Jeff23
Jeff23
Connecticut
18 registered members (Alan_nc), 189 guests, and 382 spiders.
Gtommy, Stew Dempsey, JoeBrown, Bart223, Duckster
10175 Registered Users
Lannis 102
reverb 89
koan58 68
L.A.B. 54
554,066 mail-order LSR
Topics66,604
Posts645,479
Members10,175
Another " dumbest " question...... #73855
03/09/08 11:45 am
03/09/08 11:45 am
Dordogne, SW France
johnnyrvf Offline OP
Dordogne, SW France
confused : Whilst I can get my head around most things , HRC V4 valve timing , Triumph Trident primary transmissions etc , I am having a problem undestanding Norton Isolastics ; Can somebody please explain to me EXACTLY what the 2 smaller rubbers secured by the circlips ; the ' Engine Mounting Buffers ' on the Engine Mounting Spacer as named in the parts manual in the middle of the Engine mounting bracket do? and how? they just appear to take up space for no reason....????? confused Johnny
What d'ya mean it won't rev to 10?
1965 BSA A65D Lightning Rocket
1976 K*w*s*ki Z900.
1978 Triumph Bonn3ville (930 T160 Powered T140)
1988 H*nd* RC30
1990 Moto Guzzi California 3
1993 Y*m*h* TDM 850
Re: Another " dumbest " question...... #73856
03/09/08 1:43 pm
03/09/08 1:43 pm
Mexico City, Mexico
MexicoMike Offline
MexicoMike  Offline
Mexico City, Mexico
Actually, they don't do anything!
They were left over parts from Norton's abortive attempt to manufacture garden watering hose. It was unsuccessful because the prototype hose leaked where it was joined to the fittings despite every type of connection and/or sealer that was tried.
Management decreed that the prototype had to be used for something as opposed to destroyed, for fear of the bad publicity that would occur if the media learned of the failure/destruction.
One of the shop stewards received a cash award when he proposed a scheme whereby the hose was cut into thousands of small rings and inserted into the Isolastic units. All the hose was used in this way since it effectively disposed of the hose, did not adversely affect the use of the motorcycle, and could not be seen in normal operation.
OK, OK, I have no Idea about the real answer to the question but doesn't the above sound like it COULD be true! smile
Re: Another " dumbest " question...... #73857
03/09/08 4:26 pm
03/09/08 4:26 pm
Hamilton, Mass. USA
Dave Comeau Offline
Crew Chief
Dave Comeau  Offline
Crew Chief
Hamilton, Mass. USA
The bigger rubbers support the normal position of the drive train components. They allow for a softer deflection rate for cruising conditions and single weigh load. Therefore a more generous movement is allowed.
The secondary buffers are to create a stiffer deflection rate for the kiddies doing hole shots. Upon a much higher load the secondary rubbers make contact and severly reduce physical deflection.
This can also be noticed if you try and use the commando as a pickup truck to carry your camping stuff or a heavy passenger... you WILL bottom out the conventional 1st buffer and people of average awareness will definitely notice the huge increase in vibration being transmitted to the frame. You are now running on BOTH rubbers...the big diameter ones and the small diameter buffers
bigt
dynodave
BSA 3 1961-1963
Ducati 3 1992-2002
Norton many 1951-1975
Re: Another " dumbest " question...... #73858
03/09/08 6:37 pm
03/09/08 6:37 pm
Belgium
7
79x100 Offline
79x100  Offline
Belgium
bigt
So Commandos are designed not to carry overweight passengers ? Good job that Harley and Honda's Gold Wing have got that segment tied up then ! bigt
'39 WD16H
'75 850 Commando
Re: Another " dumbest " question...... #73859
03/09/08 8:32 pm
03/09/08 8:32 pm
Dordogne, SW France
Dordogne, SW France
Ahhh thanks Dave , I understand now ; OK ,all the original rubbers appear to be in very good condition the exception being the larger rubber bushes did'nt sit square in the tube and have taken a "set" , I shall replace these , the teflon spacers are marked around their perimiters although there were NO shims when I stripped the mounting down , the bike had failed it's M O T because of too much play in the iso's and the owner has left it for 15 years...... :rolleyes: I think someone had tried to set up the system but did'nt get it right , however they left it all nicely greased and unbodged so it's a pleasure to work on. Johnny smile
1976 K*w*s*ki Z900.
1988 H*nd* RC30
1993 Y*m*h* TDM 850
Moderated by  Dave Comeau
Page Time: 0.216s Queries: 14 (0.007s) Memory: 1.0164 MB (Peak: 1.1641 MB) Zlib disabled. Server Time: 2018-04-26 09:35:00 UTC
