The Bonneville Shop
CaptainPugwash
CaptainPugwash
Conisbrough,Yorkshire, UK
22 registered members (Alan_nc), 205 guests, and 434 spiders.
10528 Registered Users
franko 90
NickL 66
785,121 mail-order LSR
Topics69,220
Posts674,261
Members10,528
frame interchangability. A7-A10?? #8414
02/25/06 4:02 am
02/25/06 4:02 am
hamden, ct.
hacksaw Offline OP
hacksaw  Offline OP
hamden, ct.
i beleive some A7 frames wil accept A10 engines, but dont know how far back. and the same with tranys. are there differences for plunger and swing arm frams?
any insights?
Re: frame interchangability. A7-A10?? #8415
02/25/06 6:14 am
02/25/06 6:14 am
Saltspring Island BC Can
B4450Paul Offline
B4450Paul  Offline
all A10 frames are marked A7 .
very early twins the gearbox bolted to back of engine , other than that ,think you can mix and match away.
Re: frame interchangability. A7-A10?? #8416
02/25/06 4:44 pm
02/25/06 4:44 pm
North East England
beezageezauk Offline
North East England
Hi Hacksaw,
The swinging arm A7 and A10 engines are interchangeable in the swinging arm frame. As Paul says all these frames started with an A7 number. The only exception to the rule was that a genuine Rocket Gold Star frame started with an A10 number and the S/A engines would also slide into those frames with no problems.
The plunger A7 and A10 engines are also interchangeable but only in the plunger frames. Again, all these frames begin with an A7 number.
I have seen swinging arm engines in plunger frames and plunger engines in swinging arm frames but it is not a straightforward job to fit them. You would at least need to make your own engine plates for a mix and match project like this.
The swinging arm frames were available in 1955 and ran side by side with the plunger framed models until the plunger frames ended in 1957, so there was a 3 year period when both plunger and swinging arm models were available.
The plunger gearbox can not be matched up with a swinging arm engine and the swinging arm gearbox can not be mated with the plunger engine. There are too many differences between the two types of gearbox.
One other point to mention is that the S/A A7 and A10 engines will also fit into the B31 S/A frames but the B31 and B33 engines will not fit into the S/A A7 frames. Hope that this answers your question. Beezageezauk.
