Topics77,101
Posts793,026
Members12,524
Most Online230 Mar 11th, 2023
Posts: 702 Likes: 1
Posts: 702 Likes: 1 |
I ordered a set of pipes (Emgo) for my 68 Bonnie project and they are not symmetrical. The DS pipe down section goes down 2 inches further before it turns back toward the back of the bike than the TS pipe. The TS pipe also has a slight bend about 6 inches from the end. Is the correct for stock unit Triumphs or do I have a REALLY badly made set?
Thanks, Bernie
'Never argue with an idiot, they'll bring you down to their level, and beat you with experience'
'72 TR6 '12 Hinckley Scrambler '95 FLHTC Road Sofa
Posts: 10,878 Likes: 314
Posts: 10,878 Likes: 314 |
For design reasons Jack Wickes http://tiger100.co.uk/Jack%20Wickes.html didn't originally make these pipe symmetrical. The timing side pipe tucks up under the timing cover and the drive side pipe has to be lower to clear the primary.
Posts: 702 Likes: 1
Thanks John. Do you know if anyone builds a set of 1 1/2" chrome pipes (non-crossover) that are symmetrical?
No, but someone else might. Most symmetrical after market pipes for these bikes are 1 3/4" (Cycle Shack).
Posts: 702 Likes: 1
I found with my BSA that the 1 3/4" pipes without mufflers caused a deep drop out in the midrange. I had to put a small piece of baffle in the pipe and you know how hard it is to keep a baffle in a straight pipe.... The Triumph we built for my son used my old set of crossover pipes from my 72 with the crossover cut off and the holes welded shut and pipe wrap to cover 'em up. That bike ran great without baffles but it was a TR6.
Thanks again.
