kingodawg
kingodawg
Cleveland,Ohio
194 registered members (79T140E), 2,181 guests, and 594 spiders.
koan58 90
Lannis 88
NickL 86
Stuart 57
505,913 mail-order LSR
Topics66,065
Posts639,446
What do they mean regarding a porous head on an 850 #73773
03/05/08 3:53 am
03/05/08 3:53 am
Folsom, CA
Y
yellow_cad Offline OP
Y
Folsom, CA
In the Norton Commando article in December 2006 Classic Bike magazine on page 73, Roger Meyers states, that porous cylinder heads are not unusual on 850s. He goes on to say that oil will weep from the front of the casting above the gasket. Has anyone experienced this and is there any fix? When my oil tank was at the full mark, I had lots of oil in this area. I am watching this now so I am greatly interested in just exactly what Roger is referring to.
Jim
1970 Triumph Bonneville
1973 Commando Interstate
1971 OSSA MAR
Re: What do they mean regarding a porous head on an 850 #73774
03/05/08 8:26 am
03/05/08 8:26 am
australia
douglas Offline
douglas  Offline
australia
I imagine the oil tank level isn't relevant, unless you mean something else?? Douglas
Re: What do they mean regarding a porous head on an 850 #73775
03/05/08 5:21 pm
03/05/08 5:21 pm
Hamilton, Mass. USA
Dave Comeau Offline
Crew Chief
Dave Comeau  Offline
Crew Chief
Hamilton, Mass. USA
Yes the article is just repeating an incredibly old fact that the castings were typically porous.
Some processes called for something like a rosin dip that sealed similar casting done.
This was also the case with old Lotus twincam aluminum heads (british castings in the 60's-70's)...porous and rosin treated.
In addition all commando heads and cases were painted to possibly to seal them up.
I learned about this in the late 80's when I was stripping gasket goo off the gearbox outer cover with methylene chloride type stripper and found it was also eating the "paint/coating" off the inside of the cover. This must have been how they coated polished covers...by painting the inside...
Later I found the heads and cases were all painted also.
Once you clean in a dip solution or bead blast them you remove this coating. Some heads may not have been fully treated from new if they leak.
Stripping the head is obviously only half the process if the sealer coating is not replaced. .
2c
dynodave
BSA 3 1961-1963
Ducati 3 1992-2002
Norton many 1951-1975
Re: What do they mean regarding a porous head on an 850 #73776
03/05/08 11:27 pm
03/05/08 11:27 pm
Folsom, CA
Y
Y
Folsom, CA
Is there a paint or coating of some sort that can be painted on to the exterior of the head and basically baked on by the engine heat?
Jim
1971 OSSA MAR
Re: What do they mean regarding a porous head on an 850 #73777
03/05/08 11:51 pm
03/05/08 11:51 pm
Hamilton, Mass. USA
Dave Comeau Offline
Crew Chief
Dave Comeau  Offline
Crew Chief
Hamilton, Mass. USA
It is pretty much up to what you want it to look like...
I have have had people send me "clean' heads for exhaust port repair that was slathered with spray can gray/silver. that would work but eventually will change color a bit and it doesn't look natural.
I use (all aproximate) 1 part hardware store radiator silver/aluminum paint, with 1 part acrylic enamel silver, with 5-10 parts thinner and a touch of isocyinate hardener. When this is sprayed on, it is almost not noticeable that it is there. Which is what I want.....a clean aluminum finish that doesn't corrode and turn dark.
The dark is what I refer to when you clean a head and see texture and color differences.
This is from spots where the paint has come off and the aluminum corroded a bit and changed color compared to the protected areas.
I will be mixing up a batch to spray my hubs for my dunstall atlas and dunstall commando, that I am now relacing their Boranni rims with new SS spokes. Hope to have them both ready for the INOA rally this july.
Just strip a case with stripper and you will..well see what I mean. those darker stained spots.... mad
dynodave
BSA 3 1961-1963
Ducati 3 1992-2002
Re: What do they mean regarding a porous head on an 850 #73778
03/07/08 12:24 am
03/07/08 12:24 am
Folsom, CA
Y
Y
Folsom, CA
When doing a rebuild, does anyone ever powder coat thses heads in order to seal them up good?
Jim
1971 OSSA MAR
Re: What do they mean regarding a porous head on an 850 #73779
03/07/08 12:43 am
03/07/08 12:43 am
Flint,Mich
norbsa48503 Offline
norbsa48503  Offline
Flint,Mich
This man has, see HawaiianTiger
norbsa
1960 TR6
1963 Super Rocket
1965 650 Star
1966 441
1968 Thunderbolt
1969 Twinkle 250
1972 Fastback
1974 Roadster
1970 S.S
Way too many BSA's not named
http://decentcycles.com
Re: What do they mean regarding a porous head on an 850 #73780
03/07/08 1:57 am
03/07/08 1:57 am
McKellar,Ontario
Kommandokenny Offline
McKellar,Ontario
I thought about this also, but I wonder if powder coating the head would impede the dissipation of heat from the head???? confused
If Norton made an airplane,would you fly in it?
Re: What do they mean regarding a porous head on an 850 #73781
03/07/08 10:01 am
03/07/08 10:01 am
England
Seeley Offline
Seeley  Offline
England
In the UK there is a company called ultraseal who can sort this out, they've successfully done a few heads for me in the past, and also on my friends 150 rocker boxes etc, to the extent that we now have all castings done before building the motors! i notice they have a US office too, so it might be worth a try!!
http://www.ultraseal.co.uk/index.html
Re: What do they mean regarding a porous head on an 850 #73782
03/07/08 12:26 pm
03/07/08 12:26 pm
Hamilton, Mass. USA
Dave Comeau Offline
Crew Chief
Dave Comeau  Offline
Crew Chief
Hamilton, Mass. USA
Yes I guess some might.
2c
To me...well this is like putting on a scuba diving wet suit before sex instead of a condom laughing laughing
The vacuum impregnation which we do here at work would result in an almost undetectable coating. Actually it primarily is intended to go where there are cracks and little pits and caverns. Where the cavern completely goes through are the ones of prime interest.
dynodave
BSA 3 1961-1963
Ducati 3 1992-2002
Re: What do they mean regarding a porous head on an 850 #73783
03/07/08 1:26 pm
03/07/08 1:26 pm
mitchp Offline
mitchp  Offline
My '74 850 has a porous head - oil seeps out through a pinhole in the casting behind the right hand exhaust rocker box. It was "Ultrasealed" by the PO about 5 years ago, but the leak came back. Fortunately the pinhole is just accessible and a blob of clear silicone sealant has done the trick.
BUT...oil at the front of the head is far more likely to be coming from the inlet rocker cover or oil feed banjos. Oil leaking from just about anywhere on a Commando head will appear between the exhaust ports on top of the third fin. For proof, pour a little water on the inlet rocker cover and see where it comes out....
Mitch
Minds are like parachutes - they only work when they are open.
Moderated by  Dave Comeau
Page Time: 1.206s Queries: 14 (0.012s) Memory: 1.0697 MB (Peak: 1.2615 MB) Zlib disabled. Server Time: 2018-02-25 19:27:45 UTC
