Posts: 7,732 Likes: 34
Born To Run
Born To Run
Posts: 7,732 Likes: 34 |
Took the case off again, torn oil seal. WHY? I took my time putting on the case yesterday and even took it off again to check. All was ok, yet today, this. I have now fitted yet another seal, again double checking all is well. At the risk of be-laboring a point, I had asked earlier if it is a PW (Pioneer Weston) seal? There are oil seals and there are Oil Seals..... Cheers, Steve
'77 T140J "Vintage Bike". What's in your garage?
Posts: 3,347 Likes: 34
Posts: 3,347 Likes: 34 |
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=P+W+seals+britbike.com+site:www.britbike.com
The above link will take you to almost every conversation about that damn seal. Hopefully one of them turns a light bulb on. I hate it when you think you are doing everything right and things are still wrong.
Posts: 31 |
Unfortunately we cannot seem to locate PW seals. Where in the UK can I get some? Started her up this morning, 85 PSI and no reduction when it got hot. God knows why this is as the pressure release valve is a known to work item from my mates Bonny. There was no difference when both were used last time so there should be no difference this time. Next I will try the other valve and try both springs to see if there is a difference in them. Took the case off again, torn oil seal. WHY? I took my time putting on the case yesterday and even took it off again to check. All was ok, yet today, this. I have now fitted yet another seal, again double checking all is well. At the risk of be-laboring a point, I had asked earlier if it is a PW (Pioneer Weston) seal? There are oil seals and there are Oil Seals..... Cheers, Steve
Posts: 1,393 |
When you thread in a new pressure relief valve there is a HUGE chance of disturbing debris from the threads. The very first start up, the valve may have locked up, and is not opening.
It would pay to chase out the threads, and clean the debris with brake/carb clean before installing a new/rebuilt valve.
Also, I prefer pipe dope/Yama bond, perfect seal, ect, on these sort of joints vs. Teflon tape. The tape can cut off in the thread, and end up in the valve.
Posts: 11,142 Likes: 103
Posts: 11,142 Likes: 103 |
Just looked at Eriks. What if he doesn't need 500 seals?
Posts: 10,330 Likes: 24
Posts: 10,330 Likes: 24 |
Hi, cannot seem to locate PW seals. Where in the UK can I get some? Have you tried Reg Allen or Phil at L.P. Williams? 85 PSI and no reduction when it got hot. God knows why this is as the pressure release valve is a known to work item from my mates Bonny. There was no difference when both were used last time so there should be no difference this time. Unfortunately, the Triumph OPRV is a mortally piss-poor design.  If you don't separate the domed cap from the valve itself before loosening or tightening the valve, you will almost certainly loosen and tighten the whole assembly with the cap hex., which can distort the valve and lock the piston ...  OPRV thread is Unified Constant Pitch, 24 tpi iirc; tap would be a fortune, any other method increased likelihood of damaging rather than fixing thread.  I clean with old toothbrush and degreaser. Hth. Regards,
Hi Nick, OR... if a manufacturer wants to be bloody awkward with threads on his gear! OR... if a manufacturer has come across shade-tree 'mekaniks' who'll replace an OPRV with a standard-thread bolt to 'improve' the oil pressure ...?  Also, what exactly are the Tracy Tools taps 'n' die for?  "Brass" (BSB) isn't the same as "Cycle" (CEI/BSC) and neither is the same as Unified. I've used a 1/4" Brass tap to clean up a 1/4" BSF cover fastening thread but I'd hardly want to try the same on a Unified thread supposedly resisting oil pressure for the sake of possibly removing a few bits of loose swarf? Regards,
Posts: 887 |
Regards, A favourite practice of mine (well with kero anyway). I feel it has done some good at times  RR
'72 Bonneville "He who praises you for what you lack wishes to take from you what you have." - Don Juan Manuel
Just looked at Eriks. What if he doesn't need 500 seals? They have lots of local counters in the UK to service the factories in the area quickly, I have bought single engine sets of seals and bearings from them. Minimum order over the counter was £15 last time I used them so I go prepared with a list and leave it with them. You may have to wait a few days for them to get the funny sizes/clearances from the central warehouse.
Posts: 31 |
I did thik of L P Williams, he does brilliant sump pluds with a good sharp thread. Ideal for when your old one is a bit tired. Will strip and clean the valve next weekend and try all the different springs and combinations. worst case I can add some fibre washers to lower the pressure and see how it goes.
Hi Nick, The Tap is 7/8 x 16 UNS. Not BSB, where did you get that from? I suggest you actually have a look at the link Errrm ... if you look at the actual link you posted, it says, "brass-cycle-special" ... "brass" is aka "BSB" - British Standard Brass. "brass", "cycle" and (Unified?) "special" are three different threadforms. From previous first-hand experience, I know that Cycle and Unified do not fit together, even when they are the same tpi, due to other difference in the the threadforms; given BSB is even more different from Unified than Cycle is ... Hence my question, "what exactly are the Tracy Tools taps 'n' die for?"; it cannot be for all the three threadforms in the link because they're all different. I appreciate it says, "UNS" on the linked page but, having had problems in the past with Tracy's accuracy, and only some lengthy detective work involving a microscope will tell what the actual threadform is, I'm merely pointing out the discrepancies? Hth. Regards,
Posts: 31 |
Tried another pressure valve today, 80 psi, did not move much when hot, so, put in another one. Same again, so packed dome nut off with two more washers. 65 psi now, still no reduction when hot. I will take it or a run next weekend and see if it goes down after a few miles of running. Does it matter if it stays that high? It has mostly new internals and I was expecting a good pressure, but this seems a little on the high side. At least the seal is working well!
