YankeeJerry
YankeeJerry
Connecticut
25 registered members (Al Eckstadt), 195 guests, and 443 spiders.
10257 Registered Users
Stuart 75
Lannis 56
610,370 mail-order LSR
Topics67,139
Posts651,527
Members10,257
fork clunk #720661
12/31/17 10:42 pm
12/31/17 10:42 pm
rock hill ny
dale sonny Offline OP
rock hill ny
Hey all. I took my forks apart and replaced the bushings, seals, dampener tubes and upper fork tubes. They are back together now and when I compress the suspension it seems ok. But if I pull up on the bars, when the forks top out they clunk. I don't think it did it before I took them apart but I never pulled up on the bars. This is on my 69 Daytona bitsa. Could I have something together wrong? I used 15 wt oil and put in 200cc.
69 Daytona/ scrambler
02 BMW r1150r
assorted vintage dirt bike's
Re: fork clunk [Re: dale sonny] #720663
12/31/17 10:50 pm
12/31/17 10:50 pm
kommando Offline
kommando  Offline
The sleeves between the bushes, did you fit them thick end down ?
Re: fork clunk [Re: dale sonny] #720664
12/31/17 10:54 pm
12/31/17 10:54 pm
rock hill ny
rock hill ny
Yes I did. By luck, I saw the old ones were that way.
02 BMW r1150r
Re: fork clunk [Re: dale sonny] #720669
12/31/17 11:41 pm
12/31/17 11:41 pm
kommando Offline
kommando  Offline
Look at your brakeplate and see if the fork leg nub is moving in the brakeplate slot and giving the clunk, if it is then shim the gap.
Re: fork clunk [Re: dale sonny] #720684
01/01/18 1:29 am
01/01/18 1:29 am
rock hill ny
rock hill ny
it only clunks when the forks top out. No noise while compressing the forks.
02 BMW r1150r
Re: fork clunk [Re: dale sonny] #720686
01/01/18 1:53 am
01/01/18 1:53 am
Bishop, Calif.
desco Offline
desco  Offline
Bishop, Calif.
It seems to me that the oil works in one direction and the springs work in the other. PJ1 makes fork oil in many weights. Try a heavier weight. I saved a buddy of mine $300 with this suggestion.
Re: fork clunk [Re: dale sonny] #720688
01/01/18 2:10 am
01/01/18 2:10 am
New Zealand
Excalibur Offline
Excalibur  Offline
New Zealand
As the bike is a bitsa, could springs be 650?
Try heavier weight oil as suggested, it's easiest thing in process of elimination.
Re: fork clunk [Re: Excalibur] #720751
01/01/18 4:46 pm
01/01/18 4:46 pm
rock hill ny
rock hill ny
The springs are new also. I forgot to put that in the first message. I'll try heavier oil. A guy from a triumph club at VMD told my buddy to use no heavier than 20wt oil. I'll try that. My buddy actually had 50wt oil in his and they still clunked. My old damper tubes were plastic. New ones were alloy. Could that be it?
02 BMW r1150r
Re: fork clunk [Re: dale sonny] #720867
01/02/18 4:21 pm
01/02/18 4:21 pm
Lancaster, California
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
My '68 TR6 forks always clunk when I put it on the main stand. I rebuild them twice with the same effect. I stopped worrying about the same stuff and just let it be. I suppose try a thicker oil
Re: fork clunk [Re: dale sonny] #720896
01/02/18 8:08 pm
01/02/18 8:08 pm
rock hill ny
rock hill ny
I never noticed the clunk while riding. But I haven't ridden since the new fork parts. I did notice it after I rebuilt the forks and jacked it up on my stand. Maybe it was doing it before. My buddy rides a 65 650 off road and his clunk a lot riding the woods.
02 BMW r1150r
Re: fork clunk [Re: dale sonny] #720972
01/03/18 7:45 pm
01/03/18 7:45 pm
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
I'm curious to know the "real" reason why the forks clunk. I keep hearing about the sleeves ordeal but that didn't fix my problems.. Is it the nature of the forks?
Re: fork clunk [Re: dale sonny] #720980
01/03/18 9:05 pm
01/03/18 9:05 pm
Mississauga, Ontario.
Adam M. Offline
Adam M.  Offline
When sleeves are installed incorrectly they give much more than a clunk smile.
Clunk is normal with these forks when they extent to max length - the lack one spring to dampen it.
71 and up forks have it and no more clunk you can here from them.
