Hortons Norton
Hortons Norton
California U.S.
36 registered members (AML), 145 guests, and 116 spiders.
10389 Registered Users
NickL 96
Triless 87
Mori55 85
reverb 79
DavidP 72
btour 67
691,474 mail-order LSR
Topics68,055
Posts662,181
Members10,389
Page 2 of 2 1 2
Re: Restoring (to a point) my '68 BSA Spitfire Mk4 [Re: David Kavanagh] #718103
12/08/17 1:59 am
12/08/17 1:59 am
gavin eisler Offline
K70s were period tyres. similarly period are Dunlop TT100s ( AKA , K181), if I had the choice I would use TT100s. 40 years ago TT100s were a much better tyre than K70s.
Re: Restoring (to a point) my '68 BSA Spitfire Mk4 [Re: David Kavanagh] #718117
12/08/17 12:26 pm
12/08/17 12:26 pm
Illinois
Spitfire Ken Offline
Illinois
SORRY I DO NOT HAVE A PICTURE BUT LOOK GOOGLE SEARCH PETCOCK 23-1077 https://www.google.com/search?q=PETCOCK++23-1077&ie=&oe=
I HAVE USED THESE ON MY 66 SPITFIRE, THEY WORK WELL, LOOK VERY CLOSE AND ARE LESS MONEY THAN MOST OF THE ONE THAT HAVE A SIMILAR APPEARENCE. YOU WILL NEED TO USE A BUSHING WERE THEY MATE TO THE TANK.
FYI THE 66-68 SPITFIRE DID NOT USE PUSH PULL TYPE PETCOACK. THE PICTURE OF THE ONES YOU POSTED ARE CORRECT.
I APOLOGIZE FOR THE USE OF CAPS. I CAN ONLY TYPE WITH MY RIGHT HAND SO USING THE SHIFT KEY IS BEYOND MY CAPABILITES.
The Devil is in the details.
1957 BSA A10 Spitfire Scrambler (numbers matching, very correct, very nice condition)
1965 BSA A65 Lightning Rocket "Clubman" (restored)
1966 BSA A65 Spitfire MK-II (restored)
1967 BSA A65 West Coast Hornet (under rstoration)
2001 Kawasaki W650
Re: Restoring (to a point) my '68 BSA Spitfire Mk4 [Re: David Kavanagh] #718138
12/08/17 5:03 pm
12/08/17 5:03 pm
Draper, Utah
F
Fullminator Offline
Fullminator  Offline
F
Draper, Utah
Dave, very nice bike find! I restored a 1966 Spitfire that was in a little worse shape than yours when I started. I tried using the fiberglass tank, just like yours, after sealing with the Caswell epoxy system. This worked for about a year. I have about 300-400 miles on the bike now. The tank started leaking at the seam between the top and the bottom pan. I ordered a Brooklands style alloy tank from Holtworks. (already mentioned in this thread by Andy Higham). Getting this new tank took over a year. I am in the process of painting it now. The bike has been sitting; I am anxious to ride the bike again. I also did a timing side bearing conversion, which seems to work well. Before I ride it again I want to install an oil filter kit. I am thinking one of the same type that is used on the Norton Commandos.
+1 to Spitfire Ken, about the petcocks. Your picture shows the same ones that came with my 66. I am sure they are originals, and very cool looking. Unfortunately mine were broken beyond repair, so I opted to replace with the BAP ones. If you can repair yours to make them serviceable I would definitely do it.
This forum is a wellspring of knowledge and good advice. Most any question will receive a smattering of ideas to solve it.
I wish you luck with your Spitfire.
Fullminator
Page 2 of 2 1 2
