Posts: 11,142 Likes: 103
Posts: 11,142 Likes: 103 |
Have an original mudguard on the Norton, all my other bikes get them fitted as it does work. Skimpy mudguards look cool but in West Scotland conditions do not work, so either move to sunnier climes or fit mudguards. Also another reason to stay with factory specified thin tyres instead of cool looking wide tyres.
Posts: 5,723 Likes: 134
Posts: 5,723 Likes: 134 |
The tanks back story, my old man was in the Polish 1st armoured division and captained one of these things. The allies kept the 1 st armoured div in Scotland until the final push in France, from 1940 -44 they were building coastal defenses in Scotland. No match for Tigers and Panzers the Cromwell was fast but under gunned and under armoured in comparison, I have a pic of my old mans tank somewhere showing welded on man hole covers as added Armour. He was invalided out with a leg full of shrapnel after the Battle of Falaise and met my mother to be in a hospital in Glasgow.
back to the bike.
The outrigger plate John supplies with the 5 speed cluster need careful fitting , he advises this is best done with the cases split, some trimming of the mounting flange may be needed. Also John has found with the cluster fitted in his test bike , there are some minor clearance issues with subtle amounts of casing removal needed for the extra gears, this was very minor on his bike, but the later 71 castings are a little heavier all round so I expect I may have a little more work to do. @kommando, i have been down the tyre width changes before, back to stock widths after pointless experimentation.
The alloy tank has been welded up at Ramsay ladders , I now need to find an oven large enough to anneal it, 390 -410 C ( I think?) , the pottery up the road may be able to help .
Posts: 13,804 Likes: 95
Posts: 13,804 Likes: 95 |
It's not a madness Gavin. For me BSA has 2 flaws: - pre OIF is the small bike and after I retire I'd like to take my wife with me from time to time, - it still vibrates and this tires me so every trip longer than 200 km is a problem. This is why I wanted to try a Trident, which is not as big and heavy as my old Japanese bruisers and its still a Britbike. I've been in exactly the same situation. As Allan says, the dry frame BSA can be made to be very smooth with dynamic crank balancing and an EI to make sure cylinder firing is synchronized. However, be sure to sit on a Trident or Rocket with your wife before you make the plunge. The motor is certainly as smooth as anything you will find, and plenty of pull for two-up, but physically it's not really much longer than an A65 and will not have much more room. Check it out first. In my situation, I bought a Commando. About 2" longer and two disc brakes ...... Lannis
"Why do you wear that thing, Dobby?" "This, sir? 'Tis a mark of the house-elf’s enslavement, sir."
Posts: 3,681 |
I was reading about a guy moaning about the vibration of his Trident but after 35 years of riding twins when I get on my Trident I have to say "what vibration?" But, no, it isn't any bigger than my OIF Bonnie
Posts: 7,862 Likes: 123
Posts: 7,862 Likes: 123 |
In my situation, I bought a Commando. About 2" longer and two disc brakes ...... Lannis Yes, and Andover Norton do some lovely front end improvements too, it was very tempting to get one of their twin fully floating disc setups to squeeze into the beezer, very stylish!!
Now let’s all have a beer  68’ A65 Lightning “clubman” 71’ A65 823 Thunderbolt (undergoing restoration) 67’ D10 sportsman (undergoing restoration) 68’ D14 trials (undergoing transformation)
Strip down continues at a leisurely pace, today I removed the air boxes, chain guard , carbs, loom, battery carrier, rear mudguard with tail light and grab rail came off as one unit , handy. Discovered an unknown defect, the coil carrier bracket has fractured where it mounts at the rubber on the timing side, weld needed. The TS airbox mount bracket has lost its captive nut, more welding. Apart from being filthy everything came apart with no grief. New carb brass plated slides still in A1 condition. Not much muck in the fuel filters at the banjos. The skankiest part so far is the battery carrier rubber tray, this has turned into a sticky mess, the DS side panel rubber has seen better days as well. An old original fault may be dealt with , I have never been able to stop the coil bracket from saying hello to the side panel, even with the panel as far outboard as the slot will allow, I think this and the added weight of the voltage reg rec may have caused the crack. needs a new location for the reg rec. Much to my surprise all the loom connectors parted correctly, I will re use about 75% of the loom, replacing the ignition circuit and adding a few relays I am considering 55% as a balance factor, this should move the sweet spot up the rev range a bit, currently starts getting rough at 5K plus. No real surprises so far. Note to self, run the loom under the coil bracket not over it.
Thanks for the gen Nick. My current gearbox shifts pretty well, but I have spent a fair bit of time setting it up, it does not shift well on the down change when the primary chain gets slack, other than that its good. I like the lathe plan, thats do -able.
