Dave Beef
Dave Beef
Great Britain
22 registered members (Alan_nc), 189 guests, and 61 spiders.
10389 Registered Users
NickL 95
Mori55 88
Triless 86
Rohan 84
reverb 79
btour 69
DavidP 68
691,951 mail-order LSR
Topics68,056
Posts662,208
Members10,389
70 65L Leg removal #9216
03/20/06 4:05 pm
03/20/06 4:05 pm
dt34 Offline OP
dt34  Offline OP
Do I need special tool 61-3824 to remove the legs from the triple trees?
Re: 70 65L Leg removal #9217
03/20/06 5:42 pm
03/20/06 5:42 pm
Finland
tombeau Offline
tombeau  Offline
Finland
Hi DT,
If its tight on the taper:
Get an old fork top nut (or sacrifice one to justify a shiny new set)
Grind off the corners until it will go through the hole in the yoke.
Grind a couple of slots in it so you can get a spanner on it and screw it into the fork leg all the way in.
You can then smack merry hell out of it with a hammer and not worry about the threads, until the leg loosens.
The nut can later be used to fabricate the tool for drawing the leg back into the yoke:
Drill a hole in the top and get a bit of threaded rod and a few nuts.
2 to lock it at the bottom. Use something like a big socket placed on the fork leg to pass the threaded rod through.
When you tighten the nut it will draw the leg up into the yoke. I'm about to do mine this week will try and take some photos.
Hope this helps.
Tombeau
Re: 70 65L Leg removal #9218
03/20/06 7:23 pm
03/20/06 7:23 pm
dt34 Offline OP
dt34  Offline OP
Thanks Tombeau I'll give that a shot. If you get a chance to snap some photos that would be great. I need to get the trees and headlight ears painted to I figure I should probably rebuild the forks while at it. I'm sure I'll have more questions as I move along.
Dustin
Re: 70 65L Leg removal #9219
03/21/06 7:57 am
03/21/06 7:57 am
Saltspring Island BC Can
B4450Paul Offline
B4450Paul  Offline
dont mutilate , just back nut off 2turns , hit with soft hammer .
use a foot of broom handle screwed in to pull back up .
paul
Re: 70 65L Leg removal #9220
03/21/06 9:56 am
03/21/06 9:56 am
Melbourne Australia
Tiger Offline
Tiger  Offline
Melbourne Australia
And when it comes time to unscrew the seal holders from the sliders do as follows:
Clean the seal holders squeaky clean, wrap a piece of new radiator hose or similar around the seal holder, down low where it is solid, [down near the thread] and fix this in place with a good quality worm drive hose clamp.
You can then use stillsons [a pipe wrench] on the worm drive clamp to unscrew the seal holder.
Saves one service tool [that silly peg spanner] and does a better job, cannot mark the seal holders.
Thank the man who told me.
1969 TR6R
Re: 70 65L Leg removal #9221
03/21/06 10:07 am
03/21/06 10:07 am
Finland
tombeau Offline
tombeau  Offline
Finland
"Thank the man who told me."
Likewise.
Tombeau
Re: 70 65L Leg removal #9222
03/21/06 2:08 pm
03/21/06 2:08 pm
dt34 Offline OP
dt34  Offline OP
Thanks guys for all the help
Dustin
Re: 70 65L Leg removal #9223
03/21/06 2:56 pm
03/21/06 2:56 pm
Finland
tombeau Offline
tombeau  Offline
Finland
There we go. Pic of two "not so special service tools" as approved by users of Britbike.com.
...and yes that is snow.....still!
Cheers, Tombeau
Re: 70 65L Leg removal #9224
03/21/06 11:29 pm
03/21/06 11:29 pm
dt34 Offline OP
dt34  Offline OP
No Pic, red x
Re: 70 65L Leg removal #9225
03/22/06 6:12 am
03/22/06 6:12 am
Finland
tombeau Offline
tombeau  Offline
Finland
Re: 70 65L Leg removal #9226
03/22/06 6:42 am
03/22/06 6:42 am
australia
beezagrot Offline
beezagrot  Offline
australia
another way to remove the fork legs is to remove headlight,handlebars,steering dampner,top tree pinch bolt & top fork nuts then give the top tree a good whak with a rubber mallet from the under side.seems like a bit of work but hey,ya might as well check your steering head bearings if your gonna pull your forks off.just make sure the forks are supported from below when removing the tree or your front end will drop down through the the steering head & may tickle your toes or worse, do avoidable damage to bits you would rather not have to repair or replace.good luck.
Re: 70 65L Leg removal #9227
03/24/06 5:15 pm
03/24/06 5:15 pm
dt34 Offline OP
dt34  Offline OP
Well I got one off without a problem but the other one is not coming off. I have been trying for 2 days with no luck. I tried letting it soak in liquid wrench but that doesn't seem to work. Should I try heat?
Dustin
Re: 70 65L Leg removal #9228
03/25/06 5:06 am
03/25/06 5:06 am
Eastern Ontario
Costa Z Offline
Costa Z  Offline
Eastern Ontario
The stanchion has probably rusted itself to the bottom fork yoke. You could try to open the hole in the bottom yoke slightly, and tap from the top again. Otherwise, you'll have to dismantle the fork leg in situ, remove the top yoke, as described above, and remove the stanchion from the bottom yoke on the bench (a brute force approach might involve a large vise, a block of wood and a large mallet, for example...)
Costa
Re: 70 65L Leg removal #9229
03/25/06 4:06 pm
03/25/06 4:06 pm
Mississauga, Ontario.
Adam M. Offline
Adam M.  Offline
This is what I always do - opening the hole in the bottom yoke with the big screwdriver and tap or whack from the top - allways worked.
Adam M.
