Hi Mike, Sometimes they can be stubborn. Generally though with tach cable off, reach in the drive through tach cable area & turn that gear clockwise with a flat screw driver. Almost always that will push the horizontal gear out enough to grab it with some pliers.
Also, if it's still stubborn, take some needle nose pliers or the like & get between the teeth & gently "zig zag" the gear as you turn screwdriver. This can help free the horizontal gear from the cam slot if it's stuck there. You may have to kick eng to get a new position of shaft in cam slot also. Some times the slot will grab at one place, but release at another.
On a side note are you going to clubman's show at Santa Clara Fairgrounds next Sat.? I'll be there with my blue/white 73 Tiger. Stop by & say hello if you make it.
