Glencannon
Glencannon
Alanson, MI USA
16 registered members (Boomer), 140 guests, and 58 spiders.
10389 Registered Users
NickL 95
Mori55 88
Triless 86
Rohan 84
reverb 79
btour 69
DavidP 68
691,908 mail-order LSR
Topics68,056
Posts662,200
Members10,389
Page 2 of 2 1 2
Re: A65 Tiiming Side Main Bearing - No Lip [Re: Andy Lorenz] #721168
01/05/18 4:35 pm
01/05/18 4:35 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
Nick, Charlie Barnes made a steel insert for the drive side bearing on triples that wore out the bore. Possibly that could be done for your blown out case. An inside lip (DS) for the bearing and an outside lip (TS) for the case.
Re: A65 Tiiming Side Main Bearing - No Lip [Re: Andy Lorenz] #721170
01/05/18 4:57 pm
01/05/18 4:57 pm
Tridentman Offline
Tridentman  Offline
Implying presumably that when hot the bearing outer moves and even rotates in the crankcase bearing bore?
Re: A65 Tiiming Side Main Bearing - No Lip [Re: Andy Lorenz] #721213
01/05/18 10:35 pm
01/05/18 10:35 pm
Aus
NickL Offline
NickL  Offline
Aus
I see what you mean Dave, thanks for the heads up, I did think about sleeves/inserts of various types but
really the route i'm taking is the easiest way. I didn't even need to 'glue' the broken piece back on as it's
not doing anything anyway. The primary side will be open to crankcase so no need for a seal, like triumph.
I know it doesn't sound (or look) very elegant but it also means that i don't have to farm out more machining
to people i am uncertain about. It took me long enough to get someone who would do the line boring and
counter boring of the timing side, i don't want to push my luck trying to get stepped sleeves made and fitted too.
I've assembled the crank with dummy spacers etc and the old TS bush and all seems OK, so as the new bush
is on it's way i'll carry on with it.
Allan, that engine is long gone and i never had any photo's of the setup. It was straightforward enough though.
If the OD of your needle race is 47mm (normal one to use) the thrust can be made to just slip over it and run
on the machined flat on the crank web. As the race projects into the case the thrust can have a step allowing
the fixings with no interference.
No-one expects the Spanish Inquisition................
Bring in the 'Comfy Chair'
Re: A65 Tiiming Side Main Bearing - No Lip [Re: Tridentman] #721220
01/05/18 11:18 pm
01/05/18 11:18 pm
Aus
NickL Offline
NickL  Offline
Aus
My own paranoia i suppose, but i always shimmed up Triumph mains as well for the same reason.
Plus with the beezer the oil pump is 'tugging' at that bearing.
Page 2 of 2 1 2
