Ian C
Ian C
South Yorkshire, UK
#288647 12/12/09 11:21 pm
SteveM Offline OP
In a previous thread there was mention of a technical article online that described how to convert the lay-shaft bushings to needle bearings. If anyone has a link to that tech article, I'd appreciate it. I've done a few searches and have found nothing.
I'm also interested in anyone's comments who has experience in incorporating modern lip seals to the outer cover; or whether or not it's reasonably feasible.
Anything from a 1970 4-speed gearbox will fit right into a pre-unit gearbox. The only trouble is driving the speedo, so you use a 1965 layshaft.
Don't hide 'em, Ride 'em !!
RF Whatley
NE Georgia, USA
All the bearings, including the needle races, open and closed end, are available from bearing factors, although you may wish to support your local bike part dealer. Full details of bearing sizes are in Unit Triumph manuals. You have to buy bronze thrust washers from a Triumph dealer anyway.
Oil seals on the kickstart and gear pedal sounds like a lot of work, unless you just glue the seals to the casing, where the original spongey "seals" went on some models.
The shafts are above the oil level and hardly any oil leaks from there on mine, with no seals.
The more modern gearbox versions simply placed an o-ring on the k/s and g/s shafts. As TT said, those shafts are above the oil level and the seal is for "splash" only.
You probably don't want to turn a grove into the k/s shaft to implement a seal or the shaft will simply break there. It would be an easy thing to fit the inside of the k/s cover with a groove for an o-ring which sat directly on the shaft.
Take a look at the standard seal setup from the early 70's and get some ideas.
RF Whatley
NE Georgia, USA
SteveM Offline OP
Thanks for the input. Really appreciate it.
Dave in NV who posts in the Gold Star page has the setup to cut the groove in the cases and install o-rings, in BSA p/unit gearboxes, you could try him. Don't tell him I volunteered him :>
Steve, I have used a BSA b-50 kick start seal on the shift shaft on the triumph. It worked on my 500 with the 5 speed box turned so the shaft was under the oil level.Some covers just need to machine a groove for the seal and some need a small amount of weld.
Tim Joyce
sponsors
[email protected] cycles
Works shocks
Glass from the past
Seems like lots of work here for no real gains ? The original boxes are pretty damn tough to start with, and I can't say I've ever had any issues with leaking bushes (providing those bushes are themselves in reasonable nick.)
As for the bearings ? Why fix what ain't broke ? I've done hundreds of thousands of miles with these, and I've had to rebuild ONE, after it had clocked upwards of 80k under MY @rse - and I have NO IDEA how long before my ownership it had been fettled other than the fact that the bike (Daisy) had been refurbished some 9 years or so before I got her ?
Jus' sayin' is all smile
https://www.amazon.com/gp/product/B074C7CZYL?ref_=dbs_r_series&storeType=ebooks
Good judgment comes from experience, but the most memorable experiences tend to come from bad judgment!
I'm with you on this Graham,I think that many owners of these old bikes,want to set up their bikes to racing spec's and then ride them 40-50 mph ,less than a thousand miles a year. A lot of these "so called" upgrades are talking points only for this kind of use. Then, some of us get along just fine with the bike in standard trim. I'm not putting any blame on anyone,as we all have different reasons for messing with these things. Just sayin' Dick
I'm also with Graham.
The big downfall of the Triumph outer gearbox cover is that there is ZERO oil splashing around out there. If there were, then there would be a lot less green goo sitting there, and a lot fewer rusted shifter springs. laughing
So in order to have a leak with any kind of bothersome regularity, you really have to have a loose k/s shaft bush or you have to lean the bike way on over.
RF Whatley
NE Georgia, USA
If you have the correct tolerance between the kickstart shaft and its bush then you will have minimal oil leakage. As its a steel shaft running on a steel bush they BOTH wear.
I have recently put a new kickstart bush in my box but noticed that the shaft is also worn. It's only a couple of thou but enough to let the oil out.
Of course you could always use the leak as some sort of indicator - when the leak stops it's time to top up the gearbox. grin
"Live the life you love, find a god you trust and don't take it all too seriously"
Pre-units rule!
Mid fifties Triumph T100
SteveM Offline OP
First thanks to all for the info. I should have mentioned that this is not an old bike. I'm building a Triton and may race it with AHRMA if it works out well. I'd like to beef up the old box to some extent where it makes sense and reduce as much lubricant leakage as possible.
