Kent Shaun
Kent Shaun
Kent Garden of England
25 registered members (Alan_nc), 208 guests, and 405 spiders.
pemdoc65, creativecroc, gregneal, Chris Marsland, heathcliff
10169 Registered Users
Lannis 100
Stuart 88
reverb 78
NickL 75
koan58 54
548,613 mail-order LSR
Topics66,537
Posts644,984
Members10,169
Page 2 of 2 1 2
Re: joined the Goldie cult! [Re: L.A.kevin] #720523
12/30/17 9:13 pm
12/30/17 9:13 pm
Los Angeles, CA
L.A.kevin Offline OP
Los Angeles, CA
What the heck are these pushrods?
I was noticing when checking valve clearance that the pushrods look a little weird. Do these look strange? These have a constant diameter at the lower end, whereas most pushrods I've seen have a reduced diameter at the follower end.
Re: joined the Goldie cult! [Re: L.A.kevin] #720587
12/31/17 10:30 am
12/31/17 10:30 am
Norfolk England
DBDBrian Offline
DBDBrian  Offline
Norfolk England
Welcome to the Goldstar fraternity Kevin. Your pushrods would seem to be aftermarket solid duraluminium,(to prevent flexing). possible Eddie Dow.
I run a set in my Goldie, but I have fitted short steel bottoms to prevent them pocketing into the follower, which inhibits valve adjustment.
Brian
Made In England
Re: joined the Goldie cult! [Re: L.A.kevin] #720652
12/31/17 9:18 pm
12/31/17 9:18 pm
Webco also made aftermarket alloy pushrods. Some debate about whether lightening the valve train is beneficial or not.
Re: joined the Goldie cult! [Re: Boomer] #720670
01/01/18 12:09 am
01/01/18 12:09 am
Los Angeles, CA
Los Angeles, CA
Thanks Bill and Brian. Will have another debate with myself as to whether I'll go with stock or ABASAF pushrods. Or???
I had a long ride today of about a 100 miles. Went up the Angeles Crest and ran 'er in well. I had the back brake adjusted too tight and cooked it a bit, but still seems to have some bite. The rear tail light lens went walkabout, and both speedo and tach decided to go nuts. Spun right around about the same time. Whoever rebuilt them last must have used some sort of locking device or threadlocker chemical that failed exactly the same time.
Bike ran well. I had a 240 main jet that i replaced the 320 jet with. Will order some new jets soon and try to get a 220 in there and see how it runs. Will try Magneto Man's carb settings because I believe our bikes are very similar- well at least mechanically.
Kevin
Re: joined the Goldie cult! [Re: L.A.kevin] #720678
01/01/18 12:50 am
01/01/18 12:50 am
Rich B Online happy
Rich B  Online Happy
Congrats on the ride. clap
A GS is a sweet ride, especially when you get them dialed. Surprisingly competent for a 1950’s motorcycle.....
grin
Re: joined the Goldie cult! [Re: Boomer] #720681
01/01/18 12:58 am
01/01/18 12:58 am
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
Any reduction in reciprocating weight is beneficial as it reduces the load on the components
1962/67 Greeves 350
1967 Greeves 360 Challenger
Jawa 500cc "Llareggub"
Re: joined the Goldie cult! [Re: Andy Higham] #720685
01/01/18 1:51 am
01/01/18 1:51 am
I was referring to performance purposes.
Re: joined the Goldie cult! [Re: L.A.kevin] #720803
01/01/18 9:39 pm
01/01/18 9:39 pm
Elko, Nevada USA
dave - NV Offline
dave - NV  Offline
Elko, Nevada USA
Reference to pushrods mentioned here. I've commented on this before ... It's commonly acknowledged by many mc and auto performance tuners that pushrod harmonic flex causes unreliable cam timing as the flex will cause the valve to 'bounce' on the seat. This has been shown with high speed sychro cameras.
Anyhow .. I've fitted ABSAF double ball ended tubular chrome moly pushrods and their ball socket cam followers in two GS engines, one a racer and the other my 'special' road bike. It's 'a bit of a fiddle' arriving at the correct length but certainly not beyond our home shop talents. The ball ends are pressed into the tubes. I had some alu tubing in my 'stuff' with the correct ID that I used as test models before cutting the steel tubing. It's difficult to remove the ball ends that are a press fit into the steel tubing if you need to redo the length. So my son the ME designed and made a neat puller tool for myself and GStarRon (RIP).
I do have some question using steel vs alu for GS pushrods. As the steel rods will have little growth due to engine heat as would alu rods growing in length compensating with the cylinder muff growth. hmmm. I've been setting the cold valve clearances at 'just able to spin' vs the OEM specified 6 thou. This is a strong argument to modify the GS rocker box with removable caps to do a 'look see' of valve clearances in a hot engine. And then be able to adjust clearance as needed.
dave - NV
Page 2 of 2 1 2
Page Time: 0.093s Queries: 16 (0.017s) Memory: 1.0535 MB (Peak: 1.2292 MB) Zlib disabled. Server Time: 2018-04-19 09:59:48 UTC
