Topics76,815
Posts788,702
Members12,450
Most Online230 Mar 11th, 2023
Posts: 11,817 Likes: 318
Posts: 11,817 Likes: 318 |
Could someone explain please why la -y does not relate to 67 as indicated by bsa docs within uk? The BSA owners club is UK focused and does not worry about what happened in the US despite the majority of BSA's output going to the US. There is a really long thread on this board which explains more but can't find it. In short if it has a -Y but a 67 number but has 70 parts its a 70. There may have been a 1000 67 A65's that were made and had to be re-exported but there is more to the story than the BSAOC has on their website. Just to confuse matters more there are 70 bikes stamped with a Y not -Y but that is a reference to extended warranty.
Posts: 10,481 Likes: 46
Posts: 10,481 Likes: 46 |
Hi Ian, Firstly, welcome to the Forum.  bought an unregistered lightning USA which is virtually identical to Kev's. It has matching numbers a65la10997 y. I'd like to know what year it is. The us title says 1970 Contributors to this thread suggest la65 -y relate to 1970 Could someone explain please why la -y does not relate to 67 Note there is a significant difference between "-Y" (Dash Y) and just "Y". The thread "kommando" couldn't find is http://www.britbike.com/forums/ubbthreads.php?ubb=showflat&Number=403236#Post403236, be prepared to be there a lo-on-ng time ... and note there will be short test afterwards.  various clues on the bike indicate its later than 67 : 2 screws on metal tank badge; twin leading front brake; bsa 'watermark' on engine numbers tag. Are the engine numbers and "bsa 'watermark'" stamped into a 'pad' raised above the surrounding crankcase metal? Are the nuts holding down the barrel base to the crankcase 12-point rather than normal 6-point, does a 1/2"AF 12-point ring spanner fit (ignoring that the barrel material might be a bit close for just any spanner to fit completely), are the studs into the crankcase 3/8" o.d. and threaded UNF? If so, more clues it's more-likely '70 rather than '67. the vintage mcc dating gurus say It left the factory 5 Jan 1967 which concurs with bsa oc info posted online which says A65 LA relates to 1967. Bantam John (bsa parts specialist in uk) tells me the bike probably had a replacement bsa engine at some point with bsa dealer restamped engine number to match the frame. As the saying goes, "Denial ain't only a river in Africa" ... Hth. Regards,
Posts: 60 |
Thanks for your replies guys. OMG! I didn't realise all the discussion about LA Y bikes! How complicated. The answer to all your Q's, Stuart, are 'yes' therefore it looks as if my bike is a 1970 bike after all which concurs with the US title. I have actually applied to BSAOC dating officer for a dating letter so I will wait with interest. Hopefully thereafter I can start the uk registration process. Thanks for your help guys. This looks like a great forum! I'm going to post a separate message about gearbox cluster removal...
Sunbeam S7 Deluxe 1949 Suzuki GP100 1979 Suzuki GT500 1977 BSA B31 1949 ZB Plunger BMW R1150 RT 2003
Posts: 5,296 Likes: 276
Posts: 5,296 Likes: 276 |
We need pictures, just so you know.
and welcome
So another Y bike, we will soon have enough for our own sub section :bigt
''Then out spake brave Horatius, the captain of the Gate: To every man upon this earth death cometh soon or late. And how can man die better than facing fearful odds, for the ashes of his fathers and the temples of his Gods?''
Posts: 9,077 Likes: 323
Posts: 9,077 Likes: 323 |
Ian, if you take the seat off and look at the bolt mounting brackets, this will tell us a lot, 69/70 frames had different seat brackets to 67/68 and pre 67 had them different again.
Some 69/70 frames had fairing tubes welded to the headstock, this wasn't on earlier frames and all 69/70 frames were fitted with a swing arm which had bronze bushings and not rubber silent block bushes, the swing arm bolt was also solid where as the earlier ones were hollow.
As already mentioned, all 70 engines had a bsa embossed number block, as did most 69's but the very early 69's were on a raised block, but not machined flush or bsa stamped.
Now lets all have a beer!
Posts: 60 |
![[Linked Image]](http://i1067.photobucket.com/albums/u424/Iantinley/image_zpssj15b0mg.jpeg) ![[Linked Image]](http://i1067.photobucket.com/albums/u424/Iantinley/image_zpsawgskika.jpeg) ![[Linked Image]](http://i1067.photobucket.com/albums/u424/Iantinley/image_zpstf3wgkw7.jpeg) Here are a couple of shots of the frame. The front of the seat doesn't latch onto a part of the frame - I wonder if this has broken off? Do these photos help identify the year? Thanks guys
Posts: 6,200 Likes: 317
Posts: 6,200 Likes: 317 |
3/8ths bihex barrel studs/nuts make it 1970.it will have a vertical clutch cable entry as well. The seat should have a pair of forks/ bracket at the front to engage with the horizontal bar at the rear end of the frame top tube.
