Topics76,551
Posts784,409
Members12,392
Most Online204 Jul 10th, 2022
Posts: 966 Likes: 5
Posts: 966 Likes: 5 |
Can anyone tell me how tight the lower engine mount bolt should be on a 1970 500? The one that runs laterally across the engine, just behind the sump plug. My laptop has died and I can't read my workshop manual. Am chasing a persistent oil leak in this area. The two steel collars that sit inboard of the lower frame rails seem loose. I can spin them with my fingers. If they are that loose then they aren't bearing on the crankcase and I think the bottom joint is weeping. I know they leak here but mine is pretty bad. Maybe they should spin to prevent chafing the alloy casing? Thanks
'51 C11 in a '54 C10L frame. Back on the road... '70 Triumph Trophy 500. Next on the bench for a refresh! '72 Triumph Tiger 650. Back on the road...
Posts: 10,478 Likes: 45
Posts: 10,478 Likes: 45 |
Hi, Can anyone tell me how tight the lower engine mount bolt should be on a 1970 500? The one that runs laterally across the engine, just behind the sump plug. Nearest I can find in the 'C'-range manual is "Crankcase junction bolts ... 15 lb./ft." or "Crankcase junction studs ... 20 lb./ft." (sic). However, on the T160 (which essentially isn't any different to any other Triumph in this area), "(Engine mounting bolts) Bottom" is "30/35 lb.ft." The two steel collars that sit inboard of the lower frame rails seem loose. I can spin them with my fingers. If they are that loose then they aren't bearing on the crankcase Maybe they should spin to prevent chafing the alloy casing?  Maybe they aren't the correct length? When I built my '69, I measured the actual gap on the bike and made spacers to fit, rather than relying on the accuracy of some Far Eastern machinist without any responsibility for the quality or purpose of the parts. Also, if you make 'em/have 'em made to your measurements, no chance of you bending the lower frame rails when you tighten the stud/nut? Hth. Regards,
Posts: 411 |
I'd just shim them up with washers and tighten the nuts to about 35ft/lbs.
davy
Posts: 1,499 Likes: 37
Posts: 1,499 Likes: 37 |
I'd guess that the principle is identical on a 500 to an OIF 750, in which case the nuts (on T140s it is a stud) or nut (if it's a bolt) have to be tightened sufficiently to clamp the spacers firmly between the frame and crankcase lugs. 35ft/lbs seems a good starting point. If 500s have 7/16" stud/bolt, you should be able to tighten a lot more than that safely.
Posts: 772 Likes: 6
Posts: 772 Likes: 6 |
I know its a Triumph, but surely the engine should not be relying on the engine bolts to keep the oil inside it!
Posts: 966 Likes: 5
It's a single stud with a nut on each end. I gave it a tweak and tightened up one collar. I'll have to shim the other one. The gap is .035" so I don't think I'd get a washer in there.
Thanks for the thoughts.
If the bike has been used with the spacers free to move for some time, chances are they've worn some of the aluminium away from the crankcase lugs, therefore necessitating shims. Normally, if the spacers are free with the nuts slack, just tightening them fully will clamp them up.
Posts: 3,813 Likes: 80
Posts: 3,813 Likes: 80 |
My laptop has died and I can't read my workshop manual. Why I prefer the printed page.
Posts: 411 |
Thanks, It's a single stud with a nut on each end. I gave it a tweak and tightened up one collar. I'll have to shim the other one. The gap is .035" so I don't think I'd get a washer in there.
Thanks for the thoughts. A stainless washer is 46 thou thick so if you loosen both nuts off you should get one in there without too much effort, 11 thou is nothing at that point between the rails. davy
Hi Davy, A stainless washer is 46 thou thick It might be in Oz but that's a weird size. Here in GB, 3/8" and 7/6" i.d. washers - whether stainless or other steel - are punched out of standard 1 mm. (~40 thou.) or 2 mm. (~80 thou.) plate or strip; given how they have to be produced for the producer to make a profit, I'd be surprised if they're different in much of the rest of the world. Regards,
It seems you have a choice between springing the frame rails out 11 thou or so, or clamping them up 35 thou. I'd choose the latter, as long as the crankcase lugs haven't worn significantly (if they have, making up the difference with shims would seem a good way to go).
Posts: 411 |
Hi Davy, A stainless washer is 46 thou thick It might be in Oz but that's a weird size. Here in GB, 3/8" and 7/6" i.d. washers - whether stainless or other steel - are punched out of standard 1 mm. (~40 thou.) or 2 mm. (~80 thou.) plate or strip; given how they have to be produced for the producer to make a profit, I'd be surprised if they're different in much of the rest of the world. Regards, Whatever Stuart, but I'm not about to argue with my vernier caliper on your account. I simply picked a stainless washer out of the box and measured it. 6 thou less would be in the OP's favour anyway. davy