Pics of new shiny bits. 5 speed cluster, lay shaft to fore showing needle roller for 1st. ![[Linked Image]](https://i101.photobucket.com/albums/m79/argpod/IMG_0146_zpsrbptbrp3.jpg) Selector plate with lovely finish and extra track for selector. ![[Linked Image]](https://i101.photobucket.com/albums/m79/argpod/IMG_0149_zps4idan3a0.jpg) Outrigger bearing and plate. ![[Linked Image]](https://i101.photobucket.com/albums/m79/argpod/IMG_0152_zpsttzjeahv.jpg) Outrigger plate mounted on mainshaft showing splined mount for clutch centre. ![[Linked Image]](https://i101.photobucket.com/albums/m79/argpod/IMG_0155_zpsz6qnsazx.jpg) Main shaft sleeve gear needle roller bearings ![[Linked Image]](https://i101.photobucket.com/albums/m79/argpod/IMG_0156_zps7c4ihjph.jpg) Cluster with selector forks loose assembly ![[Linked Image]](https://i101.photobucket.com/albums/m79/argpod/IMG_0164_zpsobsdmldi.jpg) Fork stanchions , seal, lamp bucket, wires , gears. ![[Linked Image]](https://i101.photobucket.com/albums/m79/argpod/IMG_0170_zpsnhy6m88v.jpg) Rear mudguard assembly and airbox ![[Linked Image]](https://i101.photobucket.com/albums/m79/argpod/IMG_0173_zpsgoq6qylm.jpg) The end of the pencil indicates the cracked zone of the coil bracket ![[Linked Image]](https://i101.photobucket.com/albums/m79/argpod/IMG_0176_zpsvoyn7srk.jpg) Carbon fiber side stand 133 grammes , £10 from China. I will not pay £100 for a steel club. Better the stand is the weak point than the frame tab. ![[Linked Image]](https://i101.photobucket.com/albums/m79/argpod/IMG_0179_zpstb2hsyz5.jpg) The camera certainly adds an extra scabbiness to the before pics. I will be treating rust with electrolysis, brown soup to follow. Cheers G
Posts: 1,393 |
Insanely jealous of the five speed set up.
I'm waiting to find a complete engine for the price those sets are fetching.
Posts: 2,055 Likes: 16
Posts: 2,055 Likes: 16 |
Entertaining winter read as always, Gavin. I just powdercoat my frames and hidden bits mainly for resistance to scratching and a low price. Your decision to buy a five speed cluster still looks much better and cheaper to mine of buying another bike with a five speed  .
Hi Adam, I am undecided about what type of paint to use for the frame. It wont be shotblasted, thinking of a Caustic Soda marinade after power washing with citric acid. Will probably use a brush for the frame and get the air boxes blasted and sprayed black locally.The list of frame repairs is increasing.
Manufacture and weld a slotted saddle for the tank centre mount. Manufacture and weld a side stand bracket. Same for footrest mounts, 2 x 1 inch OD bosses, radiused to frame tube OD tapped to suit peg mounts ( 3/8 th UNF). Re weld the air box mounting fixed nut ( 1 x 5/16 UNF).
Trim the coil bracket and hanger brackets to prevent fouling with side panels. Weld crack in coil bracket, trim coil bracket around perimeter to prevent fouling with side panels.
The good news is the Swing arm bearings are OK, I replaced them in 1983, and have greased them with a zealousness that can only be attained after pounding out the seized solid previous swinging arm spindle.. I am very curious to know how well the taper roller headstock bearings have lasted. I have never had to replace these , I did add fresh grease once about 20 years ago. there is no untoward play or notchiness.
Posts: 2,640 Likes: 12
Posts: 2,640 Likes: 12 |
The good news is the Swing arm bearings are OK, I replaced them in 1983, and have greased them with a zealousness that can only be attained after pounding out the seized solid previous swinging arm spindle.. I am very curious to know how well the taper roller headstock bearings have lasted. I have never had to replace these , I did add fresh grease once about 20 years ago. there is no untoward play or notchiness. gavin, I saw this and wondered how many people in the world still have the motorcycle that they owned 33 years ago -- some do, I'm sure. Out of that number, how many remember that they replaced the swing arm bearing that year -- a lesser number, I'm sure. Like me, you must keep a "bike diary" for each one. You often make me chuckle as I read your thread, but I always do read it. I'm still trying to decide if you wrench on your BSA so that you can ride it, or if you ride it so you'll have a reason to spanner it. Both, I suspect. Ray
i remember replacing the SA bearings very well, it took a weekend of heat and heavy hammers, ultimately i pre purchased a new spindle and bushes so that I could get serious with the old one, it was so seized that half the old bushes came out stuck on the steel spools. I had to make a special puller extractor and ream the finished item . It had never been lubed! No diary, just memory burned in.
Posts: 1,815 |
Bit off topic, Ray, but I bought my Triumph T140 new in 1976, in fact did the pre delivery on it. It has a rather large note book! Forty years worth! Oh, and has never been out of registration!