Top end should all be back together this weekend if I don't go to a Guzzi camp in Gloucester....
Posts: 448 |
I can see the remnants of the front seat bracket in the picture. It either broke off or someone cut it off. I've had several A65 with the Y and from all my research they are '69, '70 specification even though the serial number suggests it's a '67.
reliccycles.com
Posts: 2,194 Likes: 30
Posts: 2,194 Likes: 30 |
If you plan to put it together this coming weekend Kev, don't forget to anneal the gasket even when new, and cover it with copper cote both sides. I hope the bottom of your head will be machined by SRM. After you start riding, proper retorque is essential to keep your cylinders sealed.
My head having returned from SRM, was now ready to be fitted, and after a question asked in the competition section, I equipped myself with some copper sealant, and a pair of small o-rings, so I was ready to go. Barrel and gasket prepared and ready for the head to be fitted.. ![[Linked Image]](http://kevindean.zenfolio.com/img/s7/v160/p715001407.jpg) Head looking good too.. ![[Linked Image]](http://kevindean.zenfolio.com/img/s6/v136/p804951327.jpg) ![[Linked Image]](http://kevindean.zenfolio.com/img/s7/v155/p848170002.jpg) ![[Linked Image]](http://kevindean.zenfolio.com/img/s2/v52/p564704303.jpg) :bigt
How do you guys torque the outer four head nuts, I can't fit a socket/ torque wrench on these four, so have done them by "feel" using a spanner.
Posts: 14,952 Likes: 511
Posts: 14,952 Likes: 511 |
You can buy a "crowfoot" open-end wrench that has a 3/8" or 1/2" drive hole on it, mount it at 90 degrees to the shaft of the torque wrench so that the overall length is correct, and torque it that way. I don't bother, though ... "feel" has always worked well for me. Have never had a head leak. Lannis
The worst prison is the one that you don't know that you're in.
Get a 1/2" af ring spanner, weld a 1/2" drive adaptor to it use the wrench on this with the spanner at 90 degrees to the torque wrench.
Posts: 8,758 Likes: 380
Posts: 8,758 Likes: 380 |
GrandPaul (does not use emoticons) Author of the book "Old Bikes" Too many bikes to list, mostly Triumph & Norton, a BSA, & some Japanese "The Iron in your blood should be Vintage"
Now where was I?With the head all bolted down, and the rockers installed, it was time for some new SRM adjusters to be fitted... ![[Linked Image]](http://kevindean.zenfolio.com/img/s11/v3/p776601398.jpg) ![[Linked Image]](http://kevindean.zenfolio.com/img/s12/v178/p920898609.jpg) ![[Linked Image]](http://kevindean.zenfolio.com/img/s7/v155/p261306703.jpg) Next on the list was refitting the exhaust system... ![[Linked Image]](http://kevindean.zenfolio.com/img/s6/v135/p947365210.jpg) ![[Linked Image]](http://kevindean.zenfolio.com/img/s1/v56/p1011882455.jpg) ![[Linked Image]](http://kevindean.zenfolio.com/img/s9/v97/p206011053.jpg) Now I have a couple of questions.... 1. can someone tell me the thread size of the rocker cover head studs, the end that goes into the head. As I need to run a tap down the threads in the head. 2. I am after the part number for the oil tank drain/filter gasket. Thanks.
Centre studs are 1/4 BSF tapped in the ally.
Posts: 684 |
The pictures are well lit and in focus too, yay!
And the pipes are stock/original?
What is the latest opinions about the mushroom tappet adjusters?
Looking good kev!
I'd use phenolic distance pieces between head and the carbs. In town and in the traffic jam they can save your carbs from overheating.
My little BSA has had to take a back seat for a while, I just can't find the correct forks for the bike, so it is just sitting on the bench until something turns up.
Hi Kev, My little BSA has had to take a back seat for a while, I just can't find the correct forks for the bike, Risking asking a silly question, you do know that '70 BSA forks are essentially the same as contemporary Triumph forks? The only really BSA-peculiar bits are the sliders; fit Triumph sliders - and ride the bike :bigt - 'til the Beeza bits come along? Hth. Regards,
Or leave the triumph sliders on and don't change them because they don't looks any different
Hi Allan, Or leave the triumph sliders on and don't change them because they don't looks any different I did wonder ... I couldn't see any difference but, as most other '69/'70 forks part numbers are the same as Triumphs, I thought Small Heath must've given the sliders different part numbers for a reason I couldn't see ...? Regards,
They could have their differences but as the wheel fits the same they look close enough for me not to be too worried if it was mine.
I can't find Triumph ones either, I ave been looking. I have the correct wheel now with 8" twin leading brake. One will turn up.
