wadeschields
wadeschields
quinten 91
Rohan 65
quinten 13
11,839 Registered Users
2 members (Roadwarrior, bsalloyd), 26 guests, and 66 robots.
#61551 06/23/08 6:27 pm
Dew Offline OP
After 2 winters restoring my BSA, I,m trying to get her running but the bike only runs with the choke completely on. When I open up the choke she falls flat on her face. Whats up?? Air Leak??
Old gas?
Jer
http://www.caferacer.ca
1968 BSA Lightning Cafe
1968 BSA Thunderbolt
1969 BSA Royal Star
1972 BSA Thunderbolt
Are you sure it's totally on, instead of totally off? I don't know how many times I've done that or I've known others to do that. When the cable is pulled (under tension), the choke is off.
Otherwise: Are the balance pipes connected?
Dew Offline OP
Fresh new 93 octane go juice.
Dew Offline OP
Alex, I have the air breathers off so I can see the choke slide. I know what you mean about the confusion. When you say balance pipes, is that the hose between the two carbs? Thanks
Well, the hose between the two inlet ports on the head itself. You can check for air leaks by waving a propane torch (unlit) around the carbs and inlets. If RPMs change solely on the basis of where the propane is, you've got an air leak.
Dew Offline OP
Alex, Thanks for that info. That balance pipe is the original part and it has lost some of its flexibility. I'll check for that air leak. Regarding the choke lever being open/closed,I'm guessing when I see the choke slide covering the intake opening then the choke is in the closed position??
Yes. If you look down the throat of the carb with the throttle all the way open, all you should see in the bore is the needle.
Dew Offline OP
I checked for air leaks around the balance tube and the carb mounting flange and found nothing. It still stalls out when I open up the choke. What should the idle rpm be? I'm scratching my head now on what to look for now.
Moderated by  Jon W. Whitley
