
I am not sure why but even I had to refresh the page to see the two images, Thanks Stuart, yes it is a strap and thanks Peter.
Thanks, Peter. When I posted, I didn't realise how to get the Les's second image to display.
Les P #726146 02/19/18 2:10 pm
hey Les, I was just going to post what it was when everyone beat me to it. but I might need it, pm at you.
Rich
75 commando
couple of beesas a ducati
and a Honda?
Les P #726179 02/19/18 8:39 pm
Les P Offline OP
PM replied Rich.
Les P #727949 03/08/18 2:57 am
Les P Offline OP
Delivered 01:34pm Wed 07 Mar US-68059, UNITED STATES
Les P #727984 03/08/18 1:03 pm
got it last nite. Thanks a lot Les, I owe you dinner some time. What are you doing in may?
Rich
75 commando
and a Honda?
Les P #729499 03/21/18 11:55 pm
Les P Offline OP
All good Rich.
May is unknown but will probably have to think about work by then, of course that is the beginning of the dry season in the tropical top end of Australia and my Africa Twin is prepped and ready to go just in case.
I found another oddity, some form of cap for something Triumph electrical perhaps ?
I thought carburetor at first but there are no holes for cables.
Les P #729564 03/22/18 12:53 pm
And you are think right! It is for a Concentric carburetor some fettling required.
Les P #729569 03/22/18 1:08 pm
Les P Offline OP
Thank you for that Mr Healy, with some embarrassment I just put my reading glasses on and noticed it is embossed with A M A L.
It seems odd that it has no provision for the cables to exit but appears to be new so fettling it is and onto my 1974 TR5T.
Les P #729576 03/22/18 2:43 pm
Quite common to find those rubber covers on bikes and cars in UK.
Due to the continuous wet weather I guess.
Very common on car (and bike) distributors.
The original Mini was notorious for having the distributor just behind the grill where it got all of the spray etc from the road.
Quite common in the 60s to see a piece of inner tube pushed over a magneto with holes for the plug leads and tied at the end with a piece of string (no zip ties in those days).
Best of luck with the TR5T!
Moderated by  Jon W. Whitley
