Simonofsweden
Simonofsweden
Gothenburg/Stockholm, Sweden
28 registered members (Andrew Dunham), 171 guests, and 382 spiders.
MackenzieBM, Metisseguy, Justintimeclark, Tim Pedder, blayde54
10481 Registered Users
NickL 100
franko 86
Triless 69
751,679 mail-order LSR
Topics68,883
Posts670,980
Members10,481
Tire pressure for Avon SuperVenoms-- TR6 #99853
09/01/06 12:30 am
09/01/06 12:30 am
Florida
F
Florida TR6 Offline OP
F
Florida
Just put on a set of Avon Super Venoms. Given the great difference in tread and tire design between the original K-70 Dunlops and Super Venoms, do the original factory inflation recommendations still hold true for the Avons? If not, does anyone have any recommendations. Thanks.
"For every problem, there is a solution that is simple, neat, and wrong." H.L.MENCKEN
'06 T100 Bonneville
'70 TR6 Bitsa, Pazon EI
Re: Tire pressure for Avon SuperVenoms-- TR6 #99854
09/01/06 1:21 pm
09/01/06 1:21 pm
Winston-Salem N.C.
D.W.R. Offline
D.W.R.  Offline
Winston-Salem N.C.
I have found that the more modern tires require a bit more air than the old stuff. I generally arrive at a figure through experimentation. On my Rocket 3 I run 30 lbs front and 32 rear, on the 66 A65 I run 28 and 30. The higher pressures have also alowed me to eliminate the rim locks on the rears. The old K70 type pressures in AM18's will make them run quite hot, warm tires = good, hot tires = bad.
71 A75
66 (mostly) A65
72 B50MX
??441 highly modified dirt basher
71 Rocket 3
72 B50 MX
66-71 A 65 Bitsa
96 Trident 900
Re: Tire pressure for Avon SuperVenoms-- TR6 #99855
09/01/06 1:46 pm
09/01/06 1:46 pm
Austin, TX
Redden68 Offline
Redden68  Offline
Austin, TX
Do you like the SuperVenoms? What sizes did you get and what are you running them on? I'm looking at tires for my 68 Bonneville.
68 Bonneville
Re: Tire pressure for Avon SuperVenoms-- TR6 #99856
09/01/06 9:12 pm
09/01/06 9:12 pm
Florida
F
F
Florida
"Do you like the SuperVenoms? What sizes did you get and what are you running them on? I'm looking at tires for my 68 Bonneville."
Have only put a few miles on them. Lots of good stuff on other post re: them. BTW, got a great price and quick service from Cyclespot.com.
D.W.R.: Thanks for the info. on inflation pressure. Kinda thought that the old factory settings were too low for a modern tire.
'06 T100 Bonneville
Re: Tire pressure for Avon SuperVenoms-- TR6 #99857
09/01/06 10:59 pm
09/01/06 10:59 pm
Melbourne Australia
Tiger Offline
Tiger  Offline
Melbourne Australia
Good tyres.
A 100/90-19 will go on the front of '68 and later bikes but will slow the steering a little compared to the 90/90-19, you get a little more ground clearance though and Hagon makes 15mm longer shocks to sharpen steering a little and further improve ground clearance.
A 110/90-18 is about the largest you will practically get on the rear without clearance problems.
I am using a 100 width AM18 at the front and 110 AM21 at the rear, dunno if I would use a super venom at the rear, compound may be a little soft and there is certainly nothing wrong with the '21 if allowed to warm before getting aggressive.
32 PSI front and 34 rear.
1969 TR6R
