roadrocket
roadrocket
cork ireland
32 registered members (AML), 162 guests, and 49 spiders.
10383 Registered Users
NickL 96
Mori55 88
Stuart 77
reverb 76
DavidP 72
Triless 71
Rohan 69
btour 66
689,569 mail-order LSR
Topics68,028
Posts661,839
Members10,383
length of push rod for AMC gearbox and clutch #76337
08/28/08 5:30 am
08/28/08 5:30 am
Victoria Australia
bmckeegan Offline OP
Victoria Australia
is anyone able to provide details of the length of the push rod (clutch thrust rod) for an AMC gearbox with a 5 plate clutch?
cheers
Brendan
Re: length of push rod for AMC gearbox and clutch #76338
08/28/08 12:19 pm
08/28/08 12:19 pm
Hamilton, Mass. USA
Dave Comeau Offline
Crew Chief
Dave Comeau  Offline
Crew Chief
Hamilton, Mass. USA
The clutch pushrod length depends on which clutch you use. commando (7-9 plates) or coil spring (? plates)
added:
commando 9-26/32"
atlas 9-22/32"
dynodave
BSA 3 1961-1963
Ducati 3 1992-2002
Norton many 1951-1975
Re: length of push rod for AMC gearbox and clutch #76339
08/28/08 4:03 pm
08/28/08 4:03 pm
Melbourne australia.
spook Offline
spook  Offline
Sounds like I have to make a longer one. See you on the weekend.
Re: length of push rod for AMC gearbox and clutch #76340
08/28/08 5:05 pm
08/28/08 5:05 pm
FRANCE- DINARD -BRITTANY
marinatlas Offline
marinatlas  Offline
Hi , if you need a longer one , why don't you add any 1/4" balls (you cut your actual pushrod in the middle and add it /them into the mainshaft), it could help.
Re: length of push rod for AMC gearbox and clutch #76341
08/29/08 8:39 am
08/29/08 8:39 am
belgium
ludwig Offline
ludwig  Offline
belgium
I use : a rod length of +/- 20 cm , than a 1/4" bearing ball , and the last 3-4 cm (clutch side) rod is made out of a 6.8 mm drill shaft . (6.8 drill bits are very common in a metric world )
This short piece of rod is made to a perfect sliding fit and can easily be removed to be ground to the correct length . It effectivly stops gear oil migrating . I have this setup long before DD's CRS was available .
Re: length of push rod for AMC gearbox and clutch #76342
08/30/08 6:33 pm
08/30/08 6:33 pm
Sweden
AndersA Offline
AndersA  Offline
Sweden
Ludwig, now you made my day!
This proves my theory "never ever throw anything away" ,an old broken drill may come in handy some day!
Do you do anything with the shaft or will it be oiltight enough as-is ?
Re: length of push rod for AMC gearbox and clutch #76343
08/31/08 1:25 pm
08/31/08 1:25 pm
belgium
ludwig Offline
ludwig  Offline
belgium
It won't just fit in . The hole in the mainshaft is not machined . You have to hone and polish it to make a perfect fit . I think I used valve grinding paste and polish . (can't remember , its been too long )
this is how it looks after a 3000 km trip :
I dindn't clean it up . there is no trace of oil seepage . The length of the tip is such that the felt ring exactly fills the gap between mainshaft and adjusting bolt . Felt ring is more to keep the tip lubricated than to keep oil in .
Re: length of push rod for AMC gearbox and clutch #76344
08/31/08 4:50 pm
08/31/08 4:50 pm
Sweden
AndersA Offline
AndersA  Offline
Sweden
Thanks Ludwig!
IŽll do this mod to my quaife box this winter.
Moderated by  Dave Comeau
