Bulletin March 14th 2023
Blown Income
Blown Income
La Plata, Md
DavidP 85
kevin 58
kevin 34
12,433 Registered Users
Topics76,759
Posts787,785
Members12,433
Page 3 of 4 1 2 3 4
Yes you connect a car battery but have fuse in place and make sure you do not touch any battery connections to the frame or bike parts, cover them with tape.
Follow TT's instructions when converting 6 to 12V and tape off the spare redundant wires.
How can i test if my Zener diode is working well??
Start the engine and when warm rev the engine with a Volt meter across the battery, the voltage should not go above 14.5V .
Ill use heat shrink (wrote well?)...
I think ive understand TT instructions...
Different language can some times be difficult to figure out what other person want to say/mean...
But ill post any dought that shows up...
Thanks a lot both...
Now im more confident...
Some difulty to understand the differences between headlight main beam and dip beam.
Google translator cant help...
Pilot light is the litle bulb inside the headlight, correct?
So, pilot light = minimum light
Main beam = medium light???
Dip beam = maximum light???
Main beam and dip are two separate filaments inside the big front bulb. Main beam is for seeing in the dark. You switch to dip when you meet a car at night, so as not to dazzle the driver.
Pilot is the tiny bulb.
Hi everyone...
The rectifier arrived today, just now i put on it a cpu heat sink to keep it cooler...
Bought also the fuse case, just need a 20A fuse...
What lamps should i buy for my bike?
On 6v i know witch lamps are, but for 12v i dont have a clue...
Best regards
Sérgio Crespo
Hi everyone...
Ive stoped the final step of restauring my bike for about a couple of months but now it to finish it...
I have all the items i need to do the convertion of 6V to 12V but i have some doubts about conecting cables on the rectifier.
I buyed a small square solid state componet...
Fitted it a heat-sink to help to stay coolled...
This rectifier as 4 conectors...
How can i know witch is what??
Does any one know any other person that as made this convertion or very close to this(in this forum/site or other), so he can help me??
Its the final step but i dont want to blow anything...
Best regards
Sérgio Crespo
One of the 4 terminals will be at 90 degrees to the other 3 and identifies it as being on the DC, cannot remember if its the +ve or -ve but playing with a multimeter will tell you. The other DC terminal is on the opposite side of the 90 degree terminal and the remaing 2 are the AC which connect to the Alternator.
One of the 4 terminals will be at 90 degrees to the other 3 and identifies it as being on the DC, cannot remember if its the +ve or -ve...
Thanks a lot for reply...
This one as + printed on the component...
Im bit noob on electrics but slowly ill go there...
But still a bit confused...
I know its wrong but what i need to change??
Its a positive earth bike unless you have changed this so the rectifier terminal marked + is connected to ground and the -ve to NW.
wak Offline
that drawing isnt right, the offset is positive (earth) the one diagonal to it is negative the other two corners are alternator and it will not work if youre using the original wiring to the switchs as they switch the alternator current.You need the alternator going straight to the rectifier and wire the switchs as simple on off for lights and ignition.
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA Gold Star Daytona
BSA Gold Star Scrambler
BSA Rocket Gold Star
BSA C15S
BSA Cyclone
Triumph T120
Triumph T100 Daytona
Triumph 5TA Trials
Triumph T100 Scrambles
Cheney 560 TT
Hi, thanks for reply...
As my language isnt english, im a bit confused with what you said...
Im using this diagram, same as in ruperts book...
Changing a new original wiring harness...
wak Offline
the diagram is correct, i could not see all off it , but the rectifier is wrong.+ is ground
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA C15S
BSA Cyclone
Triumph T120
Triumph 5TA Trials
Cheney 560 TT
So, like this??
Yes like that.
Thanks a lot, both of you....
Because of your help im closer to finish it to riding it.
Never eard or saw this bike running...
wak Offline
ahhhhhh no !!!!! 12 o/c +,3 o/c alt , 6 o/c - & 9 o/c alt
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA C15S
BSA Cyclone
Triumph T120
Triumph 5TA Trials
Cheney 560 TT
Sorry, you wrote very fast and i dont understand...
What means o/c and the 3,6 and 9?
alt - alternator
wak Offline
12 oclock as in clock face,
ac ac
_
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA C15S
BSA Cyclone
Triumph T120
Triumph 5TA Trials
Cheney 560 TT
So, switch the NW with the WG....
Im not on pc right now to do another picture...
wak Offline
yes
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA C15S
BSA Cyclone
Triumph T120
Triumph 5TA Trials
Cheney 560 TT
Hi there...
The wiring is almost there...
Now i need to buy a 12V battery, but i dont know how much ah it needs...
Can someone tell me the minimum ah i must buy??
Because of the size i need to know the minimum ah so i can search from there...
Best regards
Sérgio Crespo
http://www.ebay.co.uk/itm/YB7-A-Motorcycle-battery-BSA-C15-C-15-247cc-58-71-/150573713139?_trksid=p4340.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D2639769712497759864%26pid%3D100011%26prg%3D1005%26rk%3D2%26sd%3D180773281440%26#ht_1807wt_1398
Thanks....
So 8ah is enough?
Because im trying to buy here in Portugal.
If i cant, from UK...
Page 3 of 4 1 2 3 4
