BrianL
BrianL
Bellaire, TX, USA
35 registered members (AndyB), 223 guests, and 411 spiders.
10418 Registered Users
btour 89
Triless 76
reverb 75
710,281 mail-order LSR
Topics68,305
Posts665,031
Members10,418
front wheel bearings Atlas/commando #75648
07/04/08 3:57 pm
07/04/08 3:57 pm
Southeast Usa
Bigtwin Offline OP
Bigtwin  Offline OP
Southeast Usa
Hi! I have acquired a Norton Front hub with a double leading shoe front brake, but no wheel bearings or axle are present. Does anyone have a bearing number ( or dimensions for interchange) that might be available at a local (US) bearing supplier? Otherwise a suggested source mail order? Since I am out in the sticks, my local tractor shop has been really good at cross referencing odd bearings/bushings. Any info/ideas appreciated!!!
Thanks!
Bigtwin
Re: front wheel bearings Atlas/commando #75650
07/04/08 4:26 pm
07/04/08 4:26 pm
Ron Leisner Offline
Ron Leisner  Offline
Bearing numbers are
6203 17 X 40 X 12 Single Row Deep groove Ball
4203 17 X 40 X 16 Double Row Deep Groove Ball
The single row is easily found in sealed, but not the double row. There is a slightly wider sealed double row that requires the bearing spacer to be machined first.
Ron L
1973 MkV 750 Roadster
1974 850 Interstate
1975 850 Cafe Racer
1968 750 Fastback
1967 P11
1969 Ranger 750
Re: front wheel bearings Atlas/commando #75651
07/04/08 5:52 pm
07/04/08 5:52 pm
Southeast Usa
Bigtwin Offline OP
Bigtwin  Offline OP
Southeast Usa
Hi & thanks for the info!
I do not have the internal spacer either, so I may have to make both an axle & internal piece. I like the idea of going to the wider shielded bearing.
Thanks again!!!
Bigtwin
Re: front wheel bearings Atlas/commando #75652
07/06/08 12:32 am
07/06/08 12:32 am
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
BT -
I have fitted the wider bearing by trimming the spacer myself. Just so you fully understand, the wider bearing is simply wider, not any stronger. The only advantage is in availability.
You'll want to spec all your wheel bearings as "double sealed" NOT "shielded". There's a big difference between the 2.
The 3 bearings in the rear wheel are in an inch size (if I remember correctly), but can still be had "sealed".
bigt
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Moderated by  Dave Comeau
