Topics76,060
Posts769,577
Members12,122
Most Online151 May 8th, 2022
Posts: 8,056 Likes: 95
Born To Run
Born To Run
Posts: 8,056 Likes: 95 |
It seems that many people have been having trouble using the search function on these forums (present company included!). In order to try and help, I have put together a short tutorial. I use the search function alot, and while it may leave something to be desired, if you follow a few simple steps, you’ll find your searches much more fruitful. A few things to be sure you always do when searching: • Be sure you are logged in. I have had instances where I’ve used the search and all of a sudden I get the login page. So be sure you’re logged in! • ALWAYS use the advanced search function. It’s available to you as soon as you click on Search. • Select the forum(s) you want to search. Use the CTRL key to select multiple forums. Directly below Keyword Search Terms are three choices: • in subject (Topic heading) • in body (within the post itself) • in subject and body Unless you need to tailor and refine your search, the default setting should be in subject and body. Date Range: Unless you know a specific date, it’s a good idea to allow a wide range to get the results you’re looking for. I almost always use the “Newer than” selection of 3 years. Now that you have all your search parameters in place, it’s time to select what it is we’re looking for. Keyword Search Terms: This is an important step. What you enter here and how you enter it will determine, in large part, how successful your search is. There are a few advanced search functions that I use to get the results I want. They are: +keyword for required keywords. -keyword to exclude posts with a keyword. Quotes (“) around a phrase to search for a phrase. Use a * at the end of the word to match partial words. Let’s look at an example of each: Enter: + BoyerResult: Will return all posts with the word BoyerEnter: - Boyer Result: Will return all posts WITHOUT the word Boyer. Enter: “ Boyer won’t fire” Result: Will return all posts with that EXACT phrase in it. Enter: con* Result: Will return all posts with the word con, conrod, connect connecting, confirm, etc….. If you follow these simple suggestions, I think you’ll be much happier with the results of your search. I have noticed some limitations with the search function when it comes to numbers, special characters, etc…..perhaps these can be addressed by Morgan at some point. If there are any particular search issues you have, list them on this thread and perhaps they can be corrected/changed. I assembled this fairly quickly, so if there are any glaring errors, please bring them to my attention to be edited. Hope this helps, Steve Prince
'77 T140J Silver Jubilee '82 T140LE TMA Royal ‘69 BSA Rocket 3 (patiently awaiting it's turn) "Vintage Bike". What's in your garage?
Posts: 101 |
Thanks Jubee. Juan 1978 T140V 1969 T120R
Posts: 127 |
Hi Jubee, Thanks! Can your post stay on the first page? Just like the "Post a pic"? My short memory lasts only for about 8 hours!  Hein
Triumph Bonneville T140 1978 Yamaha XS 650 Heritage special 1982 (rephased, big bore)
Posts: 5,864 |
From wake up to first beer?
Posts: 127 |
I see that the search tutorial is on the top of page one now! :bigt
Thanks Jubee and/or moderator!
Hein
Posts: 2,602 Likes: 1
Posts: 2,602 Likes: 1 |
Thanks Steve- That's a real time saver !
1983 TR65T Tiger Trail 1983 TSSAV 1983 TSX 1983 TR65 Thunderbird 1982 TR7T Tiger Trail
Posts: 190 |
Steve you a better man than me if you can make this work! What I am searching for is the correct procedure to tention the primary chain on a T140, tried numerous ways by using your advice and I get nothing or a heap of unrelated posts. I have been putting in primary chain adjustment* or primary chain tention* Just can not make it work.
Posts: 2,057 Likes: 78
Posts: 2,057 Likes: 78 |
Gotta spell what you are looking for correctly for a start..."tension".
Posts: 190 |
Sorr Steve I have been trying for 1.5 hours and this is the most difficult search function I have ever come across. Who ever programmed it must have done so just to hurt and fustrate people who are not computer experts. I am trying to search for any info on the "Norman Hyde 12" brake conversion" for T140's as I wish to upgrade my stock unit but can not find anything that resembles the kit on the search. Funny thing I can restore a complete motorcycle to a reasonable standard but can't get this search to work why was it made so difficult?
Born To Run
Born To Run
rf -
I'd try the least common denominator. Search "Norman Hyde" or "Brake conversion", then cull through those posts.....
The sofware does have its limitations....something we have to live with I suppose.
Posts: 196 |
I spent a long time with this search function and I sorry to say its crap. In the end I went to Google and that found it for me on Britbike.com. No problem without fuss now what does that say about the search function ? Rest of site is 10/10 thanks for all the tips etc....kind regards
Posts: 7,707 Likes: 245
Posts: 7,707 Likes: 245 |
Great advice! So why when I do a boolean search for " Boyer +current" do I get a "match" from a thread on chains which only contains the word "currently?!?" Worthless!
Posts: 291 |
While we are complaining about the seach function, I'd like to add that any search engine worth its salt has an option to search for posts by a given user name. It is very handy.
Posts: 494 |
I would also add that if posters would put a subject that was meaningful like "primary chain adjustment" or "no spark" I think the search engine would have a better chance to find meaninful posts when you are looking for similar topics. Subjects like "Help!!" and "Newbie needs info" don't do much from a search results, POV.
respectfully submitted, Rob
Posts: 3,710 Likes: 7
Posts: 3,710 Likes: 7 |
Good point, Rob. I was once searching for info on a conical rear hub and didn't find what I was looking for until I typed "comical" into the search.
