Ob1quixote
Ob1quixote
Charleston SC
207 registered members (1xfatboy), 1,885 guests, and 584 spiders.
BosBSA, Ron 1973 TR7RV, barnett468, dohck4, Pascal Di Marco
10028 Registered Users
Lannis 146
Stuart 63
475,357 mail-order LSR
Topics65,693
Posts634,978
Members10,028
wiring diagram & suggestions #98034
08/08/06 12:23 am
08/08/06 12:23 am
west central ohio where all be...
drp Offline OP
drp  Offline OP
I have a friend who is building a triumph chopper. He is considering using a new ARD mag and would prefer not to run a battery. What should he consider using in the charging system to run headlights, brakelights, etc and does anyone have a simple wiring diagram for a batteryless magneto bike.
Re: wiring diagram & suggestions #98035
08/08/06 4:17 am
08/08/06 4:17 am
Anonymous
Unregistered
Anonymous
Unregistered
I've decided how to fund my retirement. I will manufacture in Singapore a chrome-plated billet engine-turned magneto housing that attachs in the proper place, and holds your lunch but doesn't interfere with the engine. It will cost only 75% as much as a magneto, and I will sell 10,000 of them.
Can you guess where I'm going?
Re: wiring diagram & suggestions #98036
08/08/06 8:48 am
08/08/06 8:48 am
Melbourne Australia
Tiger Offline
Tiger  Offline
Melbourne Australia
The Indians produce a diesel bullet, that dispenses with the issue completely laugh
1969 TR6R
Re: wiring diagram & suggestions #98037
08/08/06 9:32 am
08/08/06 9:32 am
Halifax, Butt end of Europe
andrewinpopayan Offline
I saw some pics a looooong while ago of an Norton ES2 fitted with a Lucas/CAV injector pump instead of a magneto and it was piped up to an injector instead of a sparkplug!
Should be economical to run and have plenty of torque, an electic-less bike smile
99% of carb problems are electrical.
1959 3TA
BMW R1150 Oilhead
Re: wiring diagram & suggestions #98038
08/08/06 10:16 am
08/08/06 10:16 am
Melbourne Australia
Tiger Offline
Tiger  Offline
Melbourne Australia
Sorry for the humour DRP but I guess the point is that the magneto is long dead and pretty much unmourned by those who had to use and work on the bloody things, the idea of hanging a maggy off the timing side of a Triumph is a hoot.
1969 TR6R
Re: wiring diagram & suggestions #98039
08/08/06 10:18 am
08/08/06 10:18 am
Flint, Michigan
sbolton Offline
sbolton  Offline
Flint, Michigan
Put on a typanium unit simple 4 wire connection, add a capacitor, and run a hot wire from batt to switch. Should do the trick
1969 Triumph T100c chopper
1972 Triumph Tr6r chopper, N the works
Re: wiring diagram & suggestions #98040
08/08/06 2:46 pm
08/08/06 2:46 pm
Arizona Territory
Riff_Raff Offline
Riff_Raff  Offline
Arizona Territory
Copied & pasted from another thread. You can run batteryless with either a Mity Max or a Tympanium w/capacitor. Chopperheads can appreciate how mags look, but usually avoid using them anymore due to the aggravation. It's your call.
***For + ground...
Components for ignition system:
3 Position Ignition Switch
Mity Max
2 Coils
2 Condensors
One 15-20 amp in-line fuse
2 Green Wires on Mity Max > 2 Alternator Wires
Red Wire on Mity Max > In-line Fuse > To Ground on Frame
Black Wire on Mity Max > Battery Terminal of Ign. Switch
2 Points Wires > 2 + Terminals of Coils (one to each)
2 Condensors > + Terminals of Coils (one each) > Condensors Grounded to Frame
Jumper Wire Between 2 - Terminals of Coils
One wire from one - Terminal of one Coil (already jumped) > Ign. Terminal of Ign. Switch
Lighting system is easy as well, but this should get you fire-up.***
Alternate options:
You can run one dual tower coil w/one condensor (rule of thumb being one condensor per coil)
You can substitute a Tympanium in place of the Mity Max by adding a capacitor. (Mity Max has it's own internal cap) Just wire the cap in as if it were a battery. There ARE "flickering lights" issues at low rpm when running batteryless, but if your rotor/stator are in good condition, this issue becomes lessened.
"Factory Stock Is A Suggestion Only"
