gREgg-K
gREgg-K
Ottawa, Canada
213 registered members (1xfatboy), 1,850 guests, and 554 spiders.
Gus1956, Henry74, Benny, Lou Quirch, Mark Masa
10045 Registered Users
Lannis 152
kommando 112
480,787 mail-order LSR
Topics65,767
Posts635,801
Members10,045
BSA A10 gearbox high rev problems #714358
11/09/17 9:58 am
11/09/17 9:58 am
northern germany
gunnix Online content OP
New poster
gunnix  Online Content OP
New poster
northern germany
Hello everybody
Since I am a newbe in asking questions in a forum, I hope I am doing it right.
If not, please tell me.
I am riding a side car racer based on a BSA M20/A10 with an engine one cylinder, dohc 600cc and approx 65hp at 8500 rpm.
In my A10 std gearbox above 7000 rpm sometimes gears slip out and I am not able to get in any gear.
Sometimes the gear slips out and jumps in again (awefull noise!!!).
Is there anything I can do?
I changed the layshat to goldie type with needle rollers, and the main shaft wit one needle roller and one bush on the drive side side - no change.
The gears itself dont look worn.
Greetings from
Gunnar
Re: BSA A10 gearbox high rev problems [Re: gunnix] #714381
11/09/17 3:06 pm
11/09/17 3:06 pm
Edgewater, Md
Blown Income Online content
Blown Income  Online Content
Edgewater, Md
Gunnar,
I think the best thing you could do would to have the gears undercut. This would keep the gears pulling together while engaged.
1955 BSA Bantam D1 Plunger
1956 BSA A10RR Street and LSR Bike
1961 BSA C15S
1966 BSA spitfire
1969 Triumph T100C
1970 Triumph TR6R
1972 BSA Lightning LSR Bike
1974 Triumph T150V
Re: BSA A10 gearbox high rev problems [Re: Blown Income] #714480
11/10/17 12:44 pm
11/10/17 12:44 pm
northern germany
New poster
New poster
northern germany
Thank you very much for the information.
Is it normal to happen if the gears are not undercut?
Re: BSA A10 gearbox high rev problems [Re: gunnix] #714492
11/10/17 2:24 pm
11/10/17 2:24 pm
Bolton Lancs UK
Andy Higham Online content
Andy Higham  Online Content
Bolton Lancs UK
I don't want to rain on your parade but undercutting an A10 gearbox is almost impossible.
Only the layshaft 2nd and 3rd gears have "dogs" but they are rounded section and locate into rounded blind holes
1955 BSA B31 400cc "Stargazer"
1962 Greeves 200cc "Blue Meanie"
1962/67 Greeves 350cc
1967 Greeves 360cc Challenger
1984 Suzuki GSX1100 EFE "Sorcerers Apprentice"
GM500cc sprint/LSR bike "Deofol"
Jawa 500cc grasstrack
2003 Aprilia RSV Mille "Lo Stregone"
Re: BSA A10 gearbox high rev problems [Re: gunnix] #714493
11/10/17 2:27 pm
11/10/17 2:27 pm
Bolton Lancs UK
Bolton Lancs UK
For racing I would either fit a Nova 5 speed cluster http://www.novaracing.co.uk/ManufacturerBSA.html
or a TTI gearbox http://www.ttindustries.com/bsa_gearbox.html
Re: BSA A10 gearbox high rev problems [Re: gunnix] #714591
11/11/17 2:45 am
11/11/17 2:45 am
Riverside, CA.
noisy norton Online content
noisy norton  Online Content
Riverside, CA.
The real solution is to scrap the BSA box and find an AMC box. Impossible to break.
God rides a Triumph but wishes it was a Norton.
Re: BSA A10 gearbox high rev problems [Re: NickL] #714604
11/11/17 10:17 am
11/11/17 10:17 am
OZ
Triless Online content
Triless  Online Content
OZ
Yep, reminds me of something I once read about the poor old Matchless gearbox........ " designed for a thirty horsepower world and ending up in a sixty horsepower one !"
Re: BSA A10 gearbox high rev problems [Re: gunnix] #714662
11/11/17 9:06 pm
11/11/17 9:06 pm
Bolton Lancs UK
Bolton Lancs UK
Years ago I used an AMC gearbox on a sprint bike, supercharged (28psi) 500cc Weslake speedway engine and a 6,5" wide rear slick. First drop of the clutch would bend the gearbox mainshaft making the clutch run out by about 2mm. subsequent runs would sometimes pull it straight, it never went worse
Re: BSA A10 gearbox high rev problems [Re: gunnix] #714724
11/12/17 11:17 am
11/12/17 11:17 am
Edgewater, Md
Edgewater, Md
I've done 118 mph in Ohio and just over 120 mph at Bonneville with my A10. I have the scrambles ratio box fitted and have not had a problem at high speed with it jumping out of gear. The Nova 5 speed box's are great but do cost a lot. You may want to check the current setup on your gearbox to make sure you do not have excessive play on the mainshaft, the bearing may be worn out causing too much "end float" allowing top gear to not fully engage.
1961 BSA C15S
1966 BSA spitfire
1969 Triumph T100C
1970 Triumph TR6R
1974 Triumph T150V
Re: BSA A10 gearbox high rev problems [Re: gunnix] #714826
11/12/17 9:41 pm
11/12/17 9:41 pm
Bolton Lancs UK
Bolton Lancs UK
Racing sidecars are brutal on gearboxes, when drifting around corners the tyre is slipping and gripping which puts shock loads into the gearbox
Re: BSA A10 gearbox high rev problems [Re: gunnix] #714846
11/13/17 12:29 am
11/13/17 12:29 am
Edgewater, Md
Edgewater, Md
I could see that, straight line racing we dont really have the side loading. I guess the best plan of attack would be to upgrade to the Nova 5 speed box.
1961 BSA C15S
1966 BSA spitfire
1969 Triumph T100C
1970 Triumph TR6R
1974 Triumph T150V
Moderated by  Allan Gill
