BritTwit
BritTwit
Kansas City area
Rohan 86
quinten 75
11,846 Registered Users
6 members (C.B.S, rightshifter, Rohan, BikeVice, koan58, Hillbilly bike), 33 guests, and 70 robots.
bon Offline OP
Can Someone please post some pictures of how they mounted their battery boxes or battery platforms behind the gearboxes of their tritons ? I am mounting a t150 triple lump in a featherbed and there is plenty of room between the gearbox and front of the swinging arm for the battery.
Check out some eBay stuff
bon Offline OP
Wot no one ? Ok then , can someone describe how the battery box or platform is held to the frame , i was thinking of welding two brackets on the bottom frame cross member to hold it , any thoughts ?
bon, don't have any pics yet because it's not done, but I'm planning on putting mine under the rear compartment of the seat along with electronics on my narrow bed and T110 special. Crafting sorta a hinged compartment for the whole shooting match.
Billy
Bunch of 60s Bonnies (mostly in pieces), a 46/48 T100 project, a 73 Commando Interstate, 58 Cub, 68 Norton P11 project and one barely started slimline/pre unit Triton
Dug Offline
My solution was a bit like the previous. I had fitted an oil filter behind the gearbox where they normally hang the battery and I have a central oil tank so the best spot I could find was under the seat behind the oil tank. I use a 7ah Gel so its smaller in size than the lead acid. I had to modify my gf seat pan with a cut in for clearance. Its all tight, very utilitarian and took 3 attempts but it fits.... I'll post a pic tomorrow.
One problem I have is the God awful bright yellow Motobatt. I've seen a couple of customs where the battery is fully visible and they're so gawdy your eye zooms straight in on it.
I tried real hard to cover mine as much as possible !
I set mine in place between the tranny/engine mount plates, surrounded by foam padding. It's also a small modern AGM type, so no worries.
I have an aftermarket one on the shelf. I will try to snap a pic and upload it, if you like it I can take measurements.
i know some are integral to the oil tank.....
[email protected]
bon Offline OP
Thanks for the replies, just planning to get all the bracket welding done and don't want to discover too late i need to weld on brackets for a battery tray etc.
I don't want to use one thats integral with the oil tank as i am using a trident engine and need all the room in that area i can get.
Moderated by  GrandPaul
