Kevin E
Kevin E
Hull, East Riding of Yorkshire, England
Cyborg 69
reverb 63
Cyborg 18
Sinner66, DucatiPete, mk31755, MAM, Jonez69
11,977 Registered Users
11 members (MikeG, htown70, TinkererToo, KevRasen, Gordon Gray, Gordo in Comox, raf940, edunham, triton thrasher, Blown Income, PRO RAD), 35 guests, and 19 robots.
Topics75,253
Posts757,990
Members11,977
machico Offline OP
Just wondering if somebody knows the differences of the steering head bearings between rigid models and swing arm models.
I am planning to fit the yokes for pre unit swing arm models (nacelle model) to the rigid frame. I tried to fit the steering bottom cup for 1955 to the rigid frame but it doesn't fit because the frame side is bigger than the cup. According the factory parts manual, the parts number for the bottom cup is all H111 from 1950 to 1959 so the cup should be fit. I am kind of confused why this happens.
I thought the yokes for swing arm model are able to fits to the rigid frame but.....is it possible?
Do you guys have any advises?
Btw, I also would like to know the differences of the yokes from 1950 to 1959. According to the parts manuals, H695 is from 1950 to 1954. H942 is from 1955 to 1957. H1229 is from 1958 to 1959. They all look kinda same but what's the differences?
macico
Triumphs on eBay
Differences that readily come to mind are the earlier 1950-1954 had 5/16" pinch bolt holes, '55-'57 3/8" pinch bolts and the 1958-1959 models have a slot in th steering stem for a fork lock on the right side of the steering head. These changes are probably the major factor for the part number change.
As for the H111 bottom cup, it should fit your rigid frame too, unless it's a 3T frame. What year is the frame and what model ? Also,the 3T used different cups - XS10 with 22 3/16" bearings.
The top steering cup, 5T,6T,T100 & TR5(H437)fits into the top of the steering head/neck and requires the use of 3/16" ball bearings x 22.
1971 BSA A65 650 - Project
machico Offline OP
I am not sure what year the frame is because I bought the only front section. The prefix on the frame is "TF" so I think the model is 5T, 6T or T100. The seat tube doesn't have the split lug so I think my frame is before 1951. what else should I check to determine the year? If the frame number is original, the number is TF 21337. Do you know what year it is?
As for the bearing cup and the yokes, Thanks so much for the details. I really appreciate it.
macico
I don't have all my stuff to check the numbers, but TF is 1949 or earlier 5T, T100 & TR5. My '47 starts with TF or to be accurate T.F. Looks like your frame is a 1948.
My guess is that you probably have the wrong bearing cup/race.
machico Offline OP
Really? Do you mean that the 1948 cup is different from the cup which is after 1950? How is your '47? I only have the parts books after 1950 so... I can't check the differences...
No, I mean that if you ordered that bearing cup, you may have been sent the wrong cup.
H111 is good for 1946 on up twins except the 3T.It may fit twins from earlier years, but I will have to verify that later.
Maybe a crazy question, but is the old race ( bearing cup ) possibly still in your frame ?
machico Offline OP
I compared the '55 old cup with the '55 new one. I think the cup is right. The Both O.D is same.
No. the old one is not in there.
The O.D of the cup is about 23.20mm and the I.D of the cup housing of the frame is about 23.30-23.95mm. So the bearing cup is too loose to fit. I am not sure but it seems that the cup housing may be damaged? The housing looks good though.
Is this problem possibly happened??
That's a good question, but I can't answer this one for you at the moment as I'm a little far from home right now. Maybe one of the other members can compare measurements for you and help you figure this out.
I would imagine metal could be removed from that area and a slightly larger bearing cup installed for use with another manufacturers front end.
The O.D. of the bottom cup (H411 also know as 97-0111) is 2.0938" or 53.182mm.
Where does the 23.20 dimension come from?
machico Offline OP
I agree. Somebody might machine the frame in the past.
I have to do something about this anyway.
Thank you so much Jon. I appreciate your advices.
Macico
machico Offline OP
I'm sorry about my mistake! The dimension of the O.D. is not 23.20mm but 53.20mm. The I.D.is also wrong. It's not 23.30-23.95mm but 53.30-53.95mm. Sorry about that. Thanks for pointing out.
If it helps at all ...
I have a 1955 5T s/a and a 1948 5T rigid. The headrace cups are the same for both.
G.
https://www.amazon.com/gp/product/B074C7CZYL?ref_=dbs_r_series&storeType=ebooks
Good judgment comes from experience, but the most memorable experiences tend to come from bad judgment!
machico Offline OP
G.
Graham, Thank you so much for the information. it helps.
I think something is wrong with my frame cry