Posts: 1,678 Likes: 16
Posts: 1,678 Likes: 16 |
Unless I'm missing something, I would think adding washers would raise the blowoff pressure not lower it, because you are increasing the resistance of the spring requiring higher pressure to move the valve. I think you may be going in the wrong direction adding washers to lower the blowoff pressure.
1978 Bonneville T140E 1974 Trident 1970 BSA Thunderbolt 1971 Norton Commando 1972 Norton Commando 1973 Norton Commando 1974 Norton Commando 2018 Kawasaki Z900RS
Posts: 1,815 |
Packing the dome nut out would relieve spring pressure. Washers behind the spring would increase spring tension.
I assumed he meant washers under the spring not between the dome nut and the housing piece.
Posts: 31 |
I assumed he meant washers under the spring not between the dome nut and the housing piece. No. If you add washers between the dome and the body part, then it reduces the tension on the spring allowing it to blow off at a lower pressure, hence now only 65 psi. If I were to add washers under the spring then it would put more tension on the spring and up would go the pressure blow off limit.
Hi, Tried another pressure valve today, 80 psi, did not move much when hot, so, put in another one. Just as a matter of interest, how are you deciding it's "hot"? I use the pressure drop indicated by the gauge as an indication that the whole engine is properly warmed-up (and can then be thraped). When I've ridden on cold days, I can go dozens of miles before I see the gauge indicate a pressure drop from cold and, on a triple, that usually involves blocking off the oil cooler. How many miles are you riding before deciding the engine's "hot"? Regards,
Posts: 710 |
Paranoia about oil pressure begins with installation of oil pressure gauges. Ted Simon knew nothing about the workings of his engine yet it carried him faithfully around the world.
I bought my '70 T100R in a very well-used condition more than 25 years ago and have been flogging it hard ever since, yet have only ever had the primary cover off.
Hi Nick, Paranoia about oil pressure begins with installation of oil pressure gauges. Depends. Switches turning lamps on/off and gauges tell you different things. Given the number of speed limits in most First World countries, and the penalties for exceeding them, would you really replace the speedo. with a lamp that goes off above just 7 mph? Do you use the speedo. to make a judgement about appropriate speed given the conditions or do you ride with the speedo. needle precisely indicating the prevailing limit, irrespective of other conditions? I'd much rather have too much information on a gauge and make an adult and experienced judgement about ignoring it, than the engine indicate the inadequacy of the o.p. switch/lamp by making a new crankcase vent with the mutilated end of a conrod ... Hth. Regards,
Posts: 5,655 Likes: 112
Posts: 5,655 Likes: 112 |
I know guys would put washers under the relief spring in auto engines.. let's get technical, shimming the stock spring increases preload, does it increase the spring rate as the valve opens?? Shortening the spring slightly and shimming it to original length will increase the spring rate from what I know..
I've had oil pressure gauges on many Triumphs including my race bike. Like Stuart says it takes a bit of riding to heat up the oil and see a pressure drop if the bearing clearances are reasonable.
79 T140D, 96 900M Ducati ,61 A10 .On a bike you can out run the demons.. “But I don't want to go among mad people,” Alice remarked. “Oh, you can't help that,” said the Cat: “we're all mad here. I'm mad. You're mad.
Posts: 31 |
As I mentioned earlier, I have not yet taken a long ride to get it properly warmed up. All I did was run it in the shed for ten minutes. I was not expecting it to get to proper operating temperature, but I did expect at least some drop in pressure. With a good motor recently rebuilt, am I correct in thinking that this is most likely not a problem? All will be revealed if I can get out on it at the weekend. Bike show, Norton rebuild and car to sort first, no rush then?
Hi, All I did was run it in the shed for ten minutes. I was not expecting it to get to proper operating temperature, but I did expect at least some drop in pressure. Mmmm ... I know you're in tropical Cornwall, but I used to live next-door in Devon and I don't recall it being particularly warm in January ...? Bear in mind that not only is the engine radiating heat, so is the large surface area of the oil tank. You might've "expect[ed] at least some drop in pressure" after ten minutes of tickover ... but not seeing it in January is hardly a basis for extrapolating to 'a problem', swapping oprv, fiddling with washers, etc.? You got one of those meat thermometers - gauge on the end of a long spike? If you'd had that in the oil tank filler, the other end reached into the oil in the tank and it was showing 85C, 90C or more, you might've seen the pressure start to fall? All will be revealed if I can get out on it at the weekend. Mmmm ... I wouldn't bank on it even then, depends on the air temperature and whether it warms up before your extremities cool down ...  Fwiw, I normally have three litres of oil in the triples or the T100. When I rode in winter, I used to only put 2.5 litres in. Hth. Regards,
Posts: 31 |
I have a hexagon custom oil tank that will accept a temp gauge from the HD. I will give that a try when I can get the time. 180 to 220F is pretty normal temp. Torrential rain this weekend, also Shepton bike show. Busy on the Commando and T90, god will I ever learn not to take on so many things at once. Probably not! I think 80 psi was just a little ott but 65 I can live with or a while. I will see how it goes and let you know.
