Thanks guys.
Scarey pictures in the other post,I hadn't looked at that until you put the link in.....
I will measure the wire diameter and the overall diameter against the original and check for flatness and make sure that they are sat in the groves.
Luckily I ordered a several sets (from
Tri-Cor) for other bikes so I don't have to remove them to measure. I haven't disturbed the inside circlips; I don't intend to replace those although I could if needed.
CAB
