old-grizz
old-grizz
the wilderness
16 registered members (Allan Gill), 195 guests, and 392 spiders.
Mom1, flyntone, RNORTON, Gregg's Atv, T160vUK
10446 Registered Users
NickL 66
Jeff K. 59
DavidP 58
732,008 mail-order LSR
Topics68,565
Posts667,707
Members10,446
Shindengen Regulator/Rectifier #88253
02/16/06 12:12 am
02/16/06 12:12 am
australia
tiger_cub Offline OP
australia
Hi All,
Can anyone help with the wiring of a Shindengen reg/rect unit, type SH532-12 2.2. It was fitted to a Cub a while ago, but was disconnected. There are three yellow wires, one red wire which goes to a ballast resistor (to coil??), one green and one black wire, which have been joined together. I guess one of the wires must go to earth (ground), hopefully someone will have knowledge of Jap electrics to help me with this. Thanks.
1970 TR6C
1970 TR6R
Re: Shindengen Regulator/Rectifier #88254
02/16/06 3:00 am
02/16/06 3:00 am
Mississauga, Ontario.
Adam M. Offline
Adam M.  Offline
Yea, the good one - I used to have 3.7 version on my Suzuki GS 1150 EFE. Way better than original Suzuki.
Red wire takes power to ignition switch, a green one is a ground, the thin black should be connected to another "hot" wire ( lights or horn ). this wire actually sets your charging on the 14.5 V level, when it`s disconnected you can get 20 V and more.
Three yellow wires connect your alternator to the regulator rectifier, but it has to be 3 faze alternator.
Adam M.
Re: Shindengen Regulator/Rectifier #88255
02/16/06 8:10 am
02/16/06 8:10 am
australia
australia
Thanks very much for that info. It was definately working previously, wired up to a Lucas alternator, not a 3 phase one, but not by me. Should I just connect to two of the three yellow wires and hope for the best or join two of the yellows together?? Is the ballast resistor really necessary....
1970 TR6C
1970 TR6R
Re: Shindengen Regulator/Rectifier #88256
02/16/06 10:37 pm
02/16/06 10:37 pm
Adam M. Offline
Adam M.  Offline
I`m no electritian, and am no sure about it.
Looks like it should work, but I would just use correct Podtronic, or any other one faze reg / rec.
Adam M.
Re: Shindengen Regulator/Rectifier #88257
03/03/06 1:54 am
03/03/06 1:54 am
australia
australia
Just a thought based on the above feedback - aren't all RM alternators three phase output, so I should just connect the three output wires to the three yellow wires. If I had an alternator with two output wires, I would just join two of the yellow wires together. Should work???
1970 TR6C
1970 TR6R
Re: Shindengen Regulator/Rectifier #88258
03/03/06 4:31 am
03/03/06 4:31 am
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
If I understand this correctly, the 3 yellow wires are for AC input from the alternator (standard Jap color code for AC). If you have the 1-phase Lucas alternator you'll connect to ANY 2 of the yellow wires to your alternator and leave the third yellow wire unconnected and insulated from all other wires.
It sounds as if the unit is capable of positive or negative ground, depending on what you do with the red and black, but that's pure conjecture on my part.
:bigt:
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: Shindengen Regulator/Rectifier #88259
03/05/06 11:15 pm
03/05/06 11:15 pm
Arizona Territory
Riff_Raff Offline
Riff_Raff  Offline
Arizona Territory
May or may not be helpful, but found these in some notes on Japanese 5 wire reg/rect's.
"If you have a 3 wire stator, connect to the 3 yellow wires. Red wire goes to - term. of battery & other color goes to Ground."
"There's also a company called Electrix USA that sells aftermarket reg/rect, Part # RR40 ? They also make one for a 2 wire stator."
"Factory Stock Is A Suggestion Only"