Posts: 2,657 Likes: 18
Posts: 2,657 Likes: 18 |
I am struggling with the search feature. I am trying to find threads about diagnosing black spark plugs. I'm sure it has been talked about before, but like I say, I'm struggling with the search feature. I read Jubeeprince's tutorial but no luck. My problem is that my plugs are very black and I'm wondering how to lean my MK11's out. I can't give advice about your AMAL, but was wondering why you are having trouble with the search function. It doesn't seem to matter if I search for MKII, MKii, Mk11 or even MK 11. I get hundreds of results. Maybe you are putting in too many keywords in your search? Although the built-in search function only goes back 5 years, you can always bring up older results using google. Just type in your search string, then a space, followed by site:britbike.com, which will go back further than 5 years, and will even get you the stuff on the Old BritBike Forum. It is surprising how long some of these gents have been passing out helpful yet free advice. For an example, the search parameters in this screen capture shown below, restricting your search only to the Triumph board, and only to posts by John Healy, but asking for the past five years, will bring up 109 hits for "MKII: ![[Linked Image]](http://TR6Ray.zenfolio.com/img/s3/v42/p2423305719-4.jpg) HTH, Ray Ray,
Nice illustration! You should copy and paste it to the Search Tutorial that's a sticky post on this forum!
Steve O.K., Steve, here it is. Your instructions helped me a lot, but sometimes people want a "quick and dirty" example.
Posts: 260 |
I was putting too much and the wrong words in the description. Thanks Ray. I am going to clean the plugs, go for ride at 1/2 throttle , kill the engine and check the plugs. I,ll let you guys know what happens.
Posts: 2,706 Likes: 88
Ride safe today!
Ride safe today!
Posts: 2,706 Likes: 88 |
FYI, i increased search period to max 10 years and the shortest word is 4 characters. Remember to use +before if you use more than one word.
Posts: 484 Likes: 46
Posts: 484 Likes: 46 |
simple, one-word search: "clutch. In forum, Triumph. ie. this one. response:
"We encountered a problem. The reason reported was Database error only visible to forum administrators
Please click back to return to the previous page. "
maybe some help for me?
Posts: 5,856 Likes: 110
Posts: 5,856 Likes: 110 |
I remember that there was a thread on the BSA forum entitled "What is your favorite BSA?". The other day I went looking for it with the Search function. I restricted my search to the BSA forum, specified "in title only" and "newer than 10 years", and entered the keyword "favorite BSA".
The search returned around 200 entries, NONE of which contained "favorite BSA" or "favorite" in the title!
Born To Run
Born To Run
linker - just saw this. perhaps a software/DB glitch that day? worked fine for me.... Steve
Born To Run
Born To Run
The search returned around 200 entries, NONE of which contained "favorite BSA" or "favorite" in the title! Hi Mark - Did you use the quotation marks (") correctly? Here's what happened to me when I forgot one of the quotation marks: Search Screen: ![[Linked Image]](https://i182.photobucket.com/albums/x250/JubeePrince/Badsearch_zpsda18f6e3.jpg) Results: ![[Linked Image]](https://i182.photobucket.com/albums/x250/JubeePrince/BadResults_zps5b3cd3d9.jpg) Like you, I did not get ANY 'favorite BSA' thread.... When I enter the quotation marks correctly: ![[Linked Image]](https://i182.photobucket.com/albums/x250/JubeePrince/Search_zps3c7aab52.jpg) I get what I'm looking for: ![[Linked Image]](https://i182.photobucket.com/albums/x250/JubeePrince/results_zpsee6f95dc.jpg) Try it again!  Cheers, Steve
Posts: 157 Likes: 1
Posts: 157 Likes: 1 |
Read the intro post. Sorry, didn't live up to the title: "A Brief Tutorial...."
Not brief at all. If the purpose of writing is to communicate, then the effort was lost.
73 T140V; 02 Ducati ST4s
Posts: 6,089 Likes: 210
Posts: 6,089 Likes: 210 |
the search function is quirky.
use a lot of trial and error, and separate terms with quotation marks. eventually it will sort-of work for you.
never the first time.
Posts: 306 |
I just can't believe how useless the search FUNCTION is! (And, yes I've read and re-read the tips, and I'm on many other forums which all 'search' well). No reflection at all on the people who build this site, but somehow the back-end just ain't working is it! Try for example searching 'drive chain'. Are we to believe that there are no posts containing those words?
Posts: 306 |
Just did it again, -I got 200 results, but none are about drive chains! Did you check that those 8220 results contained information about drive chains Les? I assume it must be my end... seems weird though.
BTW are we talking about the same thing? -I'm referring to the 'internal' SEARCH function. You've put in a link to an external Google search. ?
Posts: 10,470 Likes: 41
Posts: 10,470 Likes: 41 |
Hi Jools, Try for example searching 'drive chain'. Are we to believe that there are no posts containing those words? (And, yes I've read and re-read the tips, Errrm ... On the Search page, if you click on "Advanced Search Tips" beside "Keyword Search Terms", a small page comes up with three "Tips". The last is, "Use quotes around a phrase to search for a phrase". I just tried "drive chain" (including the quotes) and got the "Your search for '"drive chain"' returned 200 results." message and links to the first 25. Btw, the top message is yours in this thread ...  When all else fails, RTFM?  Hth. Regards,
Posts: 306 |
Thanks Stuart, as you say "RTFM"! I hadn't understood the significance of including the quote marks around the search words, I'd assumed it would pick up either or both of those words if typed without quotes. Now I know. Cheers Jools