Posts: 1,815 |
This is an interesting thread, Gavin. That gearbox is beautifully made. I'm aquiring all new gearbox bits for my T140 race project, and the bits look a touch agricultural compared those components if yours. Looking forward to your impressions when its all up and running.
@ Zombie , re expense. heres how I budget. look at wrecks on e bay, add on the cost and hassle of fixing some one else's grief , then put that in the back of your mind, dont bid on it and get some quality , one off parts ( sourced from the town where I was educated, by a loon who had the same physics teacher as me) , at a fraction of the cost instead, simple.
That gearbox does look good, well engineered and well machined too. I see the PES on the outrigger plate, so they do them for twins too as well as the singles.
The clutch fitted is pretty fresh, replaced basket and hub with fresh steel plates and surflex friction plates, its behaving well, no slip or drag so its going back in, not shown in the pics is the clutch centre with female splines to suit. If the clutch was knackered I would fit an alloy item.
Triless: I've always thought that the best way to get a classic motorcycle is to buy a good one when it is brand new, and then age gracefully with it. So, I admire you for keeping your Matchless and your T140 for so long. You did the pre-delivery on the T140? That's even better.
Gavin: Pardon my ignorance on such things, but how do you seal your primary chaincase with that bearing in place of a seal? I see that it is a "sealed" bearing, but those plastic side pieces are really only good to keep most of the grease in place and most of the dirt out on wheel bearings. They are far from being a real dynamic seal. Also, the bearing is a slip fit on the shaft, so there is no sealing action there. Where does the seal fit?
Also, what is the process for aligning this bearing with the other two on the same shaft? Will there be any machining required to accomplish this?
I'm not being negative here. I hope it all works as you have planned it. Those are just the questions in my mind as I look at your pictures.
Posts: 416 Likes: 6
Posts: 416 Likes: 6 |
Hi Ray
Written in the assembly instructions describes how to go about the alignment set-up. Unlike early earlier Brg support plates which were on the gearbox mainshaft and indeed requiring the alignment of all three Brg's. On this one it the final drive gear Brg and the support plate which are aligned, while the mainshaft run on needle Brg's through the final drive gear, therefore the mainshaft has a little more tolerance.
With regards to the original seal, this sealed on the final drive gear bush, to ensure that no gearbox oil found its way out onto the rear tyre, as there is less likelyhood of primary chain oil by-passing the seal.
Hope this is of help
Thank you for the reply, John. I somewhat follow that. I'm sure it will become even clearer as Gavin shows us his pictures here. Sounds very interesting. I can only imagine next year's riding season in Scotland!
I had the priviledge of a test cluster assembly on John's bench, JH also supplied a detailed write up as a memory jogger. Its not quite as simple as the 4 speed ,requiring a specific order of assembly to locate all the selectors. I havent any major concerns over sealing the primary, hotted up unit singles ( CCM and the like) have used outrigger plates for years. There are 6 potential alignments using the mounting flange , I will use the least worst of these and if needs be modify the mounting spigot to suit. I am more concerned about the size of the outrigger plate Fasteners, ( stock is 6 x 2BA fine for a seal carrier , maybe a bit under-size for a bearing load)if there is enough meat on the casings I may enlarge the female threaded holes to 6mm or 1/4 UNC depending on which countersunk heads have a chance of fitting, these Fasteners will be fitted with Loctite, maybe stud lock grade. Once fitted I dont anticipate removing the plate until the next gearbox sprocket wears out. John has shown me a few pointers here, it may not be possible to enlarge all the Fasteners , on the GB Sprocket side there is space to fit nuts on some of the Fasteners if left oversize, but the sprocket gets in the way a bit. Currently composing a shopping list. Nyloc Nuts and bolts , misc 1/4" 5/16", 3/8" UNF . SS 1/4" washers, countersunk head 6 off x 1/4 " UNC, half size nylocs to suit. battery and side panel rubbers, tray and strap, frame grommets. Gasket set. Seals. Gearbox sprocket 21 T and chain. Kickstart cotter pin. Copper Sulphate. Na OH Caustic soda. Zinc plating kit. Black Paint ( for brushing on the frame, any favourites out there?). Looking at the headstock zone, there is a bit of free space between the support gussets , I want to fit a breather catch bottle in here so I dont need 4 feet of oil tank breather hose. Under the seat , space will be freed up by mounting the reg rec to the base of the battery carrier and fitting the Boyer EI pack into a side panel with sticky velcro.
Once you start using the outrigger plate the force that was bending the mainshaft now is placed on the fixing screws for the plate so how you attach the plate becomes a lot more important. This thread gives some solutions for Unit Singles http://www.b50.org/phpBB2/viewtopic.php?f=3&t=4603&hilit=outriggerScrews coming undone is not unknown so loctite or wiring is a must.
Nick, when you used 5mm screws , did you tap out the existing 2BA female threads or drill and tap new mountings? Thanks for the link Kommando, very informative.
I could have sworn the original screws were 3/16
