15% Off Black Friday Sale
Deadstiffcatt
Deadstiffcatt
Big Island, Hawaii
kevin 55
Bry 24
12,333 Registered Users
11 members (gREgg-K, koan58, Steve Erickson, Stuart Kirk, Psychopasta, Hugh Jörgen, BobV07662, NDarwin, Magnetoman, Tridentman, bill50cal), 16 guests, and 34 robots.
Topics76,682
Posts782,987
Members12,333
Most Online204
Jul 10th, 2022
#585986 02/16/15 6:17 pm
Haven't been on here in quite a while, the bikes had to set on the back burner for a while. Anyway I would like to do a few upgrades on my Mark III.
I have no idea how old the rear Shocks are but I know they are shot. Any suggestions on upgrades without breaking the bank?
I have read that switching from a 19" rear wheel to an 18" will improve handling and provide a wider variety of tire choice???
I also need to upgrade my front master cylinder.
All suggestions appreciated!
75 Norton Commando Mark II
75 Penton Mint 400
'72 Ossa MAR
1975 OSSA Super Pioneer
Norton on eBay
rear Shocks are one of those you get what you pay for.
the switch to 18 depends on what you call an improvement but it will give you a bigger selection of tire's
unfortunately with a MKIII if you want to keep the stock switch gear your only option is to sleeve it to 13MM 1/2 inch
windy
72 combat
if it aint broke fix it till it is
switchbackcreek.com
As well as the 13mm sleeve kit mentioned by Bill, Andover Norton sells an upgrade master cylinder which bolts to the existing Mk3 combined throttle housing and switch cluster.
http://www.andover-norton.co.uk/Accessories.htm
[quote=bill50cal]rear Shocks are one of those you get what you pay for.
Any recommendations?
75 Penton Mint 400
'72 Ossa MAR
Ikon or rebuilt Koni's are the best.
Thanks. I was looking on Britcycle.com and found a re-sleeved master cylinder exchange. I might go that route.
75 Penton Mint 400
'72 Ossa MAR
Also, is there anything to stop you using the '79-on Co-op twin master cylinder mounting, and one of the options that'll fit that mounting?
It would be an option to use the '79 Triumph M/C mounting fitted with the 13mm cylinder (as sold by RGM Motors) although an alternative front brake switch arrangement such as a banjo bolt switch would then be required.
Sounds interesting, I didn't know about this option.
75 Penton Mint 400
'72 Ossa MAR
Moderated by  Dave Comeau
