Upgrade your membership to Premium Membership or Gold Membership or even Benefactor
10% Off Girling at The Bonneville Shop 2/3-2/9/23
by The Bonneville Shop - 02/03/23 6:14 pm
by Morgan aka admin - 02/04/23 2:40 pm
Buy BritBike staff a coffee ☕️ or pint 🍺
by Morgan aka admin - 01/15/23 9:29 am
Benefactor ✅
by Morgan aka admin - 01/08/23 8:38 pm
Fisherman
Fisherman
Tennessee
Lannis 84
DavidP 83
Kev. 34
DavidP 27
Uneasy Rider, Mally, Daveed, 70Triumph, Knight57Corv
12,392 Registered Users
Topics76,551
Posts784,416
Members12,392
Most Online204
Jul 10th, 2022
Today I changed the camshaft bushes on my 69 T100R engine.
The old ones came out using a M22 tap. The new ones went in straight with a homemade drift.
But although the workshop manual says the bushes will have the correct size after installation the camshafts sitting very tight. So I have to ream the bushes.
The triumph manual list a special reamer but I´ve never seen this tool.
It is available from Britcycle but there must be an other way to bring in the right clearance 0.0010" to 0.0025".
What size of reamer will I need? (only metric stuff here at home)
Best regards, Martin
Triumphs on eBay
I think the important thing is that they are line reamed.
I think people use an adjustable reamer but no idea of the size.
I read somewhere recently that a respected expert felt that cambushes rarely wore out so he never bothered changing them as a routine job. (sorry!)
No sorry needed. But my camshaft bushes were worn. It has had too much clearance.
An adjustable will not fit when the bushes are installed.
But I googled and found out that a 13/16" reamer would work. (The search finction of this board didn´t found something...) So I have to make an adapter for the line reaming first I think.
Thank you!
the tool is a ball bearing sized to fit you push it thru , followed by the ream ..with a shoulder on it cut to fit in the first bush then lines up the second bush for a ream with the cutting part , works good
"HOUSTON, WE HAVE A PROBLEM"
I've looked for the tool in the UK, but it only seems to be available in the US/Canada?
Not exactly, the ball is used on the 650-750 twin bushes to size them.
LG all you need to do is make a bushing the o.d. that is the i.d. of the timing side camshaft bearing in the case and an i.d. of the o.d. of the reamer's shaft.You will need a little bit of clearance to allow the reamer to turn in the bushing. The bushing should be a thumb press into the case.
Hello John!
That´s the way I will do it.
I ordered the 13/16" reamer yesterday and when it arrives I will make the bushing.
Regards, Martin
