1 members (Tom A65LR),
22
guests, and
13
robots. |
Key:
Admin,
Global Mod,
Mod
Topics76,267
Posts772,160
Members12,154
Most Online151 May 8th, 2022
Posts: 8,071 Likes: 101
Born To Run
Born To Run
Posts: 8,071 Likes: 101 |
Hi All - Getting ready to reinstall my alternator. When I removed the rotor, the stud came out with the nut. Last time I was in here back in 2011, I used a bit of blue loctite on the nut, so I expect that's why the stud came out. I'm going to double-nut the stud and remove the rotor nut but what do I do with the stud: a) Screw it back in to the crank-end finger tight and torque nut per spec? b) Use blue Loctite on the nut AND the stud? c) Double nut the stud and torque it into the crank? d) Some combination of above? Cheers, Steve
'77 T140J Silver Jubilee '82 T140LE TMA Royal ‘69 BSA Rocket 3 (patiently awaiting it's turn) "Vintage Bike". What's in your garage?
Posts: 1,678 Likes: 16
Posts: 1,678 Likes: 16 |
My understanding of studs are that they should just be snugged not tightened or torqued. It's the interference of the threads and the stretch of the stud that does the holding once the nut is torqued to the proper spec. A bit of blue loctite on the stud might keep it from backing out first instead of the nut coming off. But not sure why it would be a concern if it did. If you ever need to remove the stud you should be able to break the bond on the blue with double nutting the stud.
1978 Bonneville T140E 1974 Trident 1970 BSA Thunderbolt 1971 Norton Commando 1972 Norton Commando 1973 Norton Commando 1974 Norton Commando 2018 Kawasaki Z900RS
Posts: 9,093 Likes: 179
Posts: 9,093 Likes: 179 |
I Loctite the sprocket splines, the rotor, the stud and the nut.
It's one of my favourite Loctite areas!
Born To Run
Born To Run
It's one of my favourite Loctite areas! You need to change you sig to "Professional Loctite enthusiast". As an American, I have difficulty discerning between Scottish humor and seriousness...especially with so many tongue-in-cheek posts regarding Loctite! Steve
I wouldn't joke about mechanical queries.
Born To Run
Born To Run
Thank you triton!
(you, too, htown)
Posts: 10,836 Likes: 200
Posts: 10,836 Likes: 200 |
No, really! Can we take you seriously?
Born To Run
Born To Run
WWJD?
(what would John do?)
I am with Triton, except I wouldn't Loctite the splines. (BLUE) or wear a kilt - I would scare too many little children...
Be sure to wash all of the oil from stud and be sure you clean inside the crank and nut. I prefer denatured alcohol, as it is a good solvent for oil based products and isn't as harmful as some of the brake cleaners.
I (probably) wouldn't Loctite perfect splines either, but I've found that slightly worn ones are useable, with Loctite.
Posts: 803 Likes: 15
Posts: 803 Likes: 15 |
I usually loctite the stud in, but doesn't the nut have a lockwasher?
1958 5TA / T100 1965 T120R 1970 TR6 1970 TR6C
Born To Run
Born To Run
Thanks John, et al -
I had planned on wrapping the crank and sprocket with a shop rag and spraying the threads in the crank with brake cleaner. That stuff IS pretty nasty, I'll give the denatured alcohol a go.
tiger cub - yes it has a tab washer that can be bent and locked against the flat of the nut, but using the blue loctite makes that step unnecessary.
Posts: 3,518 Likes: 3
Posts: 3,518 Likes: 3 |
I usually loctite the stud in, but doesn't the nut have a lockwasher? I reckon those tab washers are worse than useless. Loctite works better, with no tab washer. I also put a small amount of blue Loctite between the rotor and the crank.I don't get too serious, but at least wipe the oil off first. You'll get it off with a puller, without much trouble, next time. It's better than having it come loose and rattle around.
Born To Run
Born To Run
Thanks Pete - Ironically enough I was just reading a post of yours that said you can use engine mount nut(s) to double nut the stud (7/16"-20 UNF #14-0304). Didn't feel like futzing with that, so I looked up all the 7/16"-20 UNF nuts on stainlessbits.com and cross-referenced them with my parts book. Found one on the brake torque stay (rear disc #14-1304) and the locknuts used on the directional stems (#14-0404). Lucky for me, I had some spare directional stems with locknuts in my parts cabinet.....job done! :bigt Cheers, Steve
